Here is a list of all the postings Lee Jones 6 has made in our forums. Click on a thread name to jump to the thread.
Thread: Warco VMC to CNC |
09/10/2020 10:15:21 |
Good start. I wonder why you didn't receive any replies. Well you're in luck - there are no kits for these machines AFAICT. I have the Warco Super Major and I've been considering converting it for a while. The issue I have is; I'm sure the project will entail machining parts to make it work, but without a 2nd milling machine, this would entail continually disassembling it, taking some measurements and reassembling it again to make the part, which sounds like a faff. Maybe the process would be easier now that I have a 3D printer, as I can mock up all the required pieces while the mill is disassembled, and only assemble once to make the final parts.
Thread: [Project 3] Dickson T1 Tool Holder |
29/09/2020 14:27:06 |
Posted by Lee Jones 6 on 26/09/2020 08:28:02:
Ah, so you have a bought holder. Maybe that'll work better than my janky Heath Robinson setup. Received mine today from 'you know who'. It's soooo tiny! |
Thread: What *should* a Warco Super Major Milling Machine be able to accomplish? |
26/09/2020 21:32:10 |
Sorry, Daddy brain. Think about the cut pushing material outwards towards the fixed jaw.
26/09/2020 20:55:37 |
That is a fair assumption. Using the power feed. |
26/09/2020 19:56:13 |
I would like all the things please. |
26/09/2020 19:32:49 |
Annoyingly I like the current surface finish, so I'm at pains to tram to 100%. The main issue for me is that it's trammed the wrong way. I'd like the best finish to be a result from pushing the cut into the fixed jaw really.
26/09/2020 18:27:18 |
Yes, the trailing edge makes reversed arcs on the way through. And yes, it must mean the head is out of tram. Although when I checked it, it was about 0.02mm over 400mm, which I thought was reasonable. I've since ordered a new DTI holder to re-check it. |
26/09/2020 08:28:02 |
Ah, so you have a bought holder. Maybe that'll work better than my janky Heath Robinson setup. |
26/09/2020 07:55:15 |
Ha, that's cheating. Do you have a picture of your setup/shaft (no, I will not rephrase )? |
26/09/2020 07:46:57 |
Posted by JasonB on 22/05/2020 12:43:18:
Posted by Lee Jones 6 on 22/05/2020 08:21:14:
How does 0.1mm over 480mm sound? As nobody else has answered from last night I get about 1/10th of that in X&Y eg 0.003mm in 140mm on a Chinese machine. What do you measure with to gain that level of accuracy? I tried to use a 10ths/inch indicator which measures 6 10ths/inch over 480mm. Although it's hard with my setup as it's not 100% rigid. Might end up making something else. |
25/09/2020 21:21:03 |
Hola. Back again. Sorry about the delay. Machining was deprioritised for a few months. So had a big play today and guess what? Well, a picture paints a thousand words: TL;DR; Bolted machine down (didn't change much), faster speeds (1000RPM), faster feeds (250mm/m). This is how I left it *after* changing to Arc's "known good" inserts - so much for high hopes: Thoughts: maybe the setup is janky - too much flex: Yuck. Change back to the vise, pronto: Ooooo, faster (and don't let the trailing edge catch it): Missing test, back edge was trashing the finish, so mill the other way: The money shot: Pretty: |
Thread: Scrappy Haul (50 HSS Pieces) |
21/09/2020 16:30:37 |
It's something I would consider if I didn't already have more carbide than I know what to do with. My lathe came with a massive plastic box of the stuff. |
21/09/2020 15:23:31 |
It's all too big for the holders I have (and I have some pretty big holders)! |
21/09/2020 15:19:27 |
I think metal is metal to them TBH. Last time I visited they sold me 3kg of barely used carbide inserts. Shame not many of them fit my tooling, but it's the thought that counts. I'll dig out a picture. Edited By Lee Jones 6 on 21/09/2020 15:23:58 |
21/09/2020 13:50:13 |
Yes, I have a collet chuck and a mid-sized floor standing milling machine. No plans to put any of the cutters in the lathe. I don't have a horizontal milling machine, but I do have an R8 arbor that takes them. Not sure if using the larger milling cutters as slitting saws is such a good idea though.
21/09/2020 12:16:15 |
So I went a bit giddy today at the scrappy (only went for a bit of aluminium). Even if I never use this stuff, I still had a good time foraging. £35 though. Might go every week. What are your thoughts? |
Thread: Deburring Stones (stones for deburring) |
11/08/2020 13:46:36 |
Thanks guys that's super helpful. @John Pace, I watched that too, but it's not relevant unfortunately. |
10/08/2020 10:38:48 |
Don't laugh! I realise this might not be a *thing*, but ... I am already in the possession of a bench lay whetstone to sharpen some of my tools. However, I've seen a few videos of late where a few of the popular hobbyists use (hand) stoning to finish the edges of their work. Are these just the usual Aluminium Oxide/Silicon Carbide stones or something a little more specialist? I did watch a video [0] in an attempt to educate myself, but it turns out the range/choice is even wider than I first thought. [0] **LINK** |
Thread: Warco Super Major Milling Machine - Stripping Gearbox |
22/06/2020 10:08:24 |
To be honest, I don't have anything to compare it to. It's doing what I require of it. Although it is still noisy during some operations. |
Thread: Surface Plate & Height Gauge recommendations |
09/06/2020 08:30:00 |
Posted by Ron Laden on 09/06/2020 06:51:07:
The APE height gauge arrived, used but in nice condition quality is excellent. Accurate too, when checked against my gauge blocks its spot on. I really like the micrometer adjustment, super smooth and feels just right. I put an offer in on ebay and got it for £30, can't complain at that. Good things come to those who work in imperial! |
