Here is a list of all the postings AJW has made in our forums. Click on a thread name to jump to the thread.
Thread: Oxy Acetylene or Oxy Propane? |
01/10/2018 09:17:48 |
I have used oxy propane for years and although never in a firebox it has been used in similar situations and find it works very well. I have also used oxy/mapp gas for steel welding, which has also worked well. Can't remember the make of my torch offhand but it is an Australian manufactured handset, I'm sure a BOC one would work just as well. Alan |
Thread: Motor needed |
30/09/2018 22:32:32 |
Bosch Rexroth for me, great unit very compact, fits in cabinet with remote panel fitted on my ML7 headstock. No great big boxes to accommodate. Highly recommended. Alan |
Thread: Myford 7, three step spindle pulley slipping |
17/09/2018 23:23:23 |
I have just noticed you have a S7, mine is only a ML7 - perhaps they are slightly different in that area? Alan |
17/09/2018 10:28:41 |
I know I have just fixed mine but I can't remember the part you are referring to? I heated the pulley and it came off quite nicely. Alan |
Thread: Stuart Steam fan from the USA |
13/09/2018 21:55:11 |
Hi Bill and welcome. Nice collection of engines you have there - is that a Sirius I spot in amongst them? I have an inherited Sun and have made a No 4 with reversing gear. Alan |
11/09/2018 20:41:59 |
It was me! I had this on my ML7 and would lose drive under a heavier than light load. Stripped spindle out and removed pulley from bronze gear. It was still a good fit so I warned the pulley and off it came. All cleaned up and degreased I assembled it with Granville bearing fit. Good as new! Alan |
Thread: Those funny drill saw things... |
11/09/2018 20:37:02 |
I have a set of them. Just need the telescope to use them! Alan |
Thread: Petrol proof adhesive |
09/09/2018 16:43:43 |
Yes, convinced and I am currently using it as I have for the past few years just find it surprising that it's not on the pack! Perhaps it is on a new pack, mine is quite old. Alan |
09/09/2018 15:00:30 |
I have just had another look at my pack of original JB Weld and it makes no mention at all of fuel suitability? Strange as I would have thought that would be a good selling point. Alan |
09/09/2018 10:22:47 |
Jason apologies for missing that, I wonder why it's not put on the packaging and instructions? Sounds like a solution - I shall update Edgar! Alan |
08/09/2018 21:55:42 |
Just had a thought, at the last ally pally exhibition I was very impressed with some demonstrated aluminium solder. Seemed to give a good fillet, just the sort of thing i am after. Having a thumb through the bay there appears to be quite a selection of aluminium soldering products Anyone had any experience of any? Alan |
08/09/2018 21:33:09 |
Thanks guys, I have milliput and nowhere in its writeup does it even mention any type of fuel so I am thinking perhaps not. I also have some original JB weld which once again does not mention any fuel exposure. Edgar himself suggests Bondafiller but unfortunately I think this particular product has disappeared over the years. The rubber compound sounds good, will look into that, I guess not to be confused with silicone rubber which swells enormously! Alan |
08/09/2018 19:23:18 |
Made a start on my new Edgar T Westbury's Centaur engine project. Started with the base, an aluminium casting with a large cavity underneath. As well as supporting the engine it acts as a fuel tank, the base of which it is suggested to bond in an alloy blanking panel. All well and good I thought so have been cleaning up the casting and have prepared a piece of 1/8 in ally sheet ready to fill the base. I was going to use Araldite to fix it in but am not sure about it liking being in full time contact with petrol or use something else? Alan |
Thread: Centaur castings arrived |
05/09/2018 17:12:25 |
Here you go - thought I would start a photographic record!
Edited By JasonB on 05/09/2018 17:38:53 |
05/09/2018 16:21:24 |
I have built a couple of engines before including a Stuart no4 with reversing gear, which was quite a complex engine. My castings arrived today for my Centaur project and having them all spread out to check they were all present and correct I thought that a newcomer could find this quite bewildering! Tackle one piece at a time and work through methodically. Alan |
Thread: Centaur engine timing gears |
04/09/2018 15:04:31 |
The HPC gears turned up today, very quick delivery. Nicely made pair of gears in steel which give a centre to centre working dimension of 0.795 which is not a million miles away from the original drawing dimension of 0.875. This should result in a minimal amount of camshaft repositioning. Alan |
04/09/2018 13:11:22 |
Great! Worth a look. I always strip down discarded stuff for anything that might be useful but I reckon my wife might notice the sewing machine not working! Alan |
03/09/2018 22:29:36 |
I realise that ETW was using gears with different skew angles which he suggested were salvaged from motor car distributor or speedometer drives but I think the chance of finding these now is long gone! I would imagine it is nigh on impossible to find off the shelf gearing of the original specifications. Alan |
03/09/2018 17:14:22 |
Thanks for the heads up. I think it's a bit poor show to supply gearing that is not 'quite' suitable. I have ordered a pair of gears from HPC Gears, who have a fantastic range. I will be ordering castings from Reeves and I will suggest that they use HPC as a supplier as the gears are far closer to the original spec. Looks to be a lovely engine, looking forward to getting started! Alan Edited By AJW on 03/09/2018 17:15:40 |
02/09/2018 22:51:34 |
Yes I think your correct - rh, looking at the drawing the gears are described as skew gears but do appear to have teeth sketched on them and are rh. Thanks all. Alan |
