Member postings for Russell Eberhardt
Here is a list of all the postings Russell Eberhardt has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford ML7R
29/05/2013 14:45:31
Posted by Hopper on 29/05/2013 11:43:34:Get yourself a copy of LH Sparey's "The Amateurs Lathe" and "How to Run a Lathe" by Southbend Lathe Co and you will have enough info keep you busy the first year or three.
Perhaps easier to find: "Lathework - A Complete Course" by Harold Hall.
Russell.
Thread: Winson GWR1400
29/05/2013 11:43:18
Have a look on here
Russell.
Thread: What milling machine?
29/05/2013 07:51:26
Posted by Andrew Evans on 28/05/2013 23:46:52:
Disadvantages are that if you want to do a very simple one off task you have to boot up your PC first.
55 seconds to boot into LinuxCNC or 70 seconds to boot into WindowsXP/Mach3 and that's on an old second hand machine. If that's too long leave your PC in standby.
Don't connect the PC to the internet. If it works it never needs security updates so no checking for updates, no virus scanner needed as you won't get a virus, so very little overhead.
Russell.
Thread: Hard felt alternatives for wipers?
28/05/2013 19:58:29
Posted by Bazyle on 28/05/2013 16:31:00:
Mercury was only used to add a glisten to the knap of top hats as a finishing process, not as part of felt making.
.. and in "carroting" a process that removed fur from pelts before making it into felt.
Russell.
Thread: Why won't this work...or will it?
28/05/2013 19:54:31
Inertial navigation systems are used on fighter aircraft and missiles they use acceleration sensors, integrating the acceleration to get velocity and integrating the velocity to get position. These systems respond quickly but need input from GPS to correct the position frequently.
It would only take a tiny error in the measurement and maths for the system to think it's moving when in fact it is not. A similar error will occur when moving at a constant velocity. The error would then accumulate over time. Even with frequent homing, the errors would be much too great.
A typical chip (ADXL362) has a resolution of 1 mg on the 2g scale. That's one part in 2000 and the error will be much more as the nonlinearity is up to 0.5%. Remember that's just the acceleration not the position.
Good luck if you're going to try it!
Russell.
28/05/2013 14:40:54
Unfortunately they use acceleration sensors rather than distance sensors. In principle, if you could measure the acceleration vs. time accurately enough and performed a double integral you could get a measure of distance but in practice the errors would be enormous.
Russell.
28/05/2013 10:21:51
Posted by Bazyle on 27/05/2013 17:13:51:
DIY it. Any old moth eaten bit of genuine wool jumper or sock stuck in the washing machine with every wash for a month will shrink down ot a nice bit of felt. Useful for polishing cloth too.
I thought you had to put it in a bucket of urine and stamp on it for a few hours - not tried it myselflaugh
Russell.
Thread: Milling machine spring assist lever failure
28/05/2013 10:14:54
Posted by Stub Mandrel on 27/05/2013 18:39:53:My microwave interferometer of course. Don't you have one?
Not good enough. For 25 nm resolution you would have to use an Extreme UV or X-ray interferometersmiley
Russell.
28/05/2013 08:01:40
Posted by rebekah anderson on 28/05/2013 00:01:22:I really wish i could do CNC, i'm trying to convert my X2 but to be fair, I'm pretty pants at it so i need to start from scratch again.
A thread on my (S)X2 conversion is here if it's any help.
Russell.
27/05/2013 15:24:40
Posted by Bazyle on 27/05/2013 14:55:29:
What size is the hole?
12 mm. I still have all the bits I took off the SX2P mill when I converted it to CNC. They are in the "might come in useful some day" box.smiley
Russell.
27/05/2013 15:15:19
Posted by IanT on 27/05/2013 09:21:14:
The Atlas has this two layer approach - felt "oilers" and plastic wipers in front of them - so Atlas obviously thought this was advantageous.
My Atlas lathe had rubber and felt wipers when purchased in the 1970s. The rubber wipers had degraded somewhat with the oil so I replaced them with a synthetic rubber (butyl rubber I think) and they are still in use. Perhaps it's time I made a new set!
Russell.
27/05/2013 07:53:35
I strongly suspect that these felt pads won't last long with all the oil and crud. Did you see my earlier post?
Russell.
26/05/2013 21:42:10
I just removed the spring assist on my X2 mill. I think it is only useful if you are using it as a bench drill. For milling it is superflous.
Russell.
26/05/2013 21:38:32
Buy the real thing. Genuine oil seal felt in small quantities here: **LINK**
No connection but I've bought from them in the past.
Russell.
Thread: Cost of Raw Materials
21/05/2013 10:14:56
Posted by Wannabewelder on 20/05/2013 13:04:05:
Hi guys (incidentally, are there any female model engineers?)
Yes, If you want to see the standard of work done by a female model engineer, have a look at the front cover of Model Engineer no.4366. (In digital editions).
Russell.
Thread: Forum Posts Published in Model Engineer
21/05/2013 10:05:41
Posted by Graham Meek on 21/05/2013 09:53:08:
I would have thought it would be only a common courtesy and good business practice to at least approach the "Originator" as regards the intention to publish.
Agreed. Unfortunately "courtesy" seems to be a rather forgotten thing these days.
Russell - in grumpy old man mode.
20/05/2013 11:24:43
Wasn't there a time when they used to pay for any letters they published? ... or was that another magazine?
Russell.
Thread: lidl arc welder- opinions please
15/05/2013 16:53:53
As a first welder I would go for an inverter one if you can afford it. Much easier to strike the arc and it won't damage your back lifting it!
Russell.
Thread: ARC absence from Harrogate Show
09/05/2013 15:21:00
Posted by Les Jones 1 on 09/05/2013 14:22:22:
I remember going to Proops shop in Tottenham Court Road in the 1960's
Yes, and the government surplus shops in Lisle street. Different sort of shops there now!
Russell.
Thread: New subscriber from France
07/05/2013 07:43:17
Bonjour et bienvenu.
Russell (Dept. 66)
