Here is a list of all the postings Chris Evans 6 has made in our forums. Click on a thread name to jump to the thread.
Thread: New member in Lancashire |
28/04/2016 09:33:14 |
Welcome along Chris, I do not built models (may be in the future when all the bike projects are done !) but I love the machining threads. Some very clever people on here. |
Thread: Cross vice backlash |
28/04/2016 09:20:00 |
Graham Engineering, a real blast from the past. I was a regular there, usually for things like big drills and cutters from the second hand pile when the job did not justify buying new for a one off. |
Thread: Motorcycle General Discussion |
27/04/2016 09:05:01 |
Shaun, thanks for the kind offer. You are a bit of a trek from the Midlands though. I have wheeling on my list of things to try one day, I would love to make a tool box for my pre war bike. Chris. |
Thread: Dimond wheel dressing. |
27/04/2016 07:25:22 |
I have used the white sticks but think they are more for cleaning/preventing clogging than dressing. I will be eager to learn more as I run a diamond wheel on one end of my bench grinder. |
26/04/2016 20:16:23 |
I used to do a simple dress on a cup wheel to remove the wear, (single lip Deckel type cutter grinder) With the wheel off the machine it was rubbed on a cast iron lapping plate with a little paraffin. Crude but did the job. |
26/04/2016 09:11:05 |
Shaun, lovely work. In all my time in engineering I never got near a wheeling machine but would love to try one. Nearest I got was watching through the door of a local tin smiths shop. |
Thread: Tilting Table Kit? |
26/04/2016 08:59:09 |
I have castings for a swivelling/tilting table. Patterns made by my Sisters Partner and I got two sets cast, I will start machining in the next week or so. I will cheat and go into where I used to work and surface grind the faces. |
Thread: which plastic rod |
25/04/2016 20:10:46 |
KWIL, I must have been using the PTFE or other filled type to notice a difference. Most of my plastics come as offcuts from autojumbles so really could be miss labeled. |
Thread: Here to learn and find the correct way :) |
25/04/2016 09:47:53 |
Sit and think about what kind of work you want to do on a mill. I love my Bridgeport because it suits my old motorcycle hobby, to big and pricey for a lot of folk unless you come across an early one with 36" table. I am not to far from Brum, in between Lichfield and Burton on Trent. |
24/04/2016 21:27:59 |
Delrin is a bugger to drill as it contracts and grabs the drill. Acetal is not bad, glass filled PTFE is good to turn, for all you need razor sharp tooling. Final decision is yours on what you are making. |
Thread: Are we all infringing this patent? |
24/04/2016 09:08:34 |
Having spent my 50 years as a mould toolmaker from copy milling patterns to embracing CAD from the late 70s. I am possibly guilty, but did we not pay handsomely for the licence to use the software ? In the last 30 years companies I worked for ran many differing systems all correctly licenced. |
Thread: Warco VMC lamp bulbs |
23/04/2016 17:00:00 |
Don't know about Warco stuff but I get bulbs for my lathe from local commercial vehicle place. |
Thread: Excellent machine lighting |
23/04/2016 09:36:14 |
That looks a nice bit of kit, you can never have enough light. I recently fitted a T4 (think under kitchen cupboard) strip light in the lip on the lathe splash back, one of your style will enhance the machine light which is always in the wrong place. |
Thread: Grinder for end mills and drills |
23/04/2016 09:28:55 |
Looking at all of those options I consider myself very lucky. A friend has a "Pratt & Whitney" cutter grinder as supplied with a "Keller" copy milling machine pre war or early 50s. It will do flute/ends/ball ends and internal radius work. Best of all I can turn up with a box of cutters and do them myself. Having said that making something is a nice project to add to the list. |
Thread: Elliott Juniormil |
22/04/2016 20:41:17 |
Shimming Gib strips is common on older/worn machines and it works. Have you established why it is tight ? The shim will not cause tightness, maybe the slides need some re-scraping or the lead screw is worn in the middle and tight on the ends. Most machines end up like that. |
Thread: Trying to choose a diamond grinding wheel |
19/04/2016 19:49:14 |
I run the 45 degree dish style on one end of my grinder with good results on the same things as you wish to do. |
Thread: Black 5 first steam up |
19/04/2016 19:47:07 |
Being local I would have come to your Gala day but am going to Oulton Park for the Superbike meeting. |
19/04/2016 18:39:49 |
I have been following your problems Ron. Well done for perseverance. |
Thread: Stripped T bolt |
19/04/2016 07:39:35 |
It is a quick and easy job to pull the cross slide off and make a correct tee bolt. Use EN24T if you have any or a Tensile bolt. The original most likely gave up from wear and tear, my lathe only has two bolts to hold the top slide on and I have added two tapped holes in the cross slide and made "L" shaped clamps to give a bit of extra security. |
17/04/2016 09:20:41 |
Yes Windy, so much better than the TZ Yamaha engine outfits of the era. |
