Member postings for Robert Atkinson 2
Here is a list of all the postings Robert Atkinson 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Machine corrosion protection
30/01/2021 19:11:11
My preferred product is LPS 3
https://www.techsil.co.uk/lps3-rust-inhibitor-380ml
https://www.techsil.co.uk/media/pdf/TDS/MIPZ50037-tds.pdf
https://www.cromwell.co.uk/shop/lubricants-and-chemicals/general-protection-fluids/3-heavy-duty-rust-inhibitors/f/8711
Safe on all metals, most plastics etc. Not he cheapest but it works. Widely used in the aircraft industry.
Robert G8RPI.
Thread: Air Compressor Warning
30/01/2021 17:26:06
Posted by SillyOldDuffer on 30/01/2021 10:09:31:
Posted by Sam Longley 1 on 30/01/2021 08:44:28:
Posted by Graham Stoppani on 30/01/2021 06:44:17:
Conclusions
Because the water did not fully drain each time the compressor was checked it allowed crud to form over the drainage plug so that it eventually blocked the drain completely allowing a much larger volume of water to collect over time.
Did it go "Bang"?
This one did:
Sam said " And there we go again-- back to the one in 10 million cryingthat was probably as rusty on the outside as much as it was on the inside & most people with any sense would have already said "Hey this is beginning to look a bit dodgy, perhaps we should have a look inside, or think about a new one" "
As has been said before, that tank failed from fatigue at the longitudinal weld. Look at the photo. Corrosion may have had some contribution, but not from rusting through.
Edited By Robert Atkinson 2 on 30/01/2021 17:28:24
28/01/2021 15:52:37
From fatique perspective it is always best to reduce the number of cycles (the very high pressure pure air bottles that were used for early thermal imagers had limited number of refills before being scrap). Most bursting failures of cheap tanks seem to be fatique related rather than corrosion which results in leaks.
As has been mentioned more water is added every stroke of the compressor so minimising that reduces how much water enters the tank
Overall best solution for a compressor used reguarly (more often than once or twice a week or the pressure does not leak away beween uses) is just drain the water and leave the tank pressurised. If it is only used infrequenty, drain it down and leave it empty. If in a warm dry location leave th drain valve open so it acually dries out.
Robert G8RPI
Thread: Hermes in action - Lost parcel ?
28/01/2021 15:36:02
At least that is indoors. There is small industrial unit down the road and every moring there are several people with small vans and cars sorting parcels outside in in the car park whatever the weather!
Thread: Milling machine enclosure
27/01/2021 20:15:59
A lot of people have mentioned "perspex" (trademrk for acrylic) This is not the best material for clear guards and shields. Polycarbonate (Lexan) is a better choice as it has much better impact resitance. It is also easier to cut without breaking. It also has better chemical resistance. The cheapest material, polystyrene, is virtually useless.
Robert G8RPI.
Thread: Whats this Tool? Workshop find.
27/01/2021 19:59:39
I would suggest it is for cutting leather strips like thongs or laces.
Robert G8RPI.
Thread: So Much For CE Labels!
27/01/2021 18:14:27
Posted by SillyOldDuffer on 27/01/2021 11:02:03:
Posted by Robert Atkinson 2 on 27/01/2021 07:50:56:
Posted by SillyOldDuffer on 26/01/2021 22:21:43:
Posted by Robert Atkinson 2 on 26/01/2021 22:04:55:
Posted by Neil Wyatt on 26/01/2021 18:33:02:
Posted by SillyOldDuffer on 25/01/2021 12:22:19:
There is no separate marking for NI they will stay with the CE mark.
Read all about it on the UK government website...
As I said " The only exception is those items that have to be assessed by a Notified Body,"
The UKNI is only for Items requiring NB 3rd party approval who use a UK NB. CE marking is still accepted if you use an EU NB.
Robert.
So what mark should be used by a Northern Irish manufacturer who wishes to sell in NI and the mainland, but not Europe, and wants to employ a British Notified Body? I assumed UKNI covered that, but the guidance table says UKNI is only valid as a marking if accompanied by a CE mark as well. Given the need for CE I'm not sure what UKNI is for.
I think the marking guidance as a whole means goods sold next year in the UK (apart from NI) will have to be UKCA marked (requiring a UK Notified Body), whilst UK manufactured goods for sale in Europe (including NI), must be CE marked, requiring a European Notified Body. Anyone in the UK making goods for sale in Europe and the UK has to provide both marks. Let's hope the same Technical File will be acceptable on both sides of the border!
UKNI covers the case that NI can accept CE marking, but a UK (inc NI) entity cannot be a Notified Body for CE marking. So for NI sales of items needing assesment by a Notified Body you can certify to EU CE regulations but use a UK (inc NI) Notiifed Body. This would be useful if only selling in NI.
A late breaking and odd arrangement. I would not be surprised if it changes.
27/01/2021 07:50:56
Robert.
Edited By Robert Atkinson 2 on 27/01/2021 07:53:29
26/01/2021 22:04:55
Here's what to look out for. Perhaps there should be a prize for spotting the first genuine one and another for identifying the first fake!
The UK Government website here explains what has to be done to implement UKCA.
I wonder when people will start moaning that they have to pay twice for documenting both CE and UKCA marking on their products?
<edit> err... three times as they will need a UKNI marking if they want to sell in Northern Ireland as well.
Edited By Neil Wyatt on 26/01/2021 18:37:12
If they moan they do not understand, there is nothing to stop you using one technical file for multple approvals. The only exception is those items that have to be assessed by a Notified Body, they wll have to pay for two of those.
The real issue is that many smaller suppliers will just stop selling into the UK because of this, customs paperwork and if online, the e-commerce act making them pay UK VAT.
Thread: The demise of UK fossil fuel Power Stations
20/01/2021 18:19:57
Burning wood pellets produces about 5% MORE CO2 than burning coal (twice as much as gas) not including the energy used to process and dry the pellets or shipping. Leaving the trees growing and absorbing CO2 and burng coal would result in less CO2 in the atmosphere. It's not clear that new trees are being planted at the rate required to replace those cut down., never mind provide future fuel reserves.
Ships only use diesel in coastal waters. Out at sea they use heavy fuel oil typically with high sulphur content.
Robert G8RPI.
Thread: Ethanol
19/01/2021 22:02:26
IDA is Ethanol with at least 5% wood Naptha / Meatanol or simialr.
95% IDA is 95% IDA + 5% water i.e roughly 86% ethanol, 4% Wood Napha, 5% water.
99.5% has a small quantity of water, probably through absorbtion from the atmosphere (they can't prove it's 100%)
Note that in the UK you need authorisation from HMRC to buy or keep IDA. There is a 20l per year limit for members of the public for hobby use this still needs HMRC authorisation.
https://ethanol.co.uk/products/industrial-denatured-alcohol-ida/
"Meths" is completly denatured alcohol - CDA no restriction on purchase in UK. It used to be dyed purple but that requirement was dropped in 2013.
Rober G8RPI.
Edited By Robert Atkinson 2 on 19/01/2021 22:04:47
Thread: Fast charging anyone?
19/01/2021 13:13:05
Assuming no losses charging a 50kWh (small-medium EV) battery would need a 480A 415V 3 phase supply. per charger That is 24 houses worth of supply per car.
Storage has been mentioned but it still needs to be charged, no use for a typical fast charge senario of a motorway service area running 24/7. Not sure what storage technology can deliver 600kWh (50kW in 5 minutes) though.
Also no actual hardware, just hype. They announced start of producton of Flash batteries for phones a couple of years ago but I don't see any on the market.......
Robert G8RRPI.
Edited By Robert Atkinson 2 on 19/01/2021 13:24:50
Thread: IDEAS PLEASE ?
18/01/2021 12:27:21
I might also have been a induction heater for bearing races
Robert G8RPI.
17/01/2021 21:59:07
Still think a small resistance welder. The sort of thing used for thermocouples or electrical connection e.g nichrome heting element to copper terminal. The size implies a conservative rating for the core so a high duty cycle application. The 240 / 400V primary imples industral use. I did wonder about a filament transformer but most valves are fussy about current and 0.83V at 130A is 0.063 ohms total circuit resistance so very little tolerance for connection resistance etc. I'd expect to see a few primary voltage fine adjustment taps if it was a filament transformer.
17/01/2021 20:28:29
Title is slightly misleading. Article refers to coal and oil fired power stations. Gas is going to be used for a long time and is a fossil fuel. Unless there is some unforseen storage solution we are going to need new nuclear for base load.
Robert G8RPI.
Thread: Disposable Gas Bottles
17/01/2021 13:57:10
One other factor to bear in mind is volume. The stored energy and thus hazard depends on both pressure and volume. This is reflected in the regulations. There is a lower limit for gas pressure vessels of 250 Bar/Litre below which the regulations don't apply (note: steam is specfically excluded from this exemption).
When used at airline pressures most disposable cylinders are below the linit e.g. less than 2.5 litre volume at 150PSI (10 Bar).
Robert G8RPI.
17/01/2021 13:29:53
The output ratings give a power of about 100VA / 100W which is not that big for a transformer.
As John H says the output voltage indicates a resistance / spot welder is the most likely application. A phot with something for scale (CD is good) would be helpful.
Robert G8RPI.
16/01/2021 22:00:34
Posted by br on 16/01/2021 14:42:04:
Posted by Vic on 16/01/2021 13:58:44:
I’ve got a couple of old disposable Propane gas torch bottles, what do I do with those? I suppose in theory the lightweight aerosol type could go in domestic waste? I’ve got the heavier steel ones though.
Rang tip about disposal of asbestos from a Stuart boiler back along - had to drive miles to a special depot and pay a large sum
Mentioned it to bin men at Xmas whilst giving them their bottle, and was told:-
As long as sack tied up and I can lift it, not interested as to what is inside.
He did say random checks were done once they emptied, so make sure no envelopes etc or anything that could identify was in the sack.
br
That is really bad advice and I'm surprised you repeated it here. Hazardous waste regulations are there for the protection of us, workers, the environment and future generations.
loose asbestos can be very dangerous. Depending on the exact type only tiny amount can cause health problems.
Robert G8RPI.
16/01/2021 21:49:41
Posted by Michael Gilligan on 16/01/2021 11:57:51:
Just pondering ... dont know
I wonder what the legality of putting them in a kerbside Litter Bin would be.
Can the local council object to such use of a facility they have provided ?
It's against most council by-laws. Litter bins are for litter not domestic rubbish. There have been cases of councils threating legal action aginst people putting addressed junk mail in them.
Robert G8RPI.
Thread: Standards of Electrical Wiring
14/01/2021 21:39:21
I was setting up a computer room at a school in Ghana few couple of years ago and I was getting shocks if I touched a computer and the metal bars on the windows (unglazed holes in wall). The wiring in the room actually looked quite decent and certainly had all the earths on the sockets connected. The teacher was unconcerned saying the students didn't mind! Further investigation showed that this newer building was wired to the main building with a length of flex supported by a wooden pole. The main building had an overhead 3 phase and neutral feed to an old MEM fuse box, No earth connection whatsoever. The school is on a sand dune so little point in even trying an earth rod. In the end I bonded all the window grilles together and to the ring main "earth" thus all exposed metal was equipotential.
Went back the year before last to do some updates and found the school was suffering power outages. They thought it was the general area but eventually I convinced them it was just the scholl becuase I could see a broken cross bar on one of the power poles feeding the school but the shops across the main road had power. The school reported it, but nothing was done. I was then taken down to "explain" to the district power engineer, That got a crew on site who confirmed my diagnosis. The then put in a emegency supply. Thi consited of getting two rolls of 2.5mm2 single insulated wire, one red one black, connecting it to the feed side of a meter (on outside wall) of a shop across the road, running them across the road, connecting to a 13A socket in the middle of the pavement outside the school. No earth, no fuses. I then had an extension lead to the computer room.....
Robert G8RPI.
