Here is a list of all the postings AJAX has made in our forums. Click on a thread name to jump to the thread.
Thread: Rebuilding car trailer and welding/bolting galvanized frame |
27/07/2021 11:05:57 |
Posted by ega on 27/07/2021 09:40:14:
Has the use of a suitable mask as a precaution against fumes been mentioned? I think a mask to the FFP3 standard would be suitable. I don't think that would help, would it? I have FFP3 masks and filters for particulates and vapours, but they won't filter the gas. |
27/07/2021 11:04:35 |
Posted by Kiwi Bloke on 27/07/2021 02:11:19:
Go ahead and weld (with precautions as above), fabricate in MS, and send the job to the galvanizers - better than spray-on Zn-rich paint. I rather suspect that would make it an expensive build. My other trailer (now almost 50 years old) seems to have done okay without a zinc coating. |
27/07/2021 11:03:23 |
Posted by Grindstone Cowboy on 26/07/2021 23:21:21:
I'd say galvanised fixings and fittings are to be preferred, but most importantly, if you are welding to the galvanised chassis, be sure to grind off the zinc coating for a good few inches around the weld area as zinc fumes are poisonous. Probably OK if outdoors with a bit of wind, but be careful. As a finish, one of the so-called "cold-galvanising" sprays would do, or just a good primer and suitable paint - but that way you'll probably end up painting the whole thing. Rob Based on some of the comments here, plus what I've now read online, I will probably opt for mechanical fixings rather than weld anything on. I remember gas-cutting galvanized tubing in a milking parlour as a young man, and I'm still alive today, not to say that is an endorsement of the practice! |
26/07/2021 23:08:50 |
I have the chassis of an old trailer tent that I intend to re-purpose as a multi-functional trailer for my own use. The chassis is in good condition and is mostly constructed from U-section galvanized steel. All my previous fabrication projects have used plain mild steel. Some of my modifications / add-ons will require securing to the chassis. Can I bolt and/or weld mild steel fabrications to the chassis or will this be problematic? I'm thinking of various connectors for removable sides, mudguard supports, ladder/kayak rack, tie down points, etc. I would also like to reinforce the frame in a couple of places. I presume it's good practice to grind off any galvanized first when welding, but please correct me if I am wrong. If I do weld mild steel to the galvanized frame, what finish should be applied? Would it be okay to fabricate some parts from mild steel, apply an appropriate paint, and then bolt to the galvanized steel frame? In this situation, are galvanized fixings required or preferred? I should probably mention the trailer will be stored outside covered by a tarpaulin. |
Thread: AA batteries |
26/07/2021 22:44:19 |
Posted by Clive Hartland on 26/07/2021 22:00:37:
I recently bought some AA batteries, a box of 40. Needing to change the batteries in the house fone I tipped out the old ones and inserted the new fresh ones but found that the + contact did not reache the contact in the battery holder. I am convinced that the new batteries + end is shorter than it should be. I will now have to commit surgery on the battery box to cut away part of it to allow full contact. The batteries came from a reputable supplier. Was that a BT cordless phone by any chance? I had exactly the same problem when I changed batteries but when I prised the spring clips out a bit it was enough to make good contact. Alternatively I could have bought the BT approved/branded replacements instead at an inflated price. Update - my phone uses AAA and not AA batteries. |
Thread: Couple of things at Lidl |
18/05/2021 21:31:34 |
Posted by Mike Poole on 18/05/2021 14:09:19:
It always surprises me that angle grinders get away with a switch that locks on, if you drop the machine it could chase you round the workshop before you can pull the plug, my ELU router is equipped with a slide switch which again could be trouble. The router is often used in a table so the lock switch is justifiable but an angle grinder is rarely a fixed tool unless used in a chop saw type accessory. Pistol drills seem to make the trigger lockable as required. Mike I have the impression, perhaps incorrectly, the lock-on type switch is banned in the USA. I dropped an angle grinder fitted with a knotted wire brush once. Switch was locked on. Now that was "fun". |
Thread: Hand cleaner |
11/05/2021 20:32:53 |
The thing I like about swarfega is I can use it in the workshop without access to a sink and wipe my hands fairly clean and dry before returning to the house where I can wash them properly without making the sink filthy. |
11/05/2021 20:30:26 |
Posted by Gas_mantle. on 21/06/2015 11:47:06:
I always use washing up liquid too and find it works fine. I read somewhere that shampoo is basically just scented washing up liquid, that was 40+ years ago and I still wash my hair in the stuff without any probs after all this time. Must have saved a fortune in shampoo. Well I used shampoo and now don't have any hair. Who is making the greatest savings? |
Thread: Failed to get this digital clock kit working :( |
09/05/2021 19:23:00 |
Posted by SillyOldDuffer on 08/05/2021 16:52:23:
Reading the reviews I see a few people complain about board quality - tracks lifting off with heat, and broken tracks that had to be bridged. Check the tracks carefully with the microscope and for continuity with a multimeter, or - much better an oscilloscope, see below. Tracks lifting off with heat - sounds like a typical problem with beginner soldering to me. |
09/05/2021 19:18:50 |
Posted by Peter Greene on 09/05/2021 18:49:39:
Posted by SillyOldDuffer on 09/05/2021 17:07:21:
Have you checked S1 and S2 are correctly inserted? If those switches are inserted 90° out, the switch inside is bypassed, and the circuit is permanently ON. Is that how they work? Pretty poor design of switch then with pins at the corners of a square and no apparent keying, physical or visual. I'd have assumed they were spst with all 4 contacts shorted when pressed and open-circuit when released .... but I don't know for sure. The switches are square, but the pin layout is not. It's therefore generally difficult to place them incorrectly in a PCB. |
09/05/2021 19:15:48 |
Posted by Mike Poole on 09/05/2021 19:00:56:
The switches are not quite square but at 6mm x 6.5mm they are close, the components on my effort are all correctly oriented but it doesn’t work. As it cost me very little I am struggling to generate the enthusiasm to investigate the problem. Mike Mike, I sketched this for you - I hope it helps. Bear in mind that even a "failed project" is not a waste of time. It's all a learning experience. |
Thread: Problem with 4 jaw chuck |
14/04/2021 10:08:20 |
Another thing I should mention is the jaws are numbered 1, 2, 3 and 4. The chuck is similarly marked with centre-punched dots. |
14/04/2021 10:06:58 |
I have an independent 4 jaw chuck sitting on my workbench not being used. It looks vintage and has no maker's name. The jaws "fit" and appear to be from a set (all marked 171) but I am unable to say if they are original. The problem with this chuck is the jaws do not close parallel with each other. A superficial glance suggests bell-mouthing through wear but on closer inspection the inner faces of the chuck jaws show they are in excellent condition - they still show the original machining. The "slides" in the chuck body look good as do the screws. The jaws have minimal slop in their respective slides. I could make a ring to hold all 4 jaws in position and then grind their internal faces. I have previously done this with a 3 jaw scroll chuck but never needed nor thought I would need to do this with an independent chuck. Any suggestions before I attempt a fix? |
Thread: Roland CNC engraving / milling machine and 32-bit driver |
12/04/2021 20:57:31 |
Posted by SillyOldDuffer on 12/04/2021 16:00:07:
Posted by AJAX on 12/04/2021 13:30:24:... Windows 7 is available to download from Microsoft with a suitable product / licence code which I do not have. There is no option to purchase a code from Microsoft. Basically, I need to install Windows 7 (32 bit), perform the firmware update, and then remove Windows 7. I'd rather not purchase some fake codes from eBay. Any suggestions? You might try the keys from this website. They appear to be free and the site isn't on any of my blacklists, but approach with caution. Nothing guaranteed. The website is also informative about the other ways keys can be obtained. Interesting that Microsoft allow W7 to be downloaded but not activated as a new product even though that might be profitable. I guess it's because they don't want to get into arguments: 'I bought this new yesterday and it doesn't work'. The support is contractually limited to whatever the original key came with, which today might be none. Dave I'd rather not use one of those dodgy websites. I'll see if I can find someone with an old licence code they are no longer using. If it works, I'll only use it once then delete the o/s anyway. |
12/04/2021 20:47:42 |
Posted by JasonB on 12/04/2021 13:51:55:
Run it off a cheap recon XP machine from Ebay as quite a few Mach3 users do. Just do your CAD & CAM on an up to date machine and transfer the file to the XP with a USB stick. I already have a cheap machine running XP, but I was hoping to use something more up to date. I'm also interested in seeing if I can run a firmware update, but to do that it seems that I need Windows 7, maybe. |
12/04/2021 20:42:22 |
Posted by Dominic Watson on 12/04/2021 13:47:21:
I have a similar Roland (TS400 I believe) for which I ran a ‘virtual machine’ with xp or 2000 or something running on a more modern operating system (Apples OSX interestingly). So you could run windows 7 on your newer OS (within a virtual machine) and install the firmware that way. I think the virtual machine software I used was either VirtualBox or Parallels but this is going back a little while so I can’t quite remember. That's an idea. Something I should have thought about myself. I wonder if the virtual xp will have access to the USB port for printing. I may give it a try. |
12/04/2021 13:30:24 |
I have acquired a very nice Roland CNC engraving / milling machine that is in mint condition and works without fault. It is maybe 15 years old. I have the CAD/CAM software and a 32 bit driver but am currently limited to using Windows XP only. The driver is Win XP / Vista / Windows 7 compatible and I have instructions from the reseller to install on a 64 bit operating system (the instructions, unfortunately, do not work at present). Elsewhere on the internet I have found instructions to perform a firmware update to a fully 64-bit system but the update appears to require Windows 7. I am presently stuck using Windows XP (because I have a copy) and cannot progress to using Windows 10 (which I have running and licenced on more than one machine). Windows 7 is available to download from Microsoft with a suitable product / licence code which I do not have. There is no option to purchase a code from Microsoft. Basically, I need to install Windows 7 (32 bit), perform the firmware update, and then remove Windows 7. I'd rather not purchase some fake codes from eBay. Any suggestions? |
Thread: MS 'Edge' - Points and Pitfalls? |
09/04/2021 19:19:08 |
NetScape Navigator anyone?
But seriously, Edge or Chrome should be just fine. Whichever one you are using, select your preferred search engine rather that accept a default. |
Thread: Boxford Model C leadscrew half-nuts |
07/04/2021 08:17:57 |
Posted by old mart on 06/04/2021 20:52:55:
Posted by Speedy Builder5 on 05/04/2021 19:43:45:
Not suggesting you buy these, but it shows re-threaded Southbend nuts I looked carefully at the advert and was confused. There was mention of the nuts being original, but the threads looked like steel inlays. The seller should have cleaned the muck out of the threads, though, before taking the photo's. The threads looked like they were inserts brazed in. Not to worry anyway as all fixed for now, and if I decide to replace it may be with new imports from Oz. |
Thread: All the gear, no idea |
07/04/2021 08:15:13 |
If using eBay to judge prices, make sure that you refer to some prices and not unrealistically high asking or best offer prices. Good luck. |
