Michael Callaghan | 23/08/2023 09:51:38 |
173 forum posts 7 photos | Hi, my centec milling machine uses NT30 chucks, however I can’t find a slitting saw arbour this fitment. Can anyone point me in the right direction to purchase one. Thanks. |
Saxalby | 23/08/2023 10:35:16 |
![]() 187 forum posts 33 photos | I had the same problem needing one for my Tom Senior horizontal spindle (Int30). I already had a Clarkson Autolock chuck so turned up a couple of adapters to take the various slitting saws I had. Regards Barry |
DC31k | 23/08/2023 16:59:54 |
1186 forum posts 11 photos | Why do you need a special arbor for slitting saws? Do they not fit on the standard horizontal arbor? Or is it for use with the vertical head? This might be a good place to start: https://www.rdgtools.co.uk/acatalog/30-INTERNATIONAL-TO-1--FACE-MILL-ARBOUR-1040.html It has a 1" spigot, that will suit many slitting saws. It has a key in it whch can be adapted or discarded. Remove and discard the drive dogs. All you need to make is a cap and some spacers (or buy the spacers or borrow them off the horizontal arbor). You could buy a plain shank slitting saw arbor and mount it in a 30 taper ER32 collet chuck. Lots more bang for your buck that way. You can similarly make a 'plug in' full horizontal arbor to suit the ER32 chuck. |
Speedy Builder5 | 23/08/2023 17:06:40 |
2878 forum posts 248 photos | 3 Ba is 4.0894mm diameter x 34.8 tpi or 0.73mm pitch |
Dave Halford | 23/08/2023 17:08:59 |
2536 forum posts 24 photos | I have gently used the horizontal arbor in the vertical head |
Michael Callaghan | 23/08/2023 17:57:30 |
173 forum posts 7 photos | Dc31k, it would just make the job a lot easier using the vertical head. |
DC31k | 23/08/2023 20:06:35 |
1186 forum posts 11 photos | Rotagrip list one. The link is incomprehensible, so search for: 'slitting saw arbor 30 int rotagrip' |
Andrew Johnston | 23/08/2023 20:42:38 |
![]() 7061 forum posts 719 photos | Posted by Michael Callaghan on 23/08/2023 17:57:30:
...it would just make the job a lot easier using the vertical head.
In my experience a slitting saw on an arbor unsupported at the outer end will go walkies if the depth of cut in more than a few millimetres. On the other hand using a horizontal arbor, supported at the outer end, one can go as deep as the saw will allow with no tendency to wander. Andrew |
Howard Lewis | 24/08/2023 02:27:06 |
7227 forum posts 21 photos | If you are using a Slitting Saw, do NOT use a key. If anything jams, the saw is likely to split and surround you with flying metal. Luckily, I was not quite alongside when an Apprentice using a key (Disobeying instructions ) had his saw split. Half of the saw was still rotating on the arbor as the other pieces fell all around, and came down from the roof! Howard |
Michael Callaghan | 24/08/2023 08:40:09 |
173 forum posts 7 photos | Thanks Howard. Good point made, and I will be sure to make use of your suggestion. |
