Here is a list of all the postings ega has made in our forums. Click on a thread name to jump to the thread.
Thread: Hello and a question to start with |
07/02/2020 10:29:59 |
Posted by John Haine on 07/02/2020 09:14:24:
Glad you sorted it Ian. Your chuck body is probably hardened so I doubt that a JT33 reamer would have helped anyway. I have also resorted to Loctite to make sure a chuck doesn't come off the taper - I don't see why it isn't a perfectly good engineering solution. A chuck that won't stay on its taper is obviously of no use and any solution is better than none. I found a paragraph in my 1966 edition of the Loctite Design Handbook headed "Adding adhesives to splines and tapers" which seemed promising; however, the text seemed to be concerned with joints where play is present between the components (which may have been present in the OP's case but certainly should not have been). The Handbook also say that the bond in tapered overlap joints can be "very good". I have always addressed this problem where possible by the screw method; it's effective and does allow ready dismantling and I have never had any difficulty in drilling the necessary axial hole in the chuck body (chucks on reversing hand power drills are, of course, retained in this way). |
Thread: Delays in Shipping from China |
07/02/2020 09:22:13 |
Posted by clogs on 07/02/2020 06:16:48:
just goes to show how complicated world trade really is.......
A quick OT comment: I just bought some black pepper in my local UK co-op "packaged in Turkey from pepper produced in Brazil". |
Thread: Linked belt for Myford 7 |
06/02/2020 17:15:37 |
I have link belts on both primary and secondary drives on my S7. One advantage over the conventional vee belt is said to be that the link belt won't take up and "memorise" a set if left taut and unused for a period. Replacing the drive to the spindle with a link belt obviously avoids the need to dismantle. On the other hand, the greater bulk of the link belt may make shifting to and from the top speed pulleys more difficult. |
Thread: Noisy Lathe Gearbox |
06/02/2020 17:08:23 |
Posted by David Jupp on 06/02/2020 17:00:04:
The attack of bronze typically happens when acidic combustion by-products are present alongside the EP additives. So the thing you typically should avoid is using an EP oil in an engine. In a gearbox there shouldn't be combustion by-products present, so no problem. Rather like not brushing your teeth too close to eating! What about other additives such as moly or Redex? |
Thread: Effect of Tensioning a Boring Bar |
06/02/2020 14:04:39 |
In his ME manual GHT recounted how he had been challenged on the use of silver steel for his boring bars. Whilst, I think, conceding that they were no stiffer than if made in MS he preferred silver steel for its greater resistance to abrasion and the fact that it was more likely to hold up to nominal diameter (his bars were clamped in eccentric holders and a sloppy fit would have been unhelpful). Edited By ega on 06/02/2020 14:05:05 |
05/02/2020 16:56:07 |
Posted by John Haine on 05/02/2020 16:45:42:
Is the chuck falling off the Jacobs taper or the morse taper falling out of its socket? If the former, keyed chucks can be secured with a screw. |
Thread: What bench drill |
05/02/2020 14:42:39 |
Posted by Bazyle on 05/02/2020 12:58:59:
A low usage 30yr old far eastern drill can be quite a nice unit. I stored one for a club member a couple of years ago and was getting more jealous each time I went into the garage. If the quill is sloppy there was a modification published for making the operating arm spindle bushes a little eccentric to push it against the quill rack. Another mod was to put a brass push screw in at the front. In the same vein, you could turn up a close-fitting bush and screw it to the underside of the head casting to stabilise the quill. |
05/02/2020 12:05:07 |
Did I see somewhere that the additives in EP oils are detrimental to bronze, a material which is sometimes used in geared headstocks?
Thread: Only for Myford lathes |
05/02/2020 12:02:14 |
Posted by Steviegtr on 05/02/2020 10:56:46:
As above the B for QC gearbox. Look here for all the machine changes over the years. It seems the broad bed cross slide was introduced in 1972 & the powered cross feed in 1974. Edited By Steviegtr on 05/02/2020 10:57:18 Thanks for the interesting link. For clarity, I think the bed width remained unchanged when the arrangement for guiding the saddle was changed. The move from narrow guide would have been desirable regardless of the introduction of PXF. |
04/02/2020 11:27:20 |
thaiguzzi: Your machine may have been the elder and larger brother to mine which, according to its plate, was made in Taiwan in 1988. Incidentally, my impression is that Taiwan is holding its own industrially vis a vis China. |
Thread: Myford S7 long bed |
03/02/2020 14:26:28 |
Posted by Nick Hulme on 03/02/2020 14:20:16:
Posted by ega on 03/02/2020 12:19:54:
Posted by Nigel McBurney 1 on 03/02/2020 09:31:48:
... Small lathes do not need power cross feeds,its a fad rather than an essential,learn to twiddell the feed handle at a constant rate. I tend to agree with this but isn't one of the advantages of hand feed that the rate can be varied eg as in facing to centre? Better still is a VFD to increase the rpm as the cut radius decreases, with a little ingenuity an easily built linkage can be produced to actuate a speed varying potentiometer.
I believe there have been specialist lathes that perform this trick. I do it manually with one hand on the cross slide handle and the other on the pot - rather like the cook and the drummer! |
03/02/2020 12:37:40 |
It sounds as though the cheap Asian drill may have become cheaper over time: a friend gave me an old Astra import which had been condemned by his employers on account of the flange connecting the column to the base having cracked in service; this was easily replaced and, despite being rather noisy, it has given good service for some years. Checking the quill at full extension just now revealed no obvious side play. The main limitation of these machines for me is the overhead in time of setting the speed; there seem to be rather few drills available with rapid speed change.
Thread: Ian S C Back again |
03/02/2020 12:23:23 |
Posted by Ian S C on 03/02/2020 09:37:41:
Just a reminder, it's good idea to set up you profile. It doesn't need to be too much, but if we know where you are and what you know, it helps others if they think they can help. You don't have to ramble on as I did with mine. Ian S C Strongly agree. How often does a newcomer post a question or request for help that calls for some idea of their location! But feel free to ramble. |
03/02/2020 12:19:54 |
... Small lathes do not need power cross feeds,its a fad rather than an essential,learn to twiddell the feed handle at a constant rate. I tend to agree with this but isn't one of the advantages of hand feed that the rate can be varied eg as in facing to centre? |
Thread: How do I change the "default" lever angle on my Verdict DTI? |
02/02/2020 11:28:09 |
I have a Verdict T500. There is no reversing lever or obvious way of re-setting the stylus; the stylus does, however, move in either direction to give a reading on the dial. Does anyone actually know whether re-setting on this model is just a matter of using sufficient force on the stylus? Verdict DTIs used to be made/serviced here in Kent and the firm were helpful at exhibitions. |
Thread: Rear parting |
02/02/2020 11:15:50 |
Posted by John Baron on 02/02/2020 09:44:02:
Posted by Kiwi Bloke on 02/02/2020 00:35:05:
Beware of putting severe tension loads on T-slots. John Baron's toolpost obviously hasn't caused the T-slot to break (yet...), and he has fitted a reasonably long nut. I think I'd use the longest nut I could fit and would ideally spread the load by fixing the post to the nut in more than one location. The Myford/Thomas style above takes the T-slot protection further by spreading the load between two slots. The quick-change holder then adds flexibility and moves the forces outside the footprint of the post. Nothing is ideal, is it?
Actually I agree with you ! I've seen Myford's with the "T" slots broken out, and not just the rear ones. I deliberately made the "T" nut a good fit and it goes right across the bottom of the post.
I did get another piece of steel to make another support block that goes over the post and is secured in the next "T" slot, the idea being that it would effectively increase the footprint and add support. Unfortunately I have not got round to making it yet. Other projects have got in the way.
I recall Martin Cleeve suffered a tee slot breakage whilst parting off on his ML7; characteristically, he proceeded to replace his cross slide with one fabricated from steel. Myfords apparently thought that their own RTP could be held by a single slot but I prefer the Duplex/GHT use of two. Good point by old mart about the need to control saddle lift. |
Thread: Eclipse No 101 Adjustable Scribe |
29/01/2020 15:58:33 |
Aren't these case-hardened? PS Just checked the catalogue - they are. Edited By ega on 29/01/2020 16:00:24 |
Thread: Combi-Die |
29/01/2020 14:20:09 |
I had not heard of this before I saw the current items for sale. There is some information here: https://www.newmantools.com/taps/combidie.htm including the statement that perfect threads are produced without reversing. This is a hand applied tool and not one I would have much use for but I would be glad to know how the no reversing feature works. Perhaps the holes intersecting the thread are that much bigger? Edited By ega on 29/01/2020 14:20:34 |
Thread: Caliper friction washers |
27/01/2020 15:32:45 |
Posted by Grindstone Cowboy on 26/01/2020 23:09:49:
Comparing the distances 'twixt woods and jack, I would guess - I inherited a handy little string and ivory gizmo for the same purpose from my grandfather. I expect you are right but one would need a steady hand to avoid disturbing the status quo (I assume they were firm joint calipers). |
26/01/2020 23:00:46 |
Posted by Ian S C on 25/01/2020 08:14:12:
I m,ade 150 pair of calipers for the Christchurch Indoor Bowls Ass, I put a washer made of shim brass (about .010" Ian S C Presumably, the calipers were for measuring woods? Kiaora! |
