Member postings for Pete Rimmer
Here is a list of all the postings Pete Rimmer has made in our forums. Click on a thread name to jump to the thread.
Thread: Coil winding
12/11/2018 22:03:36
The video is a demonstration of a tool for winding vaping coils for kanthal wire for those e-cigarette things. Seems like it could be re-purposed for winding coil-springs but it might not be man enough to coil spring wire.
Thread: Do you clean up your rough end
12/11/2018 19:46:31
I find that stainless can pull up a nasty burr. A quick swipe with a file gets it gone though.
Thread: 3 Jaw Chuck Internal jaws - looking for a home
12/11/2018 17:44:44
Posted by IanH on 11/11/2018 20:44:00:
Hi,
I purchased a “new old stock” Pratt Burnerd 200mm 3 jaw chuck a few months ago, it came with both external and internal jaws. Unfortunately when I put it on the machine I found that the internal jaws were wrong.
Just to be clear here, the internal jaws are what I consider the “normal” chuck jaws.
The jaws look right and are the right “scale” for the chuck, but somehow they are not quite right being very stiff....I think the scroll form is different, the jaws perhaps being for a slightly larger or smaller chuck.
I set off to find replacement jaws, and to cut a long story short...eventually sourced a new old stock set from the US that are perfect - this leaves the jaws that came with the chuck redundant.
The jaws are unused as far as I can tell and look a quality job...if they would suit you, then let me know and they are yours for the cost of the postage or just come to Cheshire and pick them up. They are marked R148.
Ian
Maybe they are not originals, but replacements. Replacement jaws from PB come with a note that they might need work to ease the fit as they are machined 'tight' to allow for wear in the chuck.
Thread: DTI Glass replacement
08/11/2018 23:51:00
Posted by Hopper on 08/11/2018 23:32:40:
Often the crystal is a flat disc that is pressed into place using a domed mandrel. The disc edge snaps into a groove in the bezel, or is retained by the snap ring etc, maintaining its domed shape under tension. Can be done in the lathe by holding the bezel in a suitable collar in the chuck and making a domed mandrel that fits in the tailstock chuck. Screwing the tailstock handle provides the press action. Sometimes a slight bevel around the OD of the disc is required to make it locate in the bezel properly.
I've done this too. Turned a flat disc and pressed it in to a dome shape. You need to get the OD of the blank just the right diameter and I had several tried to get one right. It's far easier to form a shallow dome and turn the OD on the lathe.
08/11/2018 20:53:19
I have replaced several, never found a glass one they have all been plastic. Just buy a welding mask protector screen for pennies off eBay. Turn a shallow dome in some scrap material, heat up the plastic screen until it goes soft then pull it over the dome to make a dish of it then trim it to your required diameter.
Thread: The penny has finally dropped
06/11/2018 19:25:17
Posted by Bill Chugg on 06/11/2018 18:51:21:
Buying a part finished engine on ebay is, I have finally realised, a bad decision.
Better to start from scratch rather than spend hours on rectifying errors
Would the team agree?
Bill
I would say yes, but before you condemn the previous builder, understand that you don't know the circumstances. They might have been well-intentioned but incompetent, lack skill or mechanical sympathy or there might be other reasons why the work is poor. My father was trying to complete a Jinty whilst he was on heavy meds for the cancer which eventually killed him. The quality of work was shocking but it wasn't because he was not a capable engineer - after all, he did a lot of work to renovate a 1:1 scale Jinty years before.
I couldn't bear to scrap it so I donated that part-built frame and all the bits to the The Gravesend Model Marine and Engineering Society with the understanding that it would need to be re-worked from the start.
Thread: Colchester bantam gearbox
01/11/2018 21:34:34
Posted by Tim Watkiss on 31/10/2018 16:34:42:
Hi this is my first post on the website so hello to everyone, I am looking for advice about my colchester bantam lathe it is a mk1 two speed machine and had an issue with the leadscrew not working when I bought it. Does anybody have a manual and parts list for this machine? I am in need of a small part for the screcutting gearbox but I don't know what it is called but it is a link which connects two gears together, its a bit like a washer with two teeth either side which are 180 degrees apart on each side and offset by 90 degrees with the ones on the other side - apart from this the gearbox is fine and I can fit it up if I get the part.
Cheers
Tim
I'd call that a sliding dog.
Thread: Mikron Lathe Help needed
30/10/2018 16:11:26
I read both of those David, but the only thing between not knowing and knowing is learning. Many a hurdle has been crossed with the aid of a simple explaination how.
30/10/2018 13:42:43
Ketil (and Nick),
If you have access to another lathe do the following:
Get a tube of micrometer blue (or other engineer's blue)
Bore a piece of stock so that it will pass over the thread and the OD register. This is a test-piece to get the taper angle set on your compound.
Make a template from card or take measurements to get the approximate angle of the taper from the threaded part. Use it to set the compound angle on the lathe.
Now cut the taper in the piece you bored.
Blue up the taper you cut and use it to take a print off the taper by pressing it lightly and giving a bit of a turn. Removing and replacing the test piece in a 3-jaw will not affect your results at this oint and there's no need to dial it in, just re-cut the taper each time.
Adjust the compound angle until you get a good print on the spindle from the piece you cut and then keep the compound set to that angle. Keep that tool in the toolholder so the tool height is preserved because adjusting the height even slightly will change the angle.
Now get your backplate blank, face, bore and thread it for the spindle all in one setup then cut the taper on it. Everything will now be concentric and you can finish off facing and turning the OD with it mounted in the Mikron. that will ensure the best mounting face for your chuck.
Edited By Pete Rimmer on 30/10/2018 13:44:31
Thread: Taper turning
30/10/2018 11:18:01
Yes that's exactly the idea. It was a one-off setup for cutting one particular internal taper angle in a hardened shaft using PCD tooling.
Love that cross-slide idea.
30/10/2018 10:17:10
Oh yeah there are a dozen ways to do it. Just use whichever suits you best.
I think it's quite difficult to make any taper that fits another without a test-fit and some blue. I use a tenth-reading dial to make small top-slide adjustments and I've even seen a setup that someone made that used a pair of jacking screws to set and then hold a taper angle for very fine work.
30/10/2018 08:57:43
Re-setting the tailstock is a simple matter just put a piece of scrap in the chuck and turn it to the diameter of the tailstock barrel. Now bring the tailstock barrel up to it, mount an indicator on the carriage somewhere and sweep across from the barrel to the part you turned. Adjust until they read the same.
29/10/2018 22:51:24
Posted by Mick B1 on 29/10/2018 22:13:13:
Posted by Pete Rimmer on 29/10/2018 21:48:52:
No scale is going to be good enough if the taper you're cutting has to fit into any other taper. For that, you need a sine bar or an indicator and some trig. Or a lot of trial and error.
Yes, I found that out in the 1970s - but a decent scale could get you close enough to cut out a lot of the faffing about.
Ah, it was more of a response to George. He asked why no scale - it would be of very limited use.
29/10/2018 21:48:52
Thread: Boxford model a
29/10/2018 15:40:15
Can you not modify it to fit Kevin?
Thread: Does anyone recognize this grinder ?
26/10/2018 19:03:14
I think that's for grinding punch press/fly press tooling because of the short table travel. We had something similar when I worked in a sheet metalworks back in 1986.
Thread: Myford Super 7 Belt and change gear cover material
26/10/2018 09:51:22
The belt guard you need. Is it the pear-drop shaped one with long slots in it? I have one of those off a ML7, if it will fit.
Thread: Mikron F75
25/10/2018 15:14:03
I think the answer probably lies with that off-set square drive fitting in the cone pulley. Have you figured out it's purpose Bill?
24/10/2018 12:45:02
The taper will be the register, it doesn't make sense for it to be otherwise.
24/10/2018 11:23:09
That's a hefty Chuck for a little Mikron. I certainly wouldn't go any bigger.
Edited By Pete Rimmer on 24/10/2018 11:23:27
