Here is a list of all the postings Peter Hall has made in our forums. Click on a thread name to jump to the thread.
Thread: Windows 10...more worries so listen... |
27/05/2016 21:02:19 |
This is all nonsense. If you don't like Windows 10, don't use Windows 10. Pete Edited By Peter Hall on 27/05/2016 21:02:38 |
Thread: 1 Tonne Arbor Press suitability for broaching EN1A |
27/03/2016 20:02:54 |
You may get away without such a sophisticated approach. I have built an etching press similar to yours, but slightly smaller. A threaded hole through the side of the handle bush for a screw, bearing on a flat filed on the roller shaft worked for me. I have used and serviced commercially-built presses for my local printmaking studio, and although they seem to be engineered to survive a nuclear assault, I'm not sure that a keyed shaft is really necessary. It is, however, a more elegant solution than mine, so I can understand why you would want to go that way. Good luck with it anyway.
Pete |
Thread: Hand Held Casting Fettling Device |
19/03/2016 14:02:38 |
Mrs Hall said she wanted one of those, but I said not to bother. She can borrow my angle grinder anytime.
Pete |
Thread: Startrite band saw help |
22/02/2016 18:03:05 |
I once had a small startrite bandsaw. I used to use square section brass for the blade guides. Not quite the same arrangement as yours and probably wears quicker than ceramic, but should be OK unless you are using it all day every day.
Pete |
Thread: How are people finding Windows 10? |
30/12/2015 17:15:24 |
Just be careful. My laptop went OK, but I upped my netbook to 10 before I got the logo in the taskbar. It's now on a perpetual loop: starts up, then windows needs to reboot, shuts down and starts all over again. I spent an afternoon searching online for a fix and haven't found one yet. It's rendered the machine unusable and I can't get into it to do anything about it. I've found lots of people online with the same problem, but Microsoft seem uninterested in providing a solution.
Pete |
Thread: A request |
18/12/2015 18:17:48 |
Hmmm. The OP seems to have opened a can of worms. I entirely understand his point, but personally I would far rather see someone attempt to make a helpful post online than not, however garbled. And I found posting on forums difficult and intimidating at first.
My own grammar and spelling is, of course, faultless and exemplary, but even I am alarmed at the mistakes and simple errors I have made when reading back my own posts before I click the "submit" button. I often have to have several goes at editing before it is completely right. Imagine my horror when I reread the post 3 days later and realise that, quite apart from grammar and spelling, my original post seems to have been constructed randomly from one of those fridge-magnet poetry kits, and makes just about as much sense. "That's not what I meant to say at all!"
Slightly off topic, but following on from what some others have written here....
I have been listening to old men complain about standards of education, literacy and, indeed, just about everything else for the last 50 years. And I'm sick of it. The fact is that life as we know it has improved almost immeasurably over the last half-century. We are better fed, longer-living, wealthier, safer and happier (!) than we have ever been. The advances made in technology (and pretty much every other discipline) during my lifetime are astonishing. This has mostly been accomplished by the ill-educated, ignorant, illiterate, slovenly, lazy, disinterested, feckless ignoramuses who have left school since 1965. Let's give them some credit.
Pete |
Thread: New lathe arrived today : The ongoing saga |
02/11/2015 14:21:38 |
Why, Brian! Surely you're not thinking of selling up?
Pete |
Thread: The Ass is out of the stables |
28/10/2015 15:03:29 |
Posted by Ady1 on 28/10/2015 15:00:15:
The worry is a compulsory register of lathe users and jack-booted clipboard wielding council muppets marching into your home every few months to check the Prevention of Terrorism lathe users register and to use it as an excuse to inspect every room in your home That's just nonsense.
Pete |
28/10/2015 14:49:16 |
Posted by John McNamara on 28/10/2015 14:05:16:
More worrying is part of the proposal ropes in any person that possess a tool or machine that is used or intended to be used in the manufacture a prohibited firearm or part of a prohibited firearm. Similar terms of imprisonment will apply? (Registered Gunsmiths and Manufacturers excluded).
It's only worrying if you are making illegal firearms. You can be prosecuted for possession of an offensive weapon if you have a screwdriver, but I don't suppose for a moment that you've ever worried about that.
Pete |
Thread: Myford lathe values. |
21/10/2015 15:49:48 |
Heads up, chaps! Anyone on here owe Mark P any money?
Pete |
Thread: What did you do today (2015) |
30/09/2015 15:34:38 |
Posted by Neil Wyatt on 30/09/2015 14:33:45:
It is simpler for me to just click delete on anything that might be inappropriate, rather than get into a detailed and fruitless debate of whether or not a particular posting does or does not cross a line. Given that I already spend far more time on forum issues than I should, from this post onwards I'm going to take that arbitrary approach. Neil Absolutely right. If anyone disagrees with that approach, they are free to go elsewhere.
Pete |
22/09/2015 16:50:53 |
You could look further afield for short MT1 tooling. Sherline do some, but you will have to poke through their accessories catalogue item by item to find them. Their lathe has a MT1 taper in the headstock. Also Manix (formerly Toyo) ML-210, with short tapers in head and tailstock. They do centres and a drill chuck at least. If you gain some skill at turning, you will be able to make your own. I make all my short MT1 and MT0 tapers myself. It's not as daunting as you might think, although you will probably need to develop a little more skill and confidence before you have a go.
Pete Edited By Peter Hall on 22/09/2015 16:53:27 |
21/09/2015 10:57:26 |
And oil the screws. |
16/09/2015 18:39:35 |
Don't get sidetracked by the Sherline. They're nice, but expensive for you and very small. Concentrate on using your existing lathe to produce good results and you can always trade up later. Everything you learn from your current difficulties will be useful later on. Persevere. Don't be tempted to buy another lathe because yours "doesn't work properly". It will be possible to make it work properly, but you badly need some help from someone else who knows what they are doing. Tap up Hopper, or, frankly, anyone else you can find in the area who has some experience. If you reach out locally I'm sure you will find some like-minded souls who will be pleased to help you along. Good luck!
Pete |
16/09/2015 18:26:40 |
Posted by Brian John on 16/09/2015 18:17:47:
The man has a Sherline and a Sieg C4
That's why I thought it might be interesting to you. He's producing stunning work on essentially low-end equipment. No Swiss machinery costing tens of thousands. Just looks like a slow, deliberate approach and an understanding of exactly what he is doing. Lovely stuff.
Pete
16/09/2015 16:12:17 |
This chap lives and works in Cairns. http://www.clickspringprojects.com/ . He admits to picking the brains of other machinists and clockmakers, so he may answer a few of your questions if you ask nicely. I haven't looked closely yet but he seems to have some very helpful stuff on his blog.
Pete |
Thread: Probably needs new bearings but should I paint it - giggle |
15/09/2015 21:28:54 |
One mature Lady owner. Never been further than Margate. They don't make them like this anymore. Some service history. Easy maintenance. No accident damage. A quick polish and it'll be good as new. 37 point inspection. When it's gone it's gone. A sound proposition for the discerning purchaser, as God is my witness, Squire.
Pete Edited By Peter Hall on 15/09/2015 21:29:45 Edited By Peter Hall on 15/09/2015 21:30:28 |
Thread: X1 Mill lifting mechanism |
10/09/2015 20:50:32 |
Yes. I did the X and Y axis bearings to Graham Meek's design.
Pete |
10/09/2015 20:38:36 |
I have 2 X1 mills. I have not done any of the mods you ask about, but I did install a thrust bearing on the rise and fall screw. Still needs tedious multirotation, but essentially removes all effort in turning the wheel, so makes it fast and easy. Did the same to the x and y axes too, with similarly happy results. I can't remember exactly how I did it now, but if you're interested I will try dredging through what passes for my memory these days and give you a how-to.
Pete |
Thread: The ultimate easy home workshop |
10/09/2015 20:22:24 |
Posted by Clive Hartland on 10/09/2015 17:19:10:
Keeping track of the items was hard as other engineers borrowed them and forgot to bring them back.
No! Surely not. You must be mistaken. I can't believe any engineer would do such a thing.
Pete |
