Here is a list of all the postings Oldiron has made in our forums. Click on a thread name to jump to the thread.
Thread: Cleaning up surface rust |
01/03/2018 15:26:40 |
Hi Jon. Many threads on rust removal on the forum including this one. **LINK** regards Edited By Oldiron on 01/03/2018 15:26:56 |
Thread: Replies to wanted threads |
27/02/2018 18:18:27 |
I have used the reply to wanted & for sale ads a few times in the last couple of days with no problems. regards |
Thread: Help choosing a smartphone |
27/02/2018 18:14:32 |
If anyone using the old style sim needs to change the size you can buy a sim card cutter on EBAY for £3. Or go into your local phone shop or local guy in the market place and ask them to do it for you. I bought 1 and cut down sims as phones in the family were upgraded to later models. Saves all the messing about moving contacts etc if you are not tech savvy. regards |
Thread: Can you identify ? |
26/02/2018 19:15:10 |
Here is an interesting book on lathe bed design. **LINK** regards |
Thread: An odd grub |
26/02/2018 18:48:47 |
Probably a special. A transfer screw normally has the pointy end machined onto a hexagon to facilitate insertion. As here **LINK** regards
Thread: MEW 265 |
24/02/2018 13:07:30 |
Got mine Thursday regards |
Thread: Magic erasers, useful |
16/02/2018 12:50:26 |
Here is the EBAY **LINK** regards |
Thread: Digital Read Out Optical scales (cheap ones on Ebay |
15/02/2018 19:58:02 |
Hi Jim. There is an install by thecogwheel on what I believe is the same item here. :- **LINK** Might be of some help. regards |
Thread: Boxford AUD |
13/02/2018 22:27:42 |
As Robbo said, Make sure the spring loaded knob pulls all the way out. On my AUD it sometimes sticks. Another thing is when you oil the gearbox don't just put oil in the holes. Make sure you squirt oil up into and onto the gear train. Have a look at mrpete on YouTube he has some good videos on the Southbend versions of the Boxford including a complete gearbox strip & rebuild. Hope this helps. regards |
Thread: Greetings all! |
10/02/2018 17:37:27 |
Hi Mike welcome to the forum. Plenty of answers here. Might be worth contacting Amadeal Ltd and see if the have a manual for that machine. Good luck with the tear down. regards |
Thread: Change to subscription prices |
10/02/2018 14:26:55 |
I was wondering why the debit card payment is £47.99 as against £45 for DD for a print sub'. As from January 13th 2018 there is supposed to be no surcharge on debit/credit card payments.
Thread: 3-Phase motor 4-pole or 2-pole? |
10/02/2018 11:08:12 |
I also have the HY VFD's and find them an excellent unit. I went for a 2 pole motor for my Boxford lathe & Mill. I picked my motors from tecmotorsdirect.com They work together really well and have had no problems at all. Have a look here for differences in 2 & 4 pole. **LINK** Hope this helps regards Edited By Oldiron on 10/02/2018 11:10:08 |
Thread: Admin |
10/02/2018 10:51:02 |
Just send Neil a private message. regards |
Thread: Rescuing a 920 lathe! |
09/02/2018 19:39:25 |
Hi Andrew Sorry cannot help you with this but I am sure some one will have some kind of answer soon. regards |
Thread: Hello. From wrexham |
09/02/2018 18:57:07 |
Hi Welcome. A copy of LH Speary's "The Amateurs lathe" would be a good start. Also have a look on YouTube for the machining channels such as mrpete22,Abom79 etc. There is a mass of info on YouTube, just type your question in the search box there. Also a search through this forums topics will help as well. Many answers here. If you cannot find the answer just ask and the good folks here will no doubt help.
Thread: TOOLING SURVEY |
09/02/2018 16:59:23 |
Dohh OK thanks John. Didn't spot the location correctly. (not the first time and probably not the last) regards |
09/02/2018 16:47:42 |
Just a quick Q' Why does the Tangential HSS show up as number of votes and the rest as a % ?
07/02/2018 21:58:17 |
I have done the survey also. The results appear in settings. |
Thread: Accurate measurement |
07/02/2018 19:47:15 |
I would go with Neil' or Mick B1's simple explanations. For the model engineer or home workshop user there is simply no need to go into long winded diatribes on metrology. regards |
Thread: Deciding on material to buy and being economical |
07/02/2018 15:30:12 |
Gordon W. Posted by Plenty of "scrap" about which is of use for models and real life stuff. Some egs. - plumbing fittings, bed frame, CI lamp base, old weights. This morning my wife threw out a coffee filter thingy, she saw rubbish, I saw a con. rod for displacer on hot air engine.
The other good source for materials are printers and scanners & computer cases. eg, ground round bar stock, small cogs & pulleys, flat sheet metal, bushes, springs, small screws, small nuts & bolts etc etc. How would we home shop guys get along without scrap. |
