Here is a list of all the postings Bob Astill has made in our forums. Click on a thread name to jump to the thread.
Thread: Tom Senior |
28/10/2020 08:32:51 |
hi all thank you for the replies i am using it in the horizontal not vertical the bar goes right through the casting so i would be suprised to find any cracks and there is nowhere to measure what it clamps on. |
25/10/2020 06:39:08 |
Posted by Jeff Dayman on 24/10/2020 14:46:10:
You could try shims of drinks can metal between bar and housing to take up some clearance and hopefully restore clamping - no risk of machine damage with this try, and virtually no cost. Thats a great idea i have some steel shim stock will give it a go many thanks.
Bob |
24/10/2020 14:08:48 |
Hi all the main support bar has started to move when milling both the locking bolts are tight anyone had this happen? is there a way to stop it? and am i right in asuming that the locking bolts will need to be replaced if so where can i get some Many thanks Bob |
Thread: Freeby |
27/03/2020 13:59:35 |
It is part of steering column vauxhall I think |
Thread: Metric micrometer what t buy? |
23/11/2019 08:26:51 |
I have just bought 2 more and wright from Allen dale group they are on offer i am very impressed with them so far.
Bob
Thread: Lifting A Tom Senior Light Vertical |
19/10/2019 08:48:31 |
when i bought mine from machinery place they slid the bar in so sticking out both sides then slug of both sides the 2 nuts that tighten the bar were left loos i have had no problems. Bob |
Thread: Tom Senior M1 Vertical Head Drawing |
12/10/2019 11:31:06 |
Posted by fishy-steve on 12/10/2019 10:57:47:
Posted by Bob Astill on 12/10/2019 08:25:23:
Posted by old mart on 11/10/2019 16:07:30:
You may be able to get answers on the Denford forum. Denford own the copyright on all the Tom Senior archives. Great site but still no blow up of the head their is a photo of the drawing i need lol so close but so far Hi Bob, The picture of the drawing is all I have. I managed to find it late last night. I was going to send it to you today. I replaced the bearings in my knuckle head a couple of years ago. From memory the bearings were considerable more expensive than a metric equivalent. If I had to change them again I might consider re-engineering the casting to take metric bearings. Out of interest do you have a link to the bearings you purchased? Steve. Hi Steve i got the part numbers from a post on here somewhere the 2 thrust races i got from Ebay The MS9ACD was ebay and so was the LS10ACD i did google them but a big variation in prices Bob |
Thread: Would you buy one of these collets? |
12/10/2019 09:53:46 |
I have one of these as someone gave me several 50mm milling cutters i find if i clamp it in and also use a jublee clip at the end it works fine i have never tried to work the cutter hard though. Bob |
12/10/2019 09:33:23 |
Posted by paul rayner on 12/10/2019 08:40:26:
If I remember rightly the horizontal drive has bronze or oilite? bearings & the MT shaft has 2 bearings in it. 1 at the bottom which is held in place with the cover & the one at the top is held in place with a split screwed washer (the type you put a screw in so it doesn't come loose I don't know what you call them) there are no shims in there. You have to put the bearings on the shaft first and then slide the whole thing into the head. your old bearings should have numbers etched onto them so you can identify them like that if all else fails regards Paul Thank you for that Paul i have found the 2 bearing numbers and the to thrust bearing one and have ordered them i now need the number for the Oil seal and i think we are sorted. Bob |
12/10/2019 08:25:23 |
You may be able to get answers on the Denford forum. Denford own the copyright on all the Tom Senior archives. Great site but still no blow up of the head their is a photo of the drawing i need lol so close but so far |
12/10/2019 07:49:24 |
You may be able to get answers on the Denford forum. Denford own the copyright on all the Tom Senior archives. Thank you i will have a look. |
11/10/2019 15:20:56 |
Posted by fishy-steve on 11/10/2019 13:09:01:
Hi Bob, Which vertical head are you interested in? S type or knuckle head? Steve. Hi Steve not sure the difference between S type or knuckle but its just the small one it has no quill on it if that makes sense. i hope Paul will have the drawing i need. Bob |
11/10/2019 10:25:27 |
Hi all i have managed to find a Vertical Head for my M1 tom senior all be it in bits and with 2 damaged gears these are being made now i really need a drawing to see what goes where i have found some photos and part numbers to get new bearings in a search but these are not great would any one have one please.
I also need the seal number if anyone knows it? Bob |
Thread: Eagle Surface Grinder Colour |
15/09/2019 13:53:42 |
Hi all I have a small Eagle surface grinder made by Dronsfields of Oldham and have made a cover surround to Catch the debris but no where can I find what colour blue it is via google can anyone help please. Bob
Thread: Jones and Shipman 540 Dripping |
30/08/2019 14:18:43 |
Update well there is not one realy been doing 7 days at work so not had time to do it yet i have made a puller to get the stones off but thats about it
Bob |
Thread: Cheap DRO for Mill |
23/04/2019 14:29:07 |
If you look on Ebay for a seller 3977colin CBR Electronics Ltd he is from Nottingham and sells loads of DROs he goes all over fitting them he is a loverly chap and has done 2 mills and 2 lathes for me over the years at a very good price.
Bob |
Thread: Milling Machine advise |
23/04/2019 14:18:10 |
I buy all my machines fro Madan Machine tools at Goole had 2 Bridgeports and 2 lathes from him now both from colleges done very little work and he delivered them and put them in the workshops cant fault the man well worth a look www.maden-machinetools.co.uk
Bob |
23/03/2019 09:17:37 |
Posted by David George 1 on 19/03/2019 20:34:57:
How is it going Bob did you stop the leak. David Hi David not had time i am working 6 days a week at moment and she who must be obeyed claims the 7th |
Thread: J&S 540 Manual PDF |
19/03/2019 08:16:21 |
LOL David i am going to clean it not check it for finger prints
Bob |
14/03/2019 11:49:03 |
I have now bought the Spare parts manual if anyone needs a PDF copy please let me know.
Bob
