Here is a list of all the postings Philip Rowe has made in our forums. Click on a thread name to jump to the thread.
Thread: Strength of Cast iron |
13/05/2018 16:20:19 |
Posted by Peter G. Shaw
I am, of course, assuming that their scales will have been checked for accuracy. Wot! You didn't ask to see the calibration certificate? Phil
Thread: Pressure as a unit of time |
25/04/2018 16:13:02 |
I can see that in some arty farty antique shop selling for around £300! So I suggest that we all have a rummage under the bench and start producing antiques for the future. Phil |
Thread: Department of Work and Pensions |
21/04/2018 11:33:53 |
Posted by SillyOldDuffer on 21/04/2018 11:12:51:
Posted by Bazyle on 21/04/2018 08:56:02:
Pensions are a mess. I have no idea what to recommend to my kids. Dave Money stuffed under the mattress? Phil |
Thread: Rotary brass brushes |
18/04/2018 16:32:28 |
I bought a 220 grit version earlier today with a 'click-lock' fitting which is a convenient but not necessary means of attaching to the mandrel. To say I'm impressed would be an understatement, it is obviously coarser than the brass bristled brush that I have been using and consequently removes crud a lot faster but more importantly for me is the total lack of bristle shedding. Also being a larger diameter I can get in to more difficult places than with the brass version. Thanks again to Bill Phinn for bringing these to my attention, I will be buying more of these with different grades in the near future but not I hasten to add from any diy shed, their prices are no match from the source in Bill's link. Phil |
17/04/2018 16:45:56 |
Posted by Bill Phinn on 17/04/2018 16:25:10:
Besides the Scotchbrite mops there is another very efficient tool for putting a sheen on metal as opposed to polishing it, namely radial discs: http://www.cooksongold.com/Jewellery-Tools/3m-Radial-Abrasive-Disc-Yell-------Pack-of-6-prcode-997-5104 They come in many grades from 80 grit to several thou. They do not spit bristles and are very popular with the jewellery manufacturing trade. The coarser grades' ability to remove oxidation and general griminess is remarkable. Thanks for the link Bill, looks like this maybe exactly what I am looking for. However I am somewhat puzzled by the product information on the Cookson website that states that the product is fitted with a British 3 pin plug Phil |
17/04/2018 11:34:18 |
Thanks everybody all the suggestions and ideas, I have already tried the stainless brushes and I've found them a bit too aggressive for what I trying go do. However I've not tried the scotch brite variety so I think a bit of experimenting is called for. I will be nosing around my local dealer tomorrow (10% day @ B&Q) so I'll have a look. Phil |
16/04/2018 17:01:16 |
I'm sure that a lot of members here use the little rotary brass bristled brushes in a Dremel or similar rotary device. I use them from time to time for cleaning up steam fittings that need to look clean but not polished to a mirror finish. The problem that I have with them is that they shed the bristles at an alarming rate and I get fed up with picking the pieces out of my hair and clothing, I do wear full face protection because of this. Really just wondered if anyone has found a better quality brush that maybe doesn't shed so rapidly or perhaps a better way of cleaning the brass. Phil |
Thread: Warco WM 16 Read out conversion |
16/04/2018 16:27:17 |
I too have experienced annoying battery failures at the most inconvenient times but nowadays I will only buy the silver oxide variety of button and coin cell types. I generally get about a year from the batteries in my calipers and the DROs that I've fitted to my lathe but I am quite careful about switching them off. Whatever you do, don't buy from supermarkets or other high street outlets, they never seem to have much shelf life left and you will pay way over the odds for them. One of the best sources that I have found is from ARC (usual disclaimer) and I always keep a spare set to hand just in case. Phil |
Thread: William build |
11/04/2018 12:29:38 |
I know that you say that you don't want to make union nuts but seriously they do only take a few minutes each to make. I have had similar issues with pipe and union sizes in the past and my standard default is to make my own, that way I get exactly what I want without trawling through supplier's lists. Phil |
Thread: Lathe form tool query |
05/04/2018 20:41:06 |
Thank you gentlemen, you have given me some food for thought. The quality of the advice given on this forum really is second to none. Also on the subject of quality, the accuracy the humps is not so important I just want to get them all the same, I'm going to do some experimenting over the next few days with some of these ideas and will report back in due course. Phil |
05/04/2018 17:04:57 |
Strangely that is a technique that I had considered but I don't have any experiences of using these small grinding points and to be honest I don't think I have ever seen one just 2mm in diameter. Phil |
05/04/2018 16:44:00 |
I want make a form tool to produce a series of 'humps' (similar to clock frame spacers ) on a piece of 6mm diameter stainless bar. Normally for a one off I would use files and emery but this time there are several to do and for cosmetic reasons I want to keep them all the same. I am thinking of making the form tool from a piece of gauge plate, by drilling a hole 2mm diameter at an appropriate angle to give relief to the cutting edge, mill away half of the diameter and then harden the plate by quenching in oil. Not sure if tempering is necessary as there are only 6 humps to form. Any advice on the validity of this method would be most welcome, I have done the same in the past with brass but stainless is a whole new ball game for me. Phil |
Thread: What did you do Today 2018 |
05/04/2018 12:31:47 |
To be honest it was yesterday, I broke a M5 tap don't ask how but it was my own stupidity. Ordered a replacement from Tracy Tools along with some other bits that had been on the list for a while. Order timed at 16.27 with ordinary postage, package arrived earlier this morning. How's that for service, not only by the supplier but also the Royal Mail. Needless to say I have no connection with either organisation apart from being a very satisfied user. Phil |
01/04/2018 16:45:19 |
Today I finished a lantern chuck that I have been making, unashamedly pinched the idea from another post on here about shortening screws, thanks to all of you for the ideas. I think that I may have slightly over engineered it but I feel justified in that it can be used for quite a range of screw sizes. The photo shows it set up with a 2mm screw fitted ready for shortening along with some collars for other sized screws and a few blanks for screws of unknown size that will inevitably require working on. Although not seen in the photo the knurled ring is double sided, so with another clamp ring (which I haven't yet made) it will be capable of dealing with larger screws up to 8mm. Phil |
Thread: Silver Clay , Copper Clay and Bronze Clay |
30/03/2018 12:15:06 |
I too watched the programme and was impressed with the relative ease with which quite complex shapes could be produced, obviously ideal for jewelry but it didn't stop me from thinking about how a bronze/copper clay could be used for cosmetic items in model engineering. The only downside apart from cost is the necessity to be able to sculpt the item in the first place, a technique that I have absolutely zero ability. Phil |
Thread: Why Brass?? |
24/03/2018 11:56:47 |
Posted by Ed Duffner on 24/03/2018 04:17:41:
Carbon Fibre perhaps, for that modern look? ...or an aluminium/brass alloy, if there is such a thing. Ed. Many years ago I worked for a radio valve manufacturer and an aluminium/brass alloy was often used in the forming of the glass envelope of the valves as it had the same coefficient of expansion. I have no idea what the alloy proportions were but it had definite grey tinge, nothing like traditional brass colours. I still have a piece somewhere and even after 50+ years there is no discoloration or patina showing. Apologies for wandering off topic. Phil |
Thread: Shortening screws |
15/03/2018 16:15:37 |
Posted by Steve Crow on 15/03/2018 13:40:08:
I made a primitive lantern chuck for small screws. The collets are for 12BA and M1.6. Steve, that looks like a very useful lathe accessory - at least for the things that I do. One thing does puzzle me, it appears from the photos that the individual collets are not threaded, I would have thought that if they were it would give you more control over where the screw sits in the chuck, or am I seeing a problem that isn't really there? Phil |
Thread: Tap washers |
08/03/2018 13:30:32 |
Wandering off topic again, has anybody ever dismantled one of the newer ceramic valved taps? Just curious as to how they operate. Phil |
Thread: Spotting Drill or Centre drill. |
27/02/2018 16:49:56 |
I've only recently switched to using a spotting drill thanks to advice on this forum, initially to be able to get chatter free countersunk holes in brass, but have found them so useful in other areas. So much more rigid and no annoying pip to get broken off. Expensive in comparison but I think money well spent, well so far for me at least. Phil |
Thread: Hobby related jokes |
27/02/2018 11:30:53 |
As this thread seems to have wandered slightly, I thought that I would add that in 1973 when I bought my Super 7 supplied new by an ironmongers in Worthing it cost me from memory about £380. As a basic machine it didn't come with any chucks or even a motor, however you did get a faceplate, catch plate and a couple of centres but I can't remember if it had a drive dog. An expensive piece of kit that was unusable as supplied. Phil |
