Here is a list of all the postings Grindstone Cowboy has made in our forums. Click on a thread name to jump to the thread.
Thread: VFD. XSY AT4 220v 1phase to 380v 3phase - burned-out compontent identification |
30/12/2022 01:23:45 |
+1 on what Andrew said. Rob |
Thread: I found this old car but what is it? |
30/12/2022 01:21:50 |
Those pipes around the radiator appear to be plastic, and is that a plastic drain-cock on the rad or just corroded brass or ali? Probably something early modified into a 'special' later on, I would guess. Some blue plastic-covered cable there too. David - our Peugeot 504 also had a torque tube Rob |
Thread: What Did you do Today 2022 |
29/12/2022 13:05:40 |
Hi Nigel As I mentioned back in September, you have to download the example files and extract them to a convenient place where you know where they are. Assuming you are looking for Sketch_A, you'll find it here. Rob Links to https://docs.plm.automation.siemens.com/data_services/resources/se/2020/se_help/common/nonLocalized/courseware_datasets/spse01510/sketch_A.zip |
Thread: Clickspring makes a Watchmaker's Faceplate |
29/12/2022 11:45:55 |
I watched this yesterday - very therapeutic! Although, to be a bit (very!) nit-picking, the chamfers on the three big holes were ever so slightly different distances from the screw heads. Rob |
29/12/2022 01:32:29 |
Nails? I'd have a word (or three) with whoever installed it! Rob |
28/12/2022 23:53:02 |
Derek - I can heartily recommend the EPDM (rubber) roofing membrane, I've done a few flat roofs with it now, and it's far better than felt in my opinion. More expensive, though, but re-roofing isn't something you want to redo very often. Rob |
Thread: Parallelism of carriage to spindle. Taper. |
27/12/2022 13:53:07 |
" The smaller diameter the worse taper becomes " - sounds more like workpiece deflection to me? Rob |
Thread: Wilesco factory |
26/12/2022 19:48:48 |
Very interesting, thanks. I was in the Mamod camp too. Rob |
Thread: Christmas Cracker Jokes |
25/12/2022 21:37:58 |
What did the Spanish fireman call his two sons? Hose A and Hose B
Edited By Grindstone Cowboy on 25/12/2022 21:38:11 |
Thread: BEEP command not workring on a vintage 486 desktop W97 PC |
24/12/2022 23:17:47 |
Posted by Frances IoM on 24/12/2022 21:50:33:
.....I am somewhat surprised that a board of this vintage still works as electrolytic capacitors tend to fail Still have an Apricot Qi that works! Rob |
Thread: Merry Christmas Everyone! |
24/12/2022 16:39:10 |
Merry Christmas and Happy New Year to everyone! Rob |
24/12/2022 16:38:13 |
+1 on what Bill says - if you can get other sounds, it's unlikely to be anything major like a hardware issue, or software controlling system sounds. But the other question to be asked is - has it ever worked on that PC before? Rob |
Thread: SpamScam Phone Calls |
22/12/2022 21:56:02 |
Had a few over the past week, supposedly from numbers with a local area code. The recorded message states that my Amazon Prime subscription has expired and that I have been charged £95 for renewal. Options of pressing 1 or 2 for further information (which of course I didn't). Rob |
Thread: re-use of gas springs |
13/12/2022 05:39:44 |
Something I noted today, as the rear hatch of my car closed onto my head, is that they ain't as powerful in very cold weather. Rob |
Thread: A very silly question. |
11/12/2022 15:22:56 |
I quite enjoyed the film, too, Rod. Rob |
Thread: Adverts |
11/12/2022 15:13:37 |
I've found that, if ou click on the 'More "For Sale" Ads...' or 'More "Wanted" Ads...' links at the bottom of each section, you get to see the up-to-date lists. Not ideal, but a workaround. It would seem that the "Workshop" materials advert which appears at the top of the side panel adverts and has been awaiting moderation for weeks may be blocking something? Rob |
Thread: New type postage stamps |
08/12/2022 17:11:37 |
July 31st according to the Mirror (won't bother with a link) Rob
Thread: Weller soldering iron bits |
08/12/2022 16:23:50 |
Gosh, I had (still have, somewhere) one of those RS cordless irons. Burned a hole through a jacket, carrying it in the pocket Rob |
Thread: How long should I keep my recently vapour blasted steel engine components before getting a primer coat down |
06/12/2022 11:09:22 |
+1 on what Baz and others have said - I've seen rust starting within minutes on freshly blasted parts. Rob |
Thread: Stopping everything from rusting. |
04/12/2022 15:55:07 |
I know this isn't going to help much, but I had one of those garages at a previous house and it was the worst thing I've come across for stuff rusting. Possibly making an insulated ceiling and insulating the walls may help a bit, in effect creating an insulated inner box that you can heat / de-humidify more easily. Rob |
