Member postings for john carruthers
Here is a list of all the postings john carruthers has made in our forums. Click on a thread name to jump to the thread.
Thread: The Workshop Progress Thread 2019
28/11/2019 09:09:57
After a year or so of renovating the new house I have finally found time to play in my shed.
This arrangement allows me to cut spur gears.
I used an old bolt for the single point cutter but will be ordering a cheap set of mod 1 cutters from China.
Thread: Watch and Clock Escapements
28/11/2019 08:53:40
Thanks for that, I'm at the stage of thinking about an escapement for a sidereal clock.
Thread: Thread sizes on flexispeed meteor lathe
20/08/2019 08:33:21
The spindle nose is 1/2" x 16tpi
If you look in my Flexispeed album there is a copy of the old type written manual..
flexispeed
Thread: Mill hand wheel upgrade
20/08/2019 08:22:05
Have you asked Arc Euro?
They carry metal hand wheels for lathes, maybe they would fit the mill?
Thread: "Oh, I do like to be beside ... "
04/08/2019 08:04:01
Re. the Folkestone sand pumping.
Every so often a loud clanging and banging was heard in the pipe and eventually a cannon ball would be deposited on the sand heap.
We told the manager it was skulls from a disturbed war grave at sea
"No! don't say that lads!! we're behind as it is.
Thread: Angle grinders - Dangerous or not
19/07/2019 08:45:58
What could possibly go wrong? wink
carving disc link
Thread: Tapping a thread
06/07/2019 18:20:05
use the plug but make the piece longer with a tapered lead in that you can cut away later.
Thread: Using a lathe
30/06/2019 08:22:26
The old tech scool I attended started everyone in the machine shop and carpentry shop at 11.
The metalwork master Charlie (Cog) Wheeler demonstrated the cutting eficiency of the bandsaw by bringing in some pigs trotters on the first day.
He said nothing, started the saw, sliced the trotters into little bits which he threw in the bin then said
"...the saw doesn't care. That could be your fingers, any of the machines in this shop WILL do that if you piss about with them".
End of H&S sermon.
There were a few scratches and minor bruises in there over the years, nothing serious, we all got worse in the corridors.
Thread: Chinese tacho - beware
20/06/2019 18:41:18
Fluke.
Fluke have 3 factories, 2 in PRC and one in Germany.
The Fluke multimeters are tested and callibrated on an instrument made in Deal, Kent, codename 'Baldrick'.
Each factory has 2 such testers.
The main problem in manufacture is the fake parts in the supply chain.
Even the PRC guys get caught out.
Thread: A depthing tool and escape wheel
11/06/2019 08:32:49
Maybe a vernier on the indexing head?
360/25 = 14.4 deg.
(= 14 deg 24 arc min ).
Thread: Quicksilver
04/06/2019 08:18:07
As an aprentice one of my jobs was to scrape the 'silvering' off the backs of old mirrors and save the scrapings in a bottle.
The mercury gradually fell to the bottom and was decanted off to be sold to 'the mercury man' who attended annually.
Alas, no more.
Thread: What are you using for Lathe Way Oil?
02/06/2019 15:30:22
iso32 'Jack Oil'
30/04/2019 08:44:53
The new shed/workshop is finally erected, I've been aiming for a better set up since we got here last October.
8' x 10' from ShedsAhead of Port Talbot who did the installation.
Because of the slope and underlying limestone it sits on 18 4"x4" piles.
Next the power and light, then the benches. I've been saving the old kitchen units and worktops for this job.
Thread: Backlash
21/04/2019 11:43:40
The usual solution for this, when using astro telescopes, is to incorporate an absolute encoder to see actual movement rather than rely on step counting.
The cheapo diy version uses an old mouse encoder wheel.
Thread: Notre Dame
16/04/2019 08:25:01
Before the big footed structural guys get in there to shore it up, let the glaziers pick over the rubble.
Sort each fragment of glass into seperate boxes marked with the position found.
More importantly what depth or layer it was found in.
The drafts in a fire can suck fragile glass from one end of a church to the other.
We found that out after the York Minster fire
Thread: Dialect expressions
14/04/2019 08:53:21
In the (former) Kent coal field there's a mix of Welsh, Yorkshire, Gerodie and Kent spoken.
In a study by the local uni Aylesham was found to have a distinct dialect of its own.
Alleys are 'jitties'. Lunch taken to work can be 'snap' , 'bait' or 'scran'.
Thread: seals for mini lathe tapered roller bearings?
02/04/2019 09:10:51
I read that the original mini lathe design was of Russian origin and used TRBs. The later Chinese version used ball races.
Maybe an old drawing could be tracked down?
Thread: Chinese 7x10 lathe
31/03/2019 09:44:50
+1 for the 16" sc3.
Thread: Glazing Bars
30/03/2019 09:21:31
Bit late spotting this one. I had to make 2 long clock cases in the glass works for the local time ball tower collection.
I used a 5/16 'bird mouth' hardwood moulding on the corners and 2mm picture glass for one.
The moulding could be made up from 3 x quadrants ?
3/8 x 3/8 brass angle, mitred and soldered for the other.
Thread: new workshop
28/02/2019 10:07:46
CAV installed new machines which upset the neighbours. We fitted tripple glazing and the walls and ceiling were foamed.
Still the noise travelled to the neighbour's houses.
Various materials were tried as insulating blocks under the machine feet, but eventually balsa wood was judged the best in this case.
