Member postings for DC31k
Here is a list of all the postings DC31k has made in our forums. Click on a thread name to jump to the thread.
Thread: Metric Fine Threads
24/08/2023 19:10:56
To amplify Jason's point, for _any_ thread series (ISO metric, UN, Whitworth, BSCy, PG)* where a particular pitch is used on more than one diameter (so, really anything except BA), the depth of thread is only related to pitch and form (geometry).
In particular, it is independent of diameter. You can cut 1mm pitch on 6mm diameter or on 50mm diameter. The amount you plunge in is the same.
The only place diameter has an influence is when calculating helix angle, which determines the clearance angles required on the cutting tool (the M6 x 1.0 will have a much steeper helix to M50 x 1.0) .
* ISO metric and UN use identical forms, so really this is a list of four possiblities, not five.
Thread: Centec milling machine NT30 chuck.
23/08/2023 20:06:35
Rotagrip list one. The link is incomprehensible, so search for:
'slitting saw arbor 30 int rotagrip'
23/08/2023 16:59:54
Why do you need a special arbor for slitting saws? Do they not fit on the standard horizontal arbor? Or is it for use with the vertical head?
This might be a good place to start:
https://www.rdgtools.co.uk/acatalog/30-INTERNATIONAL-TO-1--FACE-MILL-ARBOUR-1040.html
It has a 1" spigot, that will suit many slitting saws. It has a key in it whch can be adapted or discarded. Remove and discard the drive dogs. All you need to make is a cap and some spacers (or buy the spacers or borrow them off the horizontal arbor).
You could buy a plain shank slitting saw arbor and mount it in a 30 taper ER32 collet chuck. Lots more bang for your buck that way. You can similarly make a 'plug in' full horizontal arbor to suit the ER32 chuck.
Thread: Warco GH1330 Lathe
23/08/2023 07:24:06
Posted by Andy Musgrove on 22/08/2023 23:09:02:
Should I buy a 3 phase machine and fit a VFD
As supplied from Warco, the machine will expect 415v three phase input. In other words, you put a red four or five pin socket on the cable and plug it in. At this stage, we do not know if it needs the neutral supply of the three phase.
Every part of the machine downsteam of the red plug will use the supply it provides. That includes all the control circuitry (E-stop, chuck guard switches, rear cover switch etc.), the light, the suds pump and maybe the DRO if fitted (Warco's site is not clear on if the DRO requires a separate supply or is supplied off the lathe).
The description for the machine says it already has a jog function so there is some unknown electronic wizardry going on there.
You do not say what type of VFD you wish to fit - one that takes 415v three phase input or one that takes 230v single phase input.
Everything is possible but to fit a VFD you will end up removing every part of the lathe that relates to its electric system and re-doing it. That might invalidate the warranty.
Thread: 12 x 2 lead screw
21/08/2023 17:25:55
Posted by Tim Stevens on 21/08/2023 15:28:30:
Has anyone every suggested adding a new 'lead-screw' to a lathe by using a wire wrapped around a drum to pull the carriage along (and back)?
The closest I have seen to that is the Trend router lathe, used for making spirals on sticks. I think Sears Craftsman in the US also made one (Router Crafter 720.25250) and manuals can be found at vintagemachinery
Thread: Warco WM250V : Tray Cleaning Questions
21/08/2023 17:21:17
Posted by Mick B1 on 21/08/2023 13:55:49:
I can screw an M20 x 1.5 thread several turns into the tray drain on my WM250V. If it was anything different I don't think I could do that.
If it is clearly a drain point, meant for coolant, the most likely thread is that used in conjunction with pipework, i.e. BSP.
M20 x 1.5 is a standard thread on electrical conduit, which generally is not used to carry liquids. That thread would be found on an electric motor, for a cable gland in the same way that a BSP thread would not be found on a motor.
M20 x 1.75 is extremely unlikly as 1.75mm pitch is not used anywhere in metric threads other than standard M12 coarse.
What I am saying is that the purpose of the thread can be a good pointer to its specification.
Thread: ER32 Extension
20/08/2023 21:51:48
I stumbled across these tonight and they are quite close in concept, if not size, to what the OP wanted two years ago.
A bit of diligent searching might find an ER32 one:
https://www.ebay.co.uk/itm/394745604793
Edit: sure anough, a bloke called Ali will send them to you by Express delivery.
The key search term is "transfer head adapter transition joint" £25.68 as of this date onto your UK doorstep for ER32 to ER32.
Edited By DC31k on 20/08/2023 21:57:30
Thread: Diacator made by Dietest
20/08/2023 17:20:15
Posted by Chris Mate on 20/08/2023 16:34:39:
That brings me to a point after some thought, one could use this tool straight in the boring head and let it swing from there
I might be misunderstanding you here, but I do not think that would work.
The typical 50mm boring head has two vertical holes in it for the tools. One of those holes would have to be set (adjusted) concentric with the boring head's axis of rotation in order for it to be used to house a co-axial indicator (or even a standard edge finder).
You could use a standard lever DTI in the manner you describe but not something where the dial always faces you and the mechanism rotates.
When you use the point of the tool to find centre as you describe above, it is always a constant distance from the rotation axis.
Thread: I particularly enjoy the recent Myford restoration articles
20/08/2023 13:36:34
Posted by Paul Taylor on 20/08/2023 11:20:15:
Can anyone tell me the number of teeth on the gearbox and idler gears please.
There are lots of Myford workshop manuals available for download from here:
http://vintagemachinery.org/mfgindex/detail.aspx?id=4654&tab=3
20/08/2023 09:32:51
A potential advantage of the co-ax indicator types used in a hole compared to a standard edge finder is that they will work at zero rpm. You can turn the spindle gently using one hand and see how the needle moves (even rotating it in discrete 90 degree increments if necessary). With an edge finder, it needs some powered rpm to see the wobble disappear and then observe the 'kick'.
With a co-ax indicator, finding centre is quite a smooth single operation. Poke in the hole and adjust until the needle does not move and zero everything. With an edge finder, there are four (maybe six) distinct actions that have to be coordinated with DRO button pressing.
Where a co-ax indicator might score is adjusting the height of a dividing head tailstock especially if you are setting it up to cut a taper.
Could we come up with something a co-ax can do that a standard indicator and a mirror cannot do?
Thread: Archer No.1 Reversing Tapping Chuck
18/08/2023 20:32:43
Posted by Ian McVickers on 18/08/2023 19:06:04:
I thought I saw a manual on this forum a while ago.
You did.
https://www.model-engineer.co.uk/forums/postings.asp?th=118853
Thread: Thread size on xd 3420 motor
18/08/2023 13:48:50
Bypass the thread conundrum entirely and Loctite the shaft extension on.
From the seller's pictures, I guess you are using it in a lawnmower or an abrasive chop saw. Those eBay Watts sure have increased in size since I was at school. Quite the opposite to a packet of polos.
Thread: INT40 Taper
17/08/2023 18:40:41
See:
https://www.tools-n-gizmos.com/specs/Tapers.html
https://www.cutwel.co.uk/blog/differences-between-bt-sk-iso-psc-hsk.html
https://en.wikipedia.org/wiki/Machine_taper#NMTB_taper_family
https://www.scribd.com/document/485098700/Machinery-Handbook-Standard-Tapers
https://cdn.standards.iteh.ai/samples/4226/0e63bb1e284e4782981af8c6506ed54f/ISO-297-1988.pdf
I do not think there is a formal standard for INT40 or its various synonyms (40 INT, 40 International).
The grand daddy of them all is the US NMTB. All others are derivations of that. You will notice in ISO297, UNC drawbar threads are permitted as an alternative to metric.
Thread: Bridgeport Issue
16/08/2023 21:45:15
Posted by SillyOldDuffer on 16/08/2023 11:02:38:
Exactly what the switch looks like varies, but after taking the wired end the motor off, it will be found mounted on the axle something like this:
If the switch is mounted on the axle, how does it transfer electricity? Last time I looked, there were no brushes or slip rings in my lathe motor.
The switch is fixed to the bell end of the motor. It is the weights that rotate.
Rather than pulling the motor off and to pieces, slip off the drive belt and see if you can reproduce the problem. If the motor fails to start, mark the pulley position relative to a fixed point and see if the position theory (bad spot) holds up. Given that the drive:driven pulley ratio is unlikely to be 1:1 you will then have separated any spindle issue from any motor issue.
Thread: Cleaning up internal thread on Bridgeport quill nose cap.
16/08/2023 16:20:35
This is an idea for a tool as the one pictured would not fit (or maybe it would if you removed the pin and reattached once in the hole):
https://www.zoro.co.uk/shop/cutting-tools/combined-drill-and-countersinks/rc2000-medium-reversible-countersink/p/ZT1126465X
Thread: Three wire thread masurements for taps
13/08/2023 09:38:40
I wondered what the UN and Whitworth thread series equivalents to ISO2857 (also called EN22857) might be.
Some info. (but not a formal standard) here:
http://www.tapmatic.com/tapping_questions_class_of_threads_h_limits.ydev
Note that the number after the H is the multiple of 0.0005" that the pitch diameter is oversize for that class of tap.
This puts it a little more clearly (but note that the link below is for an STI tap, so ignore the actual numerical values):
https://katofastening.com/article/taplimits.html
Best I can find for Whitworth form is ISO5969, which is for ISO pipe threads (which are Whitworth form).
https://cdn.standards.iteh.ai/samples/12163/1c8129d4e26a45a9a5452ae960f61f91/ISO-5969-1979.pdf
13/08/2023 07:34:44
Posted by Michael Gilligan on 13/08/2023 04:54:26:
The tolerance width is equal between 6H and 6HX. Forming taps are usually produced with a 6HX or 6GX tolerance.
Thanks for the reply. There is some shorthand going on in Sandvik's descriptions.
ISO limits and fits (e.g. https://simplybearings.co.uk/shop/Info-Pages-ISO-Limits/c4746_4779/index.html?page=1) are fussy about nomenclature, hence my confusion.
Any tolerance with uppercase is for a hole rather than a shaft, so in a very strict sense a 6H tap is non-sensical. The short hand translates to 'a tap designated 6H will produce a female thread to 6H tolerance'.
Thanks to some words from the link you kindly provided, I found ISO2857:
https://cdn.standards.iteh.ai/samples/7858/fb4ec4f1d31d4e02b38f44d39c4bd111/ISO-2857-1973.pdf
So, as you say, use the dimensions from ISO2857 and perform the three wire calculations on the basis of these.
Probably best to do all the measurements before cutting three flutes into the tap.
12/08/2023 21:38:23
Having just watched a YT video by Artisan Makes, he is making an M20 x 1 tap.
In the video, he states that there are online calculators for three wire thread measurements. So far, so good.
But if you are making a tap, does it not have to be larger than the bolt that screws into the female thread that the tap produces?
So how do you arrive at the correct three wire measurement for a TAP?
There is some information from Sandvik on the class of thread produced by a standard tap here:
https://www.sandvik.coromant.com/en-gb/knowledge/threading/tapping/thread-standards-and-thread-tapping-tolerance-classes
and it quotes H6 as a typical female thread tolerance.
What would be the shaft tolerance on the tap to produce this hole?
No three wire calculator I can find alllows an oversize tolerance.
Thanks.
Thread: Which Thread?
12/08/2023 07:42:18
The unscrew-one-turn-and-measure idea is good. Because the arbor is flanged, a set of feeler gauges might work very well for this pirpose.
A 5/16 BSW bolt could be used if your thread gauge does not have 18tpi on it.
You could also go for a majority decision: try to find an 1 1/2" arbor for sale somewhere in the world by anyone at all that is not 18tpi.
Thread: Customising a Dreadnought File
11/08/2023 08:23:02
Posted by JasonB on 10/08/2023 13:06:26:
I'd be tempted to try a carbide cutter to mill the edges...
...and consider climb milling onto the face you are creating rather than off it. That way any burrs will not affect the bottom (or top), cutting edge(s) of the file.
