Here is a list of all the postings Brian Sweeting has made in our forums. Click on a thread name to jump to the thread.
Thread: Scaling back forum activity |
10/09/2020 14:20:49 |
It's always a shame when someone feels the need to resign (or semi) from a forum such as this but it has to be remembered that times and people do change. I have been a moderator on an engineering forum for over 19 years now and it is noticeable how the users (members) interest changes over time. There is an initial keenness to be in contact with like minded people and to share experiences whether gaining or giving knowledge. After a while the realisation sets in that you know as much as you need too and you no longer know more than those asking the questions. You also notice that the newcomers queries begin to get repetitively similar and suggesting that the search facility is used normally falls on deaf ears. There are times, no doubt, when moderators may seem harsh but consider also the logistics of the forum. There is minimum advertising here because it is, I believe, run by a commercial enterprise. The owners therefore are entitled to set some rules and live by them. If these rules do not sit well with you then of course you have the right to stand back. I do find it a shame that Barrie felt the need to publicize his disagreement with Jason as it does not allow Jason to defend his position and as such seems somewhat unfair. A quiet departure with PMs to close contacts would have been more diplomatic. Brian |
Thread: Hello |
25/08/2020 18:25:52 |
Looking at your lathe on lathes.co website it would be a shame to consign it to the scrap bin, hopefully someone can help you. |
Thread: Any idea what this is guys & gals |
24/08/2020 11:45:25 |
It looks to me somewhat similar to an air operated "mole" as used by the gas and water trades to drive a pipe through the ground. |
Thread: Quality Finish |
23/08/2020 14:39:59 |
Use a shear tool to obtain a smooth finish then fine abrasive. |
Thread: How can I fix this LCD display? |
20/08/2020 18:03:27 |
Check also the back contact surfaces of the LCD unit. |
Thread: epoxy resin preventing from sticking. |
14/08/2020 22:03:05 |
There are a few things available.. Read here... |
Thread: Coping with voltage spikes |
13/08/2020 18:49:14 |
At low engine/dynamo revolutions the regulator will be busy switching on and off to balance the battery/load. Do the lights settle down as the revs come up? |
Thread: TBH! |
12/08/2020 13:13:25 |
Agreed, but it's all relative... On a refrigeration forum I use one of the members from Iraq posted a picture of his car dashboard at 5 o'clock in the morning and a temperature of 50⁰C. ( Not for me I think) |
Thread: Greenish amateur lathe enthusiast |
11/08/2020 18:25:12 |
Found a copy of the manual here...
Thread: Paint for mild steel sheet brazing hearth. |
09/08/2020 19:37:18 |
Vehicle exhaust paint, some goes up to 650⁰C. |
Thread: Viking Link Interconnector |
09/08/2020 14:08:22 |
Well that passed a little time reading up on that quite interesting subject. It seems that there are less losses in transmitting DC power as it doesn't have a frequency compared with AC. These losses increase with the distance. One factor which I believe could be important s that the DC link provides a system isolator between the two AC systems. This allows, for example, the North and South islands to be out of phase with each other but still pass power between each other. Other things are that the DC cabling can be smaller than the AC especially on overhead cabling therefore towers can be smaller, cheaper, too. |
Thread: DC motor reversing |
17/07/2020 18:49:53 |
A couple of thoughts, I'm no expert on these things... Are there any limit switches in the circuit? Is the ram mechanically sound and able to operate in both directions? What is the small PCB for? |
Thread: Hallite washers |
12/07/2020 15:57:25 |
Posted by not done it yet on 11/07/2020 23:57:29:
You mean a Dowty washer? That's the name, for the life of me I couldn't remember it. It was only 40 years ago when I used them on a regular basis. |
11/07/2020 20:06:33 |
Are these bonded seals of any use?
Thread: West Yorkshire Police |
30/06/2020 18:04:49 |
Many years ago I was in lane three at around 70 when the traffic slowed rather quickly. I hit the brakes hard but also checked my mirrors, as trained, so as I came close to stopping I moved right towards the central area with my Dad, in the passenger seat shouting "what are you doing?" Having stopped we watched the car behind me, nose down, head directly into the boot of the car in front of me. Close call |
Thread: Indian stationary engine of interest to Martin Perman ? |
28/06/2020 19:04:42 |
Excellent, bright kids. |
Thread: Lollipop maybe? |
18/06/2020 19:18:42 |
I found one other picture on the web with a 14" like yours and, of course, the lollipop was empty as well. |
Thread: Compressor inspection |
09/06/2020 19:07:44 |
Posted by Adrian R2 on 09/06/2020 08:50:29:
I've got one of these which is puzzling me. It's supposed to be 150psi but labours to get up to this pressure and then as soon as it does the safety valve blows and depressurises before the compressor cuts out. I thought the cutout switch was defective so removed it but when tested with a high pressure cycle pump it seems to work as intended (NC, opens at around 150psi, closes again at 120psi). My current plan is to derate the cut out switch to a 120/90 equivalent, are there any better ideas? Adrian Sounds more likely that the pressure relief valve needs replacing as it is out of calibration. |
Thread: A red face and a bottlejack |
08/06/2020 17:49:25 |
Maybe write some instructions down and put in a plastic bag, then tape it to the jack. |
Thread: Run capacitor value .Bench grinder |
04/06/2020 13:03:09 |
Have you tried your local electrical wholesaler, if you have one? |
