Thread: Rubbish Milling Finish in Aluminium |
28/03/2021 19:41:32 |
As already mentioned, that cutter looks blunt. New threaded shank cutters are easy to get hold of, but beware, metric sizes need metric collets and inch sizes need inch collets. Keep the new sharp ones exclusively for non ferrous metals. Edited By old mart on 28/03/2021 19:43:34 |
Thread: Little nuts.......big fingers. |
28/03/2021 19:34:43 |
I have big arthritic fingers, and when I modified the new 100mm four jaw chuck to fit my 7 X 12 lathe, I turned the first few threads off the mounting bolts to make life easier.
Thread: There may be a delay in some deliveries ... |
27/03/2021 20:13:36 |
Posted by Michael Gilligan on 27/03/2021 19:49:58:
Interesting update [with some great images] from the New York Times: **LINK** https://www.nytimes.com/live/2021/03/27/world/suez-canal-stuck-ship MichaelG. That is the best link so far, Michael. I notice they are hoping for an 18" increase in water level with the spring tide. Between now and Tuesday, the increase here will be 47", but I live next to the Bristol Channel. This spring high will be 12.7 metres, my house is at 6 metres. Edited By old mart on 27/03/2021 20:14:03 |
Thread: Removing a J2 arbor from a drill chuck |
27/03/2021 19:54:35 |
If you end up deciding to leave the chuck and arbor together, there are R8 adaptors for tanged MT2 chucks. We have one chuck still with its MT2 taper which can be used in the lathe tailstock as well as the mills. |
Thread: Excellent Chinese Chuck |
27/03/2021 19:44:48 |
Posted by peak4 on 27/03/2021 19:30:48:
It's unfortunate that (unless anyone knows better) that they don't seem to supply outside jaws with the 6 jaw chucks. Bill That is what tends to put me off buying one as well. In the USA, you can get the model with the two piece reversable jaws, I was shown a picture on the Home Shop Machinist forum. Edited By old mart on 27/03/2021 19:47:16 |
Thread: Griptru chucks |
27/03/2021 16:15:47 |
Soft jaws are the best way to hold work perfectly and without risking marking the work. |
27/03/2021 16:08:32 |
Some of the reports on the web were incorrect as to the location, it is a shame that the southern bit has not yet been dualled, this will certainly get another new section cut very soon. The ship is only a few miles north of the entrance from the Red Sea. Edited By old mart on 27/03/2021 16:10:08 |
Thread: Milling Aluminium |
27/03/2021 16:01:24 |
You would get the best use by keeping the really sharp cutters exclusively for aluminium and never using them on steel. A lubricant used sparingly is essential to keep the aluminium from sticking to the edges. Always put something soft under the tool when changing cutters as a drop onto the bed, or floor can chip the ends. Chipped carbide cutters will still cut quite well and can be used for roughing. |
Thread: New mill vice which one |
27/03/2021 15:51:44 |
That 100mm vise is about as big as you would want on the TS bed. Having an infinitely adjustable position for clamping means there is no loss of Y axis movement, and the double clamping is a bonus. The flat column on the TS makes it easy to use a mag base with an indicator to get the vise aligned. I would rough align it first with a tri square before fitting the clamps on one side. |
27/03/2021 15:39:52 |
One of the chucks at the museum is a Huhhot Chinese 125mm which is very good indeed, it dates from 2003, I still have the test certificate. The Chinese four jaw independent 160mm which I bought for the museum was only £50 and it works, but the jaw fits are rather loose. I bought a couple of the Sanou chucks for my 7 X 12 Warco mini lathe, an 80mm three jaw scroll, and a 100mm four jaw independent. The 100mm had to be modified to fit the spindle. They are both superior to the original chucks for the lathe.
26/03/2021 21:44:46 |
Griptru chucks are intended for use in a production enviroment. If there are large quantities of identical workpieces, a three jaw scroll saves time and the fine adjustability at the start of the run is a great advantage. Each batch may be a different size, but can be zeroed in perfectly. A four jaw independent can be dialed in just as accurately, but even if two adjacent jaws are loosened each time, the repeatability is not guaranteed unless it is checked. The cost of this type is double that of their standard chucks. PB is the only type using three adjustment screws, the other makes use four, and there have been comments made on other forums that trimming four is much easier. Edited By old mart on 26/03/2021 21:47:02 |
Thread: LG TV ... updated webOS |
26/03/2021 20:41:55 |
I have a Toshiba smart tv and never have any problems with it, it is only used with the dvd player and the Virgin cable tv box. |
Thread: New member, N. Gloucestershire. |
26/03/2021 19:09:38 |
Welcome, Paul, there are some very useful books to help you get on the right track, which the more knowledgable amongst us will be able to recommend. |
Thread: Steel Rule Graduations Re-Blacking |
26/03/2021 19:06:20 |
If they were originally engraved, they would have been chemically blacked all over and then rubbed down leaving the black in the numbers and scales. There may not be enough depth to repeat the process. |
Thread: Fake or real |
26/03/2021 15:10:27 |
Mitutoyo have a plant in Andover, Hampshire, I don't know any more details. |
Thread: Low head Cap Screws |
26/03/2021 15:03:21 |
I believe that the socket size is still related to the thread diameter, for hexagon or torx, of a reduced size like when a countersunk end is used. The depth of the socket is less than a normal screw, which calls for added care when tightening. Edited By old mart on 26/03/2021 15:04:48 |
26/03/2021 14:59:07 |
Posted by Michael Gilligan on 25/03/2021 23:53:34:
Recent satellite photos : **LINK** https://www.space.com/stuck-ship-suez-canal-satellite-photos MichaelG. I was right all the time, and confused by the reports of the second channel being used. It wasn't, that channel is much further north. No wonder I thought that Google earth was out of date, it isn't, the ship is stuck near Suez. |
25/03/2021 20:20:41 |
Winds on the side of one of those ships could give very little time for anyone to keep the vessel lined up with the canal, even if the bowthrusters were used. It was a sandstorm that caused the grounding. I am surprised that incidents of this nature are not more common. Looking again at the map shown in the early posts, the ship seems to be located at the southern end of the canal. That is what fooled me, the doubled section is much further north. Edited By old mart on 25/03/2021 20:36:36 |
25/03/2021 17:55:56 |
You would think that GE imagery marked copyright 2021 would be up to date. |
25/03/2021 17:12:06 |
I have just been looking at the Google earth images of the southern part of the canal, they seem to be up to date. There is no sign of a alternate route. The sweetwater canal is 1/10 of the width with lots of low bridges, so that can't be the answer. Blow me, there is a new bit, the GE is out of date. https://earthobservatory.nasa.gov/images/87948/the-new-suez-canal Edited By old mart on 25/03/2021 17:16:35 |
