Member postings for Steve King 5
Here is a list of all the postings Steve King 5 has made in our forums. Click on a thread name to jump to the thread.
Thread: V-Twin 100cc Design & Build
10/07/2019 11:57:13
Really looking forward to seeing this engine buid progress. Good luck and keep us all posted.
Thread: Using a pillar drill for milling?
22/06/2019 21:16:33
I tried it on my startrite drill it didn't end well. Lesson learned
Thread: DTI identification
21/06/2019 16:52:48
That's correct a mk2 I believe
21/06/2019 12:03:25
I'd love a DRO but even the cheapest Chinese one are hundreds and I only have tens hahaha. Maybe one day.
Steve
21/06/2019 10:34:38
I plan on using the DTI like this
21/06/2019 08:37:32
Thanks JasonB
Its metric 0.050 equal the one full rotation plus 27 divisions.
Thanks for helping out the novice its much appreciated .
Steve
21/06/2019 08:11:07
Think its metric as it does not line up when mounted to my lathe as suggested by JasonB.
If any one wants to swop it for a imperial equivalent drop me a message.
Steve
20/06/2019 19:35:34
Hi all
I have the DTI but it doesn't say if its metric or imperial nor does it say what each increment is. Its very heavy and feels smooth so I'm hoping it's a good quality one.
Can anyone help.
Steve
Thread: Hello from East Yorkshire
19/06/2019 20:18:36
Good evening Mark
Welcome to the forum, it's a very friendly place with people always happy to help.
02/06/2019 19:04:20
20190602_125636.jpg20190602_125641.jpgDragged the wife and kids around a car boot this morning and picked up a bench grinder £18, bottle Jack £4 and some g-clamps £4 for the 3.
28/05/2019 19:29:30
Finished and blued up some tee nuts.
Thread: WHERE ARE THE SHAPER USERS ?
28/05/2019 15:24:03
Managed to finish the tee nuts this morning. Used cold blue for the 1st time and was pleasantly surprised with the results.
13/05/2019 16:01:33
Thanks that would be much appreciated.
05/05/2019 11:32:15
Thanks lads some good advice for me as a beginner to follow. I'll keep you all updated on my progress and as I take on more challenging projects. Once iv become I little more confident and my skills improve I'll be making tool holder for my QCTP. Iv got a big old lump of cast iron to practice on. Oh I need to grind up a shear tool for finishing cuts. If any one can post some pictures of the shear tools you are using that would be great.
Steve
Edited By Steve King 5 on 05/05/2019 11:33:36
04/05/2019 20:45:13
Making some tee nuts on the shaper. This is my 1st shaper project.
28/04/2019 12:00:21
Posted by Joseph Noci 1 on 28/04/2019 10:45:36:
Perhaps the ram is rocking a little? Check the slides/gibs, etc and make sure they are snug with no up/down or side play.
Also check that the table is not moving downwards - as the stroke lengthens the lever action at the outer end of the table is greatest and tends to push the table end down - this can induce tool chatter and the like. Likewise check the table vertical (Z) and horizontal (X) slides for any play and snug the slides/gibs up close.
The table end also has a support bar/pillar that rides on the base of the Shaper - make sure that is properly length adjusted and that is slides smoothly on the base - some grease, etc.
Did you machine that plate in the vice? If not, ignore this - If so , did you use packing beneath and firmly tap the plate down whilst tightening up the vice jaws - If the plate is not as square as the vice jaws are parallel, it may also rock in the vice add resulting poor finish.
Joe...
Thanks Joseph I'll look in to your suggestions tighrbut I can say all the Gibson are right possibly I little too tight. The table end bar was adjusted and I used a vice with Hss blanks as parallels. The work piece was firmly tapped down on to them. But writing this reply and I'm thinking I just chucked the vice on. I'll take it off and clock/tram it true see it that helps.
Steve
28/04/2019 11:50:07
Posted by peak4 on 28/04/2019 10:39:16:
Posted by Steve King 5 on 28/04/2019 10:03:56:
Good morning people
Yesterday I was having a play around with the shaper and for some reason unknown to me the longer the stroke of cut the worse the finish gets. I starts lovely and smooth and gets progressively worse.
Could anyone offer any advice?
Steve
I'm no expert with these, having only recently bought one myself.
Are you picking a lower belt speed for the longer stroke? I think the tool velocity increases with the stroke, so for longer workpieces, try dropping the bely one or two grooves on the drive pulley.
Bill
Hi Bill
No I have not changed anything since picking it up last week. I'll try your suggestion.
Steve
28/04/2019 10:03:56
Good morning people
Don't know if it will show up in the picture.
Steve
24/04/2019 19:36:43
Posted by Joseph Noci 1 on 24/04/2019 15:16:36:
Posted by Steve King 5 on 20/04/2019 20:14:01:
Picked up this little beauty seems to have had very little use because scraping marks are still visible on all slideways20190420_161127.jpg
Super Little Shaper you have there! Very nice! Do you intend to clean, polish and paint it?
I wonder how many more of these gems lie hidden in strange places all over the world!
Joe
Probably just a clean up and put it to good use.
22/04/2019 08:36:17
Edited By Steve King 5 on 22/04/2019 08:46:47
