Here is a list of all the postings Robert Atkinson 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Electric motors |
24/08/2023 07:56:59 |
I was not implying that all chinese items are junk, but this is The metal bodied connectors used for the motor power and feedback are not safe for use on the voltages that the motor runs on. Trouble is people ignore the rules due to "normalisation" of the supply and use of non-compliant items - until someone dies then the fertiliser hits the air mover. Then there is a clamp down or / and knee-jerk legislation that also affects the people who were doing the right thing as well as the chancers. Robert. |
23/08/2023 12:35:44 |
Yet again cheap chinese junk that does not meet UK or EU safety standards. I can tell that just from the images. The connectors on the motor are not safe for use at the voltages that the motor runs on. Tha input voltage is not compatible with UK mains. The markings are not in english. Buer beware, this could kill you or someone else. Robert. |
Thread: 2 pole or 4 pole for Myford ML7R |
23/08/2023 07:50:50 |
While Noel's answer isn't wrong per-se, he does not have the required information to determine the fuse size required. The fuse in the plug is there to protect the cable. So to know the rating you need to know the size of the flexible cable used. If a 13A fuse is fitted then 1.25mm2 or 1.5mm2 flex must be used. If 1mm2 flex is used then a 10A or smaller fuse must be fitted. Robert. |
Thread: Safety |
22/08/2023 21:20:25 |
There are two significant employment differences in the USA that probably improve their productivity. They are very much Hire & Fire. Much less job security. demaond goes down, get rid of some staff. They generally have much shorter holidays and less generous sick leave provisions. When I tell people in the USA how much leave and paid sick leave I get they are very surprised. Robert. |
Thread: Raspberry Pi Pico |
22/08/2023 20:20:56 |
I fully accept that any BASIC is not what you should start to learn IF you want to be a prpfessional programmer, but I still maintan it ahas a place. Mostly for the reasons SOD said ( Our posts crossed so I didn't see his before hitting "add" on mine. I'm going to get on my soapbox now... One of the "things" I have against Arduinos, RPi's (and a lesser extent Python generally) is the "loads of pre-written stuff ". This allows people with little understanding to "make" things. The quality of the things is variable and if it doesn't work its hard to troubleshoot. It also, IMO, normalises bloatware. It cetainly does not promote understanding and efficent use of the available hardware. I'm sure I've mentioned the C comms libary that used all the memory in a PIC when my PBP code used the built in hardware UART. Rant over. Robert. |
22/08/2023 12:56:34 |
The Pico is a bit overkill for many projects. It is a lot of processing power for the money. A lot of that is of course taken up to run Python. Making it simulate a Arduino needs a lot of third party software and seems a bit perverse to me. I certainly would not want to use it for anything critical. I must admit I'm a bit anti-Pi. I find the relationship between the charity, profit making company the mony they actually spend on charitable efforts, the niumber of directors and their relationships a bit troubling. As is the fact that their terms and conditions are business to business, i.e. no consumer protection. I use "bare" Microchip PICs with a compled Basic. Pic Basic Pro www.pbp3.com which has a free version for personal use. Robert. |
Thread: 24V rectifier for lighting. |
21/08/2023 18:46:16 |
Posted by Nealeb on 21/08/2023 14:29:18:
Is all this worrying about strobe effects justified? Apart from the neon light illuminating the strobe marks around the outside of a record turntable and a specialised strobe gun, I can't say that I have ever seen this in practice. It has to be a neon as this is one of the few lighting technologies easily available that does not have any significant "inertia" in the light output. Well, maybe LEDs driven off rectified but not smoothed AC, but even then I'm not sure how powerful an effect it is. Filament bulbs surely have so much thermal inertia in the filament that they can't flicker to any meaningful extent. Even fluorescents do not give out light directly from the internal discharge which presumably is at mains frequency but stimulate a phosphor which glows - and I'm pretty sure that the phosphor will continue to glow for the few miiliseconds between excitations. Certainly when my workshop overhead lighting was fluorescent I never came close to seeing stroboscopic effects on my lathe chuck. That wasn't the reason I swapped over to LED striplights fed by DC from a SMPS. Is the whole thing really a bit of an old wives' tale? No, it's a real issue. The phosphors in fluorescent tubes vary depending on type, colour and make, but most do not have significant persistence. So they will cause strobe effects. LED lights will too. IT's all dependent on the design of the light(s), what other light is present, the speed and optical proerties of the moving part. Trouble is that the conditions for "freezing" a moving part don't happen often so we forget about it until an accident happens. Robert. |
Thread: Wheel castings on ebay |
21/08/2023 17:05:43 |
Not my thing but saw these on ebay: www.ebay.co.uk/itm/155729677014 A lot of unmachined loco wheels low start, collection from wolverhampton. Robert. |
21/08/2023 07:49:52 |
Low voltage lamps were used on machine tools and as inspection lamps fpr two reasons: Care is needed when buying low cost mains powered machine lights (or making our own). Even just looking at the photographs of many on ebay show they do not comply with UK safety regulations and probably are not safe in practice. Nor having a proper UK mains plug and only two core cable are big red flags. Robert. |
Thread: Safety |
20/08/2023 17:13:16 |
A machine tool used by a business does not have to be fitted with guards under uk law. The employer must ensure that they are safe. Of course if they think they are safe without guards and here is an accident they may be in trouble. As the club mentioned seems to have found, one of the big drivers for safety complinace is insurance company inspections. Robert. |
Thread: Diacator made by Dietest |
20/08/2023 09:24:30 |
Looks like I was right. Google is your friend: https://swissinstruments.com/my_products/diacator/ Robert. Edited By Robert Atkinson 2 on 20/08/2023 09:27:18 |
20/08/2023 09:21:55 |
The lever below the DTI translates sideways movement of the probe into vertical and pointer deflection. Robert |
Thread: Safety |
19/08/2023 18:51:50 |
Those would be thermal lances not Thermite. Interestingly the reverse reaction with iron. Robert. Edited By Robert Atkinson 2 on 19/08/2023 18:54:56 Edited By Robert Atkinson 2 on 19/08/2023 18:55:13 |
19/08/2023 18:33:52 |
That was Thermite not a furnace. The gas torch was just pre heating the rails.
Thread: VFD. XSY AT4 220v 1phase to 380v 3phase advice sort |
19/08/2023 15:21:58 |
Welcome to the forum. Robert. |
19/08/2023 15:15:56 |
Posted by Steviegtr on 18/08/2023 22:52:08:
Ebay is awash with machine led lights. I bought 2 for my machines some time ago & they are pretty good & very bright. Have a look at this item No on ebay. There are lots to choose from. Your only drawback is these are 230Volt. Steve. The lamp pictured is not compliant with UK regulations. Additionlly a metal bodied lamp with a two core mains lead is problematic. The 220V rating ia also incorrect for UK. I'd need to examine it but I bet it has multiple safety issues. Note that despite being UK stock the contact info is in China so good luck with support or getting your money back. Robert |
19/08/2023 15:06:54 |
The light rating is 27W input power so 1-3Acdepending on voltage. Clearly intended for vehicle use confirmed by the R10 approval. It must have a built in regulator to work over this voltage range. While the peak voltage of 24V AC is out of the noinal range of the lamp, as mentioned by SOD, the loaded average votage is probably OK. To be safe just use half wave recification (1x 3A or higher rated diode) and a larger smoothing capacitor, say 1000uF or 2200uF 35V. Robert. |
19/08/2023 10:37:17 |
To answer the question : For your Sealy 27W lamp the current draw will be over 1A so you need a 1.5A or greater bridge rectifier. I'd suggest a 2 or 3A item. If using individual diodes to make a bridge then you can use 4 x 1A diodes like 1N400x series. This is because each diode is only carrying current 1/2 the time. Hope this helps. Robert.
Edited By Robert Atkinson 2 on 19/08/2023 10:38:34 |
18/08/2023 20:38:09 |
Bigger brings greater mass and inertia. This can be a benefit or detrement depending on application. Good for constant running with variable not good for frequent stopping and starting.
Thread: Fuse Rating for VFD |
17/08/2023 08:02:50 |
To be clear the people with experience almost certainly are Competent and would legally be able to do the work. The issue is when the work has to be notified. This is normally done throgh a registered body. You have to meet their requirements and pay a registration fee and annual membership fee. It's all about the money. In theory they could do it through their local council building control officer but in practice the time and cost involved make this impractical. You CAN change fuses and make minor repairs and additions in your own home but there are specific limits. Robert.
