Here is a list of all the postings Bo'sun has made in our forums. Click on a thread name to jump to the thread.
Thread: Shims |
28/12/2021 11:51:44 |
All the usual suspects. Spent hacksaw blades, steel banding from pallet shipments, scrap sheet metal, etc. |
Thread: New mini mill or use lathe as a mill.? |
27/12/2021 10:24:10 |
I've used a milling slide on my WM250 with good success. But the swapping things around, only to find out that you realy should have completed one more operation before swapping back, convinced me to buy a benchtop mill. Other considerations with a milling slide attachment are lack of travel and general visibility. |
Thread: Blank Tee Nuts. |
25/12/2021 15:49:20 |
Thanks Jason. |
24/12/2021 11:07:55 |
As they say, the simple solutions are sometimes the best. "Can't see the wood for the trees" and all that. I should get enough threads for M6. Thanks Dave. |
24/12/2021 10:48:59 |
HI ndiy, By blank I meant with no hole, so I could drill and tap for an M6 stud. |
24/12/2021 10:18:20 |
Good morning, Yes, I know I can make them, but I'd rather be model making than tool making. I want to use an M6 clamping stud in a M8 tee nut. I had considered loctiting a piece of M8 stud in the tee nut and re-taping it M6, but with an M8 core dia of 6.5mm, I thought it would be a bit too close. So, can I buy M8 blank tee nuts? |
Thread: warco 16 b advice |
20/12/2021 15:45:54 |
Thank you JD2. |
20/12/2021 11:03:29 |
Good morning Stuart, I have just taken delivery of a new WM16B and wish to fit a DRO. However, the base is a square shape rather than the tapered shape of Warco's other similar machines. Although Warco's website offers the WM16B with a DRO, their guide to fitting a DRO only shows the Y axis encoder on a tapered base. I'm waiting a reply from Warco about the Y axis DRO on a WM16B. Hope this makes sense. |
Thread: Mamod Locomotive Rebuild |
20/12/2021 10:00:15 |
Posted by Chris Evans 6 on 20/12/2021 09:11:19:
Welcome William, your post prompts the question are Mamod still trading ? They used to be made in Burntwood West Midlands not far from me. I have a Mamod stationery engine that has not steamed for many years. Chris. I'd be surprised if Mamod are still trading. Children with fire and burny stuff. Perish the thought! I look forward to seeing the completed rebuild William. |
Thread: Machining Plastic |
15/12/2021 09:20:53 |
At our Scout Campsite we used a sliding chop saw with a blade with the least amount teeth we could find, slow feed and a little WD40 to cut 150mm x 50mm recycled plastic to make some benches. I think the large tooth gullet stopped the blade binding and getting too hot. Hope this helps. |
Thread: Free Cutting Mild Steel Flat |
10/12/2021 16:55:49 |
Thank you Thor, That's just the sort of thing I had in mind. Just need to get my head around the "% machinability index".
10/12/2021 14:46:08 |
While vaguely relating to this thread, has anyone come across a "succinct" comparison chart of commonly used steels in model engineering with EN numbers, properties, machinability, etc, and cross reference to current specification numbers. |
Thread: a gluing quandry |
07/12/2021 08:26:21 |
Andrew Whale (Learning Turning Metal) often uses superglue to good effect for temporarily holding small parts. Clean, well fitting joints with the largest surface area you can is the key. |
Thread: Silver solder resist |
07/12/2021 08:20:54 |
Best stock up on it, typewriters are probably a thing of the past. |
Thread: Perfect Stainless |
02/12/2021 12:30:34 |
Posted by Bob Stevenson on 02/12/2021 12:13:42:
The first maker was Herberts and in 2013 the centenary was celebrated by the Swedish owner of Herbert's business who made some ingots of SS with the union jack pattern thru the bar when it was cut. More correctly the "Union Flag" I believe. |
Thread: Steel banding. |
01/12/2021 09:10:07 |
Thank you all, It cuts easily with Gilbow tin snips, so I'll treat it as a relatively low carbon steel for small brackets and shims, etc. You're probably right old mart, the blueing is likely only there to give some corrosion resistance while it's in storage and then in transit. |
30/11/2021 19:32:50 |
I've saved some steel banding (minus the bent and mangled bits) from a couple of machine tools I've had delivered. It seemed a shame to throw it away. I've heard it mentioned as being "spring steel". Is that true? I guess there's different grades depending on it's use |
Thread: Filing Technique |
30/11/2021 16:47:03 |
Posted by Andy Stopford on 27/11/2021 20:04:26:
Of course, once you know, it seems reasonable that dragging the file back increases wear on it's teeth - but is it true? This guy decided to find out: https://www.youtube.com/watch?v=52d0TmmQ5yI Aside from attempting to answer the question, its a nice demonstration that you can use a shaper to do all sorts of things it's manufacturers never intended (when I had one, it occasionally did duty as a tool and cutter grinder for horizontal milling cutters). An interesting video Andy, although it did go on a bit and was perhaps a little over the top. But some surprising results none the less. |
Thread: Stand for WM16B Milling Machine |
25/11/2021 13:08:32 |
Thank you Derek, It looks like you have the WM18 mill. Not that it makes any difference, because I suspect all of the tables will end up at the same height. |
25/11/2021 11:43:40 |
Thank you John & Dave, some food for thought. I'll go and have a twiddle in the privacy of my workshop. |
