Here is a list of all the postings MW has made in our forums. Click on a thread name to jump to the thread.
Thread: Model Engineer - Citizen Scientist |
03/07/2017 09:37:29 |
I'm glad to hear how they call them, I don't think people realize a lot of the best scientists and engineers had no paper qualifications whatsoever, that wasn't important, but what they did have was a lifetime involvement behind it. I would like to think we could call ourselves citizen engineers! There was an article in MEW recently about flute manufacture and the author said the best silver tube maker he's met was an old bloke in a workshop doing it the same way it had be done for generations and it was dead accurate. Some people have an almost cartoonish ideal of what a professional is allowed to be, I suppose. Michael W
Thread: Milling in a pillar drill |
02/07/2017 21:09:21 |
Yeah I would agree a pillar drill is..well not really designed with milling in mind.(a pillar drill is absolute must for a workshop in my mind, but just not for cobbled together milling). It's technically possible, but I would question whether it would get the accuracy needed even if you could get over the big deflections. A lathe would be better suited, and would probably give you a better end product, you just have to think about the setups a bit more. And own a milling slide of course. You could just use a machine vise with and angle plate and pack the work pieces to the right amount, but this is perhaps going too far. I bought a rigid vertical milling slide, simply incase my mill ever croaks it then I've still got an ace up my sleeve. Michael W
Edited By Michael-w on 02/07/2017 21:11:39 |
Thread: Appreciation of Contributors |
01/07/2017 22:11:44 |
I know I've sung his praises before but Mike Cox has got to be one of the top notch too. Michael W
Thread: What Did You Do Today (2017) |
01/07/2017 20:34:24 |
Posted by Neil Wyatt on 01/07/2017 20:13:50:
I just rescued a 1GB SD card from the jaws of Doom (Doom being a labrador...) I find the only true solution to save the object is to replace it with another on offer that's far tastier. Michael W |
Thread: Machinery enamel paint |
01/07/2017 11:28:48 |
Posted by Neil Wyatt on 01/07/2017 10:09:05:
I thought the 'Trumpism' was 'criterionliness'. N. Criterionist agendas clogging up the swamp and depriving America of it's natural gunk, pro-Chinese democrats blah blah blah.. Michael W |
Thread: Choosing my first propane torch? |
30/06/2017 18:39:41 |
MAPP was great when they used to make it.. I would advise a sievert handheld torch or for a bigger one, a generic brand hose type with interchangeable nozzles (and a pressure regulator) and hook up to a small 3kg rented propane cylinder is a viable option. Michael W
Edited By Michael-w on 30/06/2017 18:40:11 |
30/06/2017 18:34:08 |
Posted by David Standing 1 on 30/06/2017 15:15:28:
Posted by Michael-w on 30/06/2017 15:11:35:
Anyone remember AJohnW ? what's happened to him? Michael W
And it was all going so smoothly...... I honestly wasn't implying anything, just curiosity and that cat again.. Speaking of curiosity.. Michael W Edited By Michael-w on 30/06/2017 18:35:47 |
30/06/2017 15:11:35 |
Anyone remember AJohnW ? what's happened to him? Michael W |
Thread: Ulti_printer 200x300 |
30/06/2017 11:12:00 |
Posted by John Haine on 30/06/2017 08:40:38:
Posted by Neil Wyatt on 29/06/2017 16:14:26:
Looks Good! Perhaps we should have a thread to co-operatively design and build an MEW 3D printer? Neil Nice idea Neil. Another thought, I have a CNC mill but not much space for a 3D printer. I've toyed with the idea of fitting an extruder to it for occasional printing. Might be an interesting project...? Edited By John Haine on 30/06/2017 08:40:54 I also have space problems but I found that the Kossel mini printer, which is another design by the same people who made the I3 prusa kit. This makes for a machine that's got much smaller footprint than the prusa, but compensates for this by giving it a lot of height. Michael W |
29/06/2017 18:49:05 |
This is the first I've heard of this but it will be a sour loss indeed, it's rare to have acquainted another member as polite and articulate as Michael G was. Michael W
Thread: Electrifying a distant garage |
28/06/2017 15:41:52 |
Can't you just quickly do it in the night, bury all the cable back and pretend nothing happened? Michael W |
Thread: 3D printed soft jaws |
28/06/2017 15:38:50 |
I find in a lot of 3D printed assemblies that they incorporate a hexagon space for a nut to sit sunken into the body rather than bother with thread printing, that way you've got metal to metal contact which will likely have a much stronger gripping power. Michael W |
Thread: Crap vee blocks and "Oxford Precision"? |
28/06/2017 13:51:31 |
Posted by Ketan Swali on 28/06/2017 13:20:10:
Posted by Michael-w on 28/06/2017 12:54:25:
I've still got some of my dad's tools bought from a chain of stores called "Texas" anyone remember that? Michael W I think it was bought out by Sainsburys Homebase. Gave me a chuckle, thanks Michael W |
28/06/2017 12:54:25 |
I've still got some of my dad's tools bought from a chain of stores called "Texas" anyone remember that? Michael W |
Thread: Shop vac recommendations please |
27/06/2017 15:20:58 |
Henry henry henry.. Michael W |
27/06/2017 15:18:24 |
Frankly ground to within 0.001" on all faces and matched for around £13, seems a bit ridiculous to expect amazement from them. They probably couldn't give a toss if it's 0.1mm taper in full length. Michael W |
Thread: Prusa i3 Build |
26/06/2017 20:12:51 |
Posted by Neil Wyatt on 26/06/2017 15:24:22:
Don't be a cheapskate! You can get 1kg of filament for about £15 delivered. At the end you'll have a reel you can wind your 50M on to. Neil Ah good to know! I must learn to loosen those purse strings now.. Michael W |
Thread: Ancient |
26/06/2017 20:11:22 |
It could be a small circular wire brush with grinding paste. Michael W |
26/06/2017 14:50:35 |
I have bought about 50m of PLA filament, but it didn't come with a drum, typically, should I be expecting to buy the maximum single quantity in order to get a drum included? or should I be concerned with buying/making one myself? Michael W |
26/06/2017 11:31:07 |
Posted by JasonB on 26/06/2017 11:27:11:
It seems that "Oxford" is a trade name owned by Kennedy who just so happen to also trade as Cromwell Tools. So at best you will be getting Cromwell's own brand tooling made where the price point suits.
J Why do factories of all places shuffle around with the branding? I wouldn't call this the fault of the people who make the stuff, they probably aren't even aware of the people it goes to but the fault of the people representing them. When I worked in some factories I barely knew a thing about where it ended up. Where I worked individual components were made from anything under 30mm downwards and these would often go to other factories who put the components into the assemblies. I made and inspected things for Cadburys (brass pins to push open moulds for chocolate Easter eggs) to F1 plastic armatures for coil windings, French telecommunications company plastic electrical connectors, aircraft connectors to PTFE grommets for the NHS to put into children's ears. but there were plenty where I had no clue as to what it actually did, that was none of my concern as far as the managers and sales teams would let me know. I would also add that even in the most high tech facilities with rigorous inspection control, every item inspected if need be, mistakes still happen and bad stuff gets through. Having said that, we never disputed when mistakes were found. Michael W Edited By Michael-w on 26/06/2017 11:39:31 |
