Spindle
kevin large | 28/10/2018 15:40:18 |
143 forum posts 3 photos | Hi all I've changed the spindle today or tried got the old one out ok got the new one in but don't seem to able to get the last bit of slack out the rear bearing looks as though it need to in about another 10mm the spacer behind the bearing appears to be up against the gear Do I need to draw it in with something seems really tight I don't want to damage anything Any tips appreciated |
Brian Wood | 28/10/2018 16:02:42 |
2742 forum posts 39 photos | Kevin, If I am following you description correctly I think you need to get the 4 step pulley cluster, thrust gearing and it's washer more carefully aligned, it should all slide in without any forcing. Check also to see if spring loaded oiler pads have not got in the way of inserting your spindle, it is very much a juggling match I'm afraid And the obvious question of course, is everything in the same order as it was before you pulled out the old spindle? Regards Brian |
Niels Abildgaard | 28/10/2018 16:24:50 |
470 forum posts 177 photos | 10mm sounds about rigth
See picture:
Edited By Niels Abildgaard on 28/10/2018 16:25:59 |
Niels Abildgaard | 28/10/2018 16:30:24 |
470 forum posts 177 photos | The rear cone fits very fest on spindle as You will know from the removal act. A piece of all thread,two flanges and a short piece of pipe and You have full control. I once used back of an axe as hammer and moved headstock out of alignment. Edited By Niels Abildgaard on 28/10/2018 16:31:02 |
kevin large | 28/10/2018 16:57:44 |
143 forum posts 3 photos | I've tried putting the tailstock up against the spindle front and light tapping of rear bearing but does not seem to go on any more as I said the spacer looks as though it's up against the gear behind maybe the gear needs hammering on further? I can't tighten the nut enough to pull it all up together |
kevin large | 29/10/2018 12:59:44 |
143 forum posts 3 photos | I have found the problem it looks like the spindle I have been trying to fit is a MK2 not a MK1 So have a spare MK2 spindle if anyone needs one |
Pete Rimmer | 29/10/2018 15:40:15 |
1486 forum posts 105 photos | Can you not modify it to fit Kevin? |
kevin large | 29/10/2018 18:47:40 |
143 forum posts 3 photos | Only trouble with modify it I didn't write down the measurement s of the MK1 shaft and I would need the lathe to able to modify it |
kevin large | 04/11/2018 16:47:50 |
143 forum posts 3 photos | Hi all modified the the spindle and now all done thanks all for advice etc |
