Here is a list of all the postings ega has made in our forums. Click on a thread name to jump to the thread.
Thread: Ticket Clippers?? |
23/04/2017 21:16:55 |
These seem very similar: |
Thread: What Did You Do Today (2017) |
23/04/2017 18:53:17 |
I was inspired by Darren Conway's setup for balancing a pulley in MEW 254 to check the balance of my CBN wheel. I was surprised when I bought it described as balanced to see how many holes had been drilled to achieve this. Here's a picture of my own setup showing the wheel actually settled at the point of the drillings: And here's the result of adding 5 gms of Blutack to the opposite side: Now to calculate the size of hole apparently needed! Edited By ega on 23/04/2017 18:54:28 |
Thread: Lathe chuck removal |
22/04/2017 10:57:32 |
Mike Poole: Points taken; the link on lathes.co.uk relates to a South Bend lathe where the tool grips the spindle rather than anything keyed to it. |
21/04/2017 17:11:42 |
Posted by Niels Abildgaard on 17/04/2017 07:18:07:
If Chuck is really stuck this helps There are to many broken back gears out there.
Thanks for this link to a useful-looking tool. I don't recall Tony Griffiths' website article on this subject being mentioned here - I only chanced on it myself just now - but it is well worth reading and contains a link to a similar tool. Tony doesn't mention Sparey but he does sell his book! |
Thread: Sudden Radio Adverts on my computer? |
20/04/2017 10:19:30 |
Martin King 2: We are all on the road to Domestos! |
Thread: Boring copper tube problems |
19/04/2017 22:45:23 |
Rotabroach? |
Thread: Myford 10 accessories |
19/04/2017 17:00:56 |
Graham Long: Not the answer to your question but, given the premium asked for the steadies, why not make your own? |
Thread: Lathe Chuck Attachment Methods. |
19/04/2017 10:26:44 |
There is a useful discussion of this topic in Cliff Bower's Book of the Lathe and his conclusion is worth quoting: "The possibility of making special attachments for the spindle nose should be borne in mind by the lathe purchaser. If it is expected that many of these will be required, the screwed or flanged types are preferable. If standard work-holders are to be used, which is highly probable, and it is expected that these will have to be changed frequently, the tapered type of spindle nose offers advantages because of speed with which attachments can be mounted and removed." This is an old book from 1955 and I understand the Camlock came into use after this date. |
Thread: Tormach Flycutter with SEHT Insert |
19/04/2017 10:09:34 |
There is another video here: The presenter suggests that the Superfly "could even be used on a Bridgeport" but how many amateur shops have one of those? Edited By JasonB on 20/04/2017 13:30:48 |
19/04/2017 08:53:18 |
Posted by Andrew Johnston on 18/04/2017 20:42:05:
It's a shame my name was spelt incorrectly though. At least my name was correct on the front cover
Yes, I see they gave you an E for effort! I think it was right in the contents section so two out of three... |
18/04/2017 16:40:05 |
John Rudd: I would say your stable pretty much covers the field with the exception of the (I think) obsolescent long taper spindle nose L0, etc. My Willson slantbed has this feature and, apart from the extra weight of the much heavier chucks, the need to clean the taper and lock ring and tighten the latter with a large C spanner makes for much longer changeover times. |
18/04/2017 15:08:02 |
Andrew Johnston: I have no experience of Camlock which, however, I associate with larger, more expensive, modern lathes. For many, I think the real comparison will be with the flanged spigot which I understand is used by some modern popular machines (again, I have no experience of these). Thanks for your article in MEW 254. |
18/04/2017 14:30:34 |
SillyOldDuffer: By way of comment on some of your bullet points:
To Michael Gilligan's suggestion of economy I would add the factor of tradition. An advantage of the threaded mandrel is the ease of changing chucks. |
Thread: This is worth a look |
16/04/2017 17:13:37 |
Thanks to herbert punter and peak4. I watched this in some awe of the manual skills involved. Interesting that they also supply handles with these rasps - and beautiful ones at that. |
Thread: Wanted - a guide to adhesives |
16/04/2017 16:50:43 |
No 21 WPS is from 1991. I think that the author, David Lammas, also wrote an article in MEW. PS There is some information on the Arc website. Edited By ega on 16/04/2017 16:52:13 |
Thread: U-Profiles from Square Tubing |
16/04/2017 16:47:09 |
Won't square tube distort when one of its sides is cut off? |
13/04/2017 10:35:18 |
Nick Hulme: Thanks for reminding me of this thread. The reason for my resorting to PM now was that I envisaged sharing with the OP an article submitted for publication in the magazine and wanted to avoid any question of conflict with MTM's house rules. |
12/04/2017 23:22:25 |
Neil Wyatt: PM sent re your ? |
12/04/2017 17:01:10 |
Curtis Rutter: I have replied to your rmessage. Edited By ega on 12/04/2017 17:01:22 |
Thread: Dore Westbury 5" machine vice? |
12/04/2017 09:34:04 |
"vis" meaning screw, of course, making the distinction from earlier wedge-based holding devices. |
