Here is a list of all the postings Circlip has made in our forums. Click on a thread name to jump to the thread.
Thread: Winding electrical coils |
22/05/2010 15:10:25 |
Ideally you need a coil winder, cos the wire goes through a series of tension rollers (Similar in operation to a sewing machine thread feed) and it is then fed by the forward and reverse mechanism similar to a lathe leadscrew laying onto the former. (Don't arsk).
Regards Ian. Edited By Circlip on 22/05/2010 15:11:10 |
Thread: Code of Conduct |
22/05/2010 14:13:42 |
I think it's very refined
"Please refrain from:"
Not the exact words I would have used (Although meaning the same thing).
Regards Ian. |
Thread: Heat in engine room in model boat.. |
22/05/2010 14:08:39 |
Ceramic paper, about 3mm thick, cuts with a knife, or even scissors.
Regards Ian. |
Thread: ED Racer 'times two' |
22/05/2010 12:33:46 |
Yippeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Regards Ian.
Just cut it down a bit in case I get Conductified
Edited By Circlip on 22/05/2010 12:39:48 Edited By Circlip on 22/05/2010 12:40:38 |
Thread: Digital editions of Model Engineer and Model Engineers' Workshop. |
22/05/2010 12:17:06 |
My question to Model Engineering department is as they appear to be same company as Model Boats (No doubt I will be corrected if wrong) why does the model boat site still have the flexipage reader for their digital archives which gives you the better quality print. " Because they haven't got round to changing the Muddle Boat site yet TomK
Regards Ian Edited By Circlip on 22/05/2010 12:17:28 |
Thread: Box for Rotary Table |
21/05/2010 16:25:37 |
Ceder was/is used as a lining material to stop morfs from eatin yer clothes so it will be ideal to stop the rust moffs from eatin yer tools.
Regards Ian. |
Thread: securing a facing cutter on an arbour |
21/05/2010 09:37:50 |
Sent a reply yesterday at 10.59.17am to the Yahoo address you gave me, re-forwarded today (Friday) at 08.33.18 to same address, perhaps you got the M/E server disease??
Regards antother Ian. ![]() |
20/05/2010 13:07:15 |
You could also run a "Pressurised system Jens Eirik, A 5v or 12v CPU (Computer) fan to suck IN cool air and let it vent through the doors/windows/vents. If you try to use it to extract, it would probably melt the fan or dry the bearings in it out.
Regards Ian. |
Thread: Diesel fuel |
20/05/2010 13:01:33 |
Hard to belive there ain't no Hospitals in France Robert OR schools with chemistry labs. Bet they know where to buy Ether.
Regards Ian. Edited By Circlip on 20/05/2010 13:01:55 |
Thread: Anodising |
20/05/2010 12:56:08 |
Would also like to know how close in chemistry "Parkers Green Ink" is to the inkjet printer inks??
Regards Ian. |
Thread: Guidance on turning in a vertical mill |
20/05/2010 12:43:50 |
That's a new shaped wheel, Mill to lathe, wonder if a toolholder is cheaper than a vertical slide??
![]() Regards Ian. Edited By Circlip on 20/05/2010 12:46:06 |
20/05/2010 12:34:07 |
Well DC1, I NEARLY bought a subscription for the MEW archives, but have now been steered away. Still think DVDs are the way to go.
Regards Ian. |
Thread: Boiler making hearth |
18/05/2010 12:19:42 |
Good to see you teaching the collonials how to make a boiler Stewart, only things to remember, correct clearences, good flux and clean metal for Silver Soldering.
Regards Ian. |
18/05/2010 12:05:18 |
Yes Steve, but it shows it FASTER.
![]() Regards Ian.
Do the paid for Digital archives print in grey shades or is it just the mag subscription freebies????? Edited By Circlip on 18/05/2010 12:07:26 |
18/05/2010 11:50:30 |
Mill a couple of round ended pockets into the sides of the larger diameter of the arbour and let in a couple of pegs retained with C/S allen screws. Similar effect to JasonBs post but the drive is on a flat surface.
Send yer E-mail via P/M
Regards Ian. |
Thread: How close can I get? Indexable turning inserts.... |
15/05/2010 15:50:55 |
So if you're going to tap the nuts, why not pay a fiver for a die from Tracy Tools?? It was to make 30? Not forgotton any noughts?
Regards Ian. Edited By Circlip on 15/05/2010 15:53:07 |
Thread: Trouble turning brass by a very inexperienced engineer |
13/05/2010 14:32:47 |
What is the swarf like?? turnings or fine needles ??
Regards Ian. |
Thread: collet chuck for the lathe |
13/05/2010 14:16:39 |
Swimming against the flow by making it Roy, what you gonna buy the Missis with what you saved ???
![]() Regards Ian
(There's method in the above statement cos when the oven is hot after the Sunday roast, it wont take long to "Blue" it ) |
Thread: drill sharpening |
12/05/2010 12:01:21 |
Luv it Terry, wish DC1 would stop modding your long
links and get the web design whiz kids to sort it
properly.
Regards Ian
7th Jan & 4th Feb 94
16th Aug & 20th Sept 96
2 sets of articles in ME by D.A.G. Brown on 4 & 6 Facet grinding
You got a PM David Lockwood
Edited By Circlip on 12/05/2010 12:15:55 Edited By Circlip on 12/05/2010 12:20:55 |
Thread: Well done at the Harrogate show - fantastic result |
11/05/2010 11:26:37 |
Was the Rail Gun on the centre ?? table with the pair of Goblins??
Regards Ian. |
