Thread: Threads that are steel and epoxy |
01/03/2022 21:35:17 |
A 3/8" drawbar would fit a MT2, I would guess, and to get enough diameter in the wall after boring central to take a helicoil, the length would have to be reduced. The helicoil would take up less room than a threaded bush. You would have to make a longer drawbar just for that arbor. It would be easier to bin the arbor and replace it. But be careful, most MT2 arbors have a 10mm thread in them. |
Thread: Lathe Tool |
27/02/2022 21:25:02 |
I mill down the 20mm tooling using a 50mm Ceratizit shell mill holding 5 round inserts of 10mm diameter. The steel of every tool from Sandvik, Kennametal, Seco, Korloy and the Chinese no names is very tough to machine, not too hard to file, but I have to rotate the inserts after 2 tools are milled. |
Thread: Number stamps quality. |
27/02/2022 21:04:15 |
Thread: 1.5 in x 8TPI nose thread (BSF) |
27/02/2022 20:56:48 |
If you do indeed need a Boxford backplate, they are easy to get from ebay in different diameters for finish machining to fit a chuck. If you can post the exact dimensions, length of thread, overall length to shoulder and the length and diameter of the register, it could be verified by Boxford owners. |
27/02/2022 19:57:50 |
Boxford most likely, the Atlas is the same nominal size, but uses unified thread form. |
Thread: tilting rotary table online purchase |
27/02/2022 17:00:04 |
I bought a Soba 6" which is a copy of the Vertex and it is ok since ditching the central needle roller bearing and turning up a bush out of aluminium to remove the unacceptable radial play. The aluminium is fine for a bearing considering the very slow speed of rotation. |
27/02/2022 16:27:04 |
I agree with Huub about the TCMT and DCMT style inserts, they have a 7 degree clearance angle and work better with small machines. The only disadvantage is that being single sided, they have fewer edges per insert. Edited By old mart on 27/02/2022 16:29:53 |
Thread: Santander on-line banking |
26/02/2022 20:59:59 |
No genuine firm will ask you to send them your log on details. |
Thread: Songs about Engineering |
26/02/2022 20:57:53 |
The first one that comes into my mind starts: I had a girl with a -------------------. |
26/02/2022 20:53:41 |
If the tool size is a problem, then look out for the WNMG 06 size inserts in a 12mm tool. |
26/02/2022 20:45:40 |
The Chinese made tooling and inserts are very good, I have many and those WNMG 08 are a common size, available in many grades, I have various steel, stainless and aluminium inserts. If you don't have a pile up and break the entire end off the insert, there will be 6 fresh cutting edges per insert. I get mine from ebay, but the Amazon ones will be identical. Edited By old mart on 26/02/2022 20:47:04 |
Thread: 1.2 mm Insert tip radius |
26/02/2022 20:31:46 |
Posted by Ron Laden on 26/02/2022 07:02:21:
Thanks Neil and Mart, The holder and inserts I got from APT unless I missed something the MRMN 1.5 rad inserts came as a minimum 10 off. I must admit I was a bit surprised that the smallest holder shank size is 16mm for these inserts I just assumed that the 8 x 10 shanked holder would be correct. To be fair APT were very good on seeing my order they emailed to point out that the holder wouldnt fit the inserts but it went into my junk mail and I missed it. I am going to try and modify the holder which will need the bottom seat lowering by 1.5mm using a carbide cutter I,m thinking it should cut ok. The seat is V shaped so after removing the 1.5mm, angle cuts each side should re-produce the V, well thats the thinking. The lathe at the museum has a tool height of 17.53mm and I buy 20mm tooling and just mill the 2.47mm off the bottom of the tool. No shims are required, so using 2 and 4 way toolposts is easy. I would steer clear of modifying the insert seat. |
25/02/2022 21:36:58 |
I can recomment APT they are very good and fast. For home shop people they have a common range of inserts available singly, so you can buy an assortment to test out rather than a box of 10 which might be unsuitable. They also sell carbide threading inserts singly if you only have one job for them. |
Thread: ZAY7045 ZX-45 Mill Coolant Floating Oil Catch Can |
25/02/2022 21:26:30 |
The smell of old coolant was the signal to replace it, and I wonder if the extreme dilution was to blame. I just use a Rocol soluble oil in small mixes at about 10% and have never had it go off. But I only use it in squeezy bottles, not a pumped system. |
25/02/2022 20:59:41 |
Most of the cnc mills where I worked collected the floating oil with a little mechanism that looked like a vertical belt sander. Just a slow moving rubber belt dipping into the tank, and a scraper to wipe off the oil and divert it into a small container for disposal. They ran all the time the machine was running. |
Thread: Mechanism with spiral spring |
25/02/2022 20:48:26 |
How about the mechanism design similar to the bass drum pedal in a drum kit. |
Thread: Inverter interference |
22/02/2022 21:02:43 |
I was worried about the leakage current from the filter causing the rcd's to trip, they are lower than domestic ones, but so far there has been no problem. |
Thread: How to make this? |
22/02/2022 15:34:47 |
Offsetting the tailstock might not be able to produce a steep enough taper, these adaptors are cheap as chips on ebay. |
22/02/2022 15:31:22 |
When I bought a Scneider VFD for the museum's Tom Senior light vertical, I had the advantage of being able to print out the quickstart guide from The Inverter Supermarket. Following this was easy and I paid strict attention to the screening of all the wiring, including remote controls and having a fully earthed metal box to house the inverter. This was in a different enviroment from a home installation and the strict adherance to the rules was necessary. So far it has caused no interference to mobile phones, radios or wifi, including 433Mhz remote controls. |
Thread: Releasing a corroded stud (steel) passing through a casting (aluminium) |
20/02/2022 20:57:50 |
If making one, I would play safe and not use very hard steel for fear of it breaking or loosing some teeth. You could get away with only 3 teeth and sharpen them frequently with a swiss file. Every couple of turns the saw would have to be withdrawn and cleaned or risk clogging and jamming. |
