Member postings for Oldiron
Here is a list of all the postings Oldiron has made in our forums. Click on a thread name to jump to the thread.
Thread: Recycling HDPE
09/01/2023 10:50:41
I made a mould out of aluminium and melted some pieces from a round bar of HDPE in it to make some 2" square blocks.
Used a gas torch to heat the mould and feed in small pieces of the bar. A bit crude but it worked OK. Did it outdoors as it was a smelly job.
There is a video online from the ARW channel making a powered electric/air extruder for bottle caps. Probably 5 years ago if I recall.
regards
Thread: New member
08/01/2023 09:06:22
Hello Raymond. Welcome to the forum. What are your interests ? Lots of info' here for you.
regards
Thread: Model engineers
05/01/2023 19:10:14
Maybe someone at the Pallot steam & general museum may be able to help.
regards
Thread: Chinese diesel heater
05/01/2023 18:55:35
Posted by Steviegtr on 05/01/2023 18:11:49:
Posted by Oldiron on 05/01/2023 17:56:25:
Posted by Steviegtr on 05/01/2023 17:20:32:
Posted by jimmy b on 05/01/2023 17:14:08:
Posted by Oldiron on 05/01/2023 15:26:51:
This whole post seems to me to be a very good reason not to post any workshop or build videos on this forum.
Seems to me even if you have a cable or pipe out of true or a seemingly non complient clamping on a workpiece it will bring down the wroth of some people on you.
Just my 2 pence worth on the subject.
regards
This why I don't post that I power my workshop with an extension lead, fed by a 3 pin plug.
I'm no doubt living on borrowed time (not that I care).
Jim
A 3 pin plug. Huh mine is only 2 pin. The earath is just stuck in the ground. (not really)
Steve.
Thats also why I never show the pixies in the treadmill powering my shop. LoL
regards
Don't show that as you would be in deep water . I bet they have no workboots on either.
Steve
Edited By Steviegtr on 05/01/2023 18:12:17
They run naked Steve so not for general viewing or a pretty sight. devil But much more fun than trying to keep up withh this thread.
regards
Edited By Oldiron on 05/01/2023 18:56:27
Thread: The Workshop Progress Thread 2023
05/01/2023 18:00:03
Looks like a nice job Roderick. Should last for many a year. The other half keeps on at me to get a 3D printer but I have resisted so far.
regards
05/01/2023 17:56:25
regards
Jim
Steve.
regards
05/01/2023 15:26:51
regards
Thread: Q-Cut inserts
04/01/2023 17:45:45
Hi Bob, This post may help.
regards
Thread: Micrometer Question
04/01/2023 09:48:57
I have a couple of 221's. Gready I know but I do collect Starrett tools. smiley You can still get many of the spare parts from Starrett.
regards
Thread: Coming back in from the cold
04/01/2023 09:46:01
Hi welcome back to the hobby. If you are looking for something small for occasional use any of the small Sieg based machines will all work to a reasonable standard depending on the operator. There is a small Sieg in the ads on this page cheap if you want to try one out.
regards
Thread: Coughs and colds
04/01/2023 09:40:37
Go to a chemist, you can probably get Lemsip capsules. My wife got a couple of packs last week as she is always needing them through the winter.
regards
Thread: Downloads
02/01/2023 15:35:59
oops
Edited By Oldiron on 02/01/2023 15:37:22
Thread: Fuel for Petter AB1 diesel engine.
02/01/2023 12:10:56
Adding 10 to 15% of pump diesel will help with the lubrication and aid better running. Adding oil will produce more smoke than you may want and will probably clog up the injectors. I did this when running my Ssangyong 4x4 on chip oil with no problems after 25,000 miles.
regards
Thread: Downloads
02/01/2023 12:03:36
Hi Happy New Year to you and yours also.
You are welcome to download these ME screw charts from my Dropbox.
https://www.dropbox.com/s/7iqptzsm5ih5rpq/ChartC.pdf?dl=0
https://www.dropbox.com/s/087q9vz0vj4v4rk/ChartB.pdf?dl=0
https://www.dropbox.com/s/ukly5cjm7t07x1b/ChartA.pdf?dl=0PBSP9501865001
I hope they are what you need.
regards
Thread: M10 x 1.0 Fine
02/01/2023 11:53:28
Posted by noel shelley on 01/01/2023 11:15:05:
10 x 1 was/ is a common thread for lamp holders, the fitting is often brass. 8 x 1 is also not uncommon. Noel.
I used lamp extended nipples when making QCTP holders as I was too lazy to thread them on the lathe. I bought a box of 20, 60 x 10 x 1. They were available in brass or steel.
regards
Thread: Listening to my first AudioBook
02/01/2023 11:46:49
Posted by Ches Green UK on 02/01/2023 09:38:48:
Slightly off topic regarding the quality of audiobooks, more to do about the content of the book mentioned, Entangled Life.
Here's a recent example of what the little devils get up to... 'Cruise ship barred from docking in Australia due to fungal growth on hull' - https://edition.cnn.com/travel/article/australia-cruise-ship-fungus-intl-hnk/index.html
'The DAFF National Maritime Coordination Center was notified of "small amounts of biofoul" on the hull of the Viking Orion on December 28, DAFF said, adding that biofoul is a common accumulation of microorganisms, plants, algae, or small animals on vessel hulls.
According to DAFF, the management of such biofoul is common practice for all incoming international vessels.'
I wonder how the growth is spotted - are there sensors/cameras onboard, or do divers inspect the hull before she gets too close?
Ches
Even liveaboard sailing boats arriving in Australia have to have their hulls cleaned prior to arrival and are routinely inspected for "foreign" marine growth during the "quarantine " period..
regards
Thread: Parallelism of carriage to spindle. Taper.
28/12/2022 15:45:53
Posted by Chris Mate on 28/12/2022 00:38:35:
Greetings to all...
Just a question while on this subject: Facing test
Headstock Alignment to bed test...If a larger diameter flat piece clamped in jaws are faced, taken out and put on a ver flat surface, does it wobble, rock from the centre or does it set solid, ie is it convex or concaved faced-?
I have heard it must be set to slightly not flat but concaved result faced, is this true and how is this then set by factory, the method(by distance-testbar lengh etc)-?
It really is best to start a new post when asking questions. Your question was not "on the subject" as the OP was asking about taper on a new lathe.
It saves a lot of messing about trying to seperate 2 questions and the myriad of answers that ensue
Also when people search for a particular answer to a question it will not be hiding in a post with a totally different title.
Anywho I hope you get the answer to your problem.
regards
Thread: A Real Dake
28/12/2022 14:47:47
Thankyou for that PatJ. Very interesting. Downloaded and ran ok on Win10 Pro
regards
Thread: DRO
24/12/2022 09:07:04
Sorry cannot answer your question on the DRO. BUT I would be more concerned about keeping any machinery or precision tooling in a damp garage. You may be better off spending a bit of cash on insulation & damp proofing your garage.
regards
Thread: Merry Christmas Everyone!
22/12/2022 11:44:42
And a Merry Xmas & Happy New Year to you Neil and to all those involved in keeping the forum & magazine going. Not forgetting all our helpful members world wide.
regards
