Here is a list of all the postings Nick Wheeler has made in our forums. Click on a thread name to jump to the thread.
Thread: Shipping delays and costs |
21/01/2021 21:33:36 |
Posted by Frances IoM on 21/01/2021 20:57:58:
there was a large amount of publicity about a year ago to a regular ?weekly rail link between China + Europe/UK - has this not proved economic or have global politics intervened? When the largest ships hold 20,000 containers(according to Google) just how economic do you think shipping them by train will be? |
Thread: Silverline long reach air tool for Top/Crosslide mounting |
21/01/2021 08:53:15 |
Posted by Martin King 2 on 20/01/2021 21:37:43:
Nicholas, any chance of some supply links for the items on your grinder, power supply, motor spindle etc? pm me if links will not be allowed
I bought them off Ebay about 4 years ago, so a link won't help you much. A search for ER spindle motor will soon find what you need. I bought the motor, clamp, power supply and collets as a set, which comes to about £120 now. A length of 10mm square screwed to the motor clamp to fit a tool holder will have the the motor in use in a few minutes. |
20/01/2021 13:20:05 |
Posted by Greensands on 20/01/2021 12:31:07:
Typical use would be light spotting/drilling/grinding applications Air tools are horrible. Then you turn them on and they get worse.
This works well for what you mentioned, and I also use it for milling fluted knobs:
ER11 collets, drops onto the QCTP just like any other tool, and adjustable speed via the power supply. Cost about £80 all in from Ebay. I already had the 10mm square bar to mount it to the tool holder. |
Thread: Files - what do I need to know |
18/01/2021 00:24:19 |
As file handles are cheap, you could buy a few and fit them to the best files you already own. Practice with those, and then decide if you need new ones. Just buying new files won't improve your technique! |
Thread: New ways to skin a cat |
17/01/2021 13:56:39 |
Posted by Oldiron on 17/01/2021 13:19:51:
Posted by Graham Titman on 17/01/2021 12:39:04:
Or buy John Stevenson er block from Arc Euro little bit cheaper than importing from the states and do the same job BUT can you get 2" through a JS block? I cannot. Cheapest way is to make your own.
a few laser cut plates pinned together would do it |
Thread: Silver Soldering Materials |
16/01/2021 18:17:35 |
Posted by Dr_GMJN on 16/01/2021 17:18:09:
Jason - it wasn't actually for the Victoria cylinder, it was for the silver soldering required on the Hemmingway kits Myford spindle handle. Not sure what bit it's for, but presumably for fitting something like a 30mm x 40mm long boss to a shaft. Not bought the kit yet, but its says: "There is a single silver-soldered joint for which you'll need solder, flux and a propane torch." I wouldn't solder that even though I have the means. Step into the 20th century and loctite it. |
Thread: Increasing Friction?? |
15/01/2021 12:28:05 |
Posted by Hopper on 15/01/2021 11:51:18:
When disc brakes first appeared on street motorcycles, manufacturers (including Triumph) used chrome-plated discs. Mediocre in the dry, but boy, were they a lot of fun in the wet! Slippery as snot. Then the chrome wore off unevenly and you had on-off-on braking every revolution. Ah, wonderful days!
Which is an effect that any ten year old cyclist could have warned them about. I wouldn't want a bicycle without disc brakes now, although they are very fussy due to their small size. |
Thread: The Repair Shop is getting to me... |
10/01/2021 16:29:50 |
Posted by Nick Clarke 3 on 10/01/2021 16:07:09:
And apparently Edd China in Wheeler Dealers felt the show was becoming less technical too
It's only real enthusiasts who can see enough of a difference between the same job on different cars to keep watching
As I have government approved credentials for being an expert on Wheeler Dealers( |
Thread: Angle grinder cut off stand |
10/01/2021 12:16:37 |
Machine Mart sell them if there is one near you. LINK which looks better than the cheapo one I used to have. Bear in mind, this is a roughing out tool, not a precision one |
Thread: MEW 300 IS HERE ! |
09/01/2021 17:05:56 |
Posted by David Standing 1 on 09/01/2021 16:02:08:
Posted by Peter G. Shaw on 07/01/2021 16:56:41:
Not really interested in re-building an MGB Peter G. Shaw
Nor me. If I wanted to read articles about rebuilding cars, I would buy 'Practical Classics' or something like that. As the magazine title is 'Model Engineers' Workshop', I would prefer to read articles more linked to model engineers' workshops
Yet I looked at the picture of the car raised on farm jacks bolted to hub adapters, and wondered why I hadn't thought of doing that. The important part of the MEW title is workshop, not Model Engineer. If the magazine hadn't grown out of Model Engineer, it would have had a far more appropriate title. Something like Workshop Tools & Techniques |
09/01/2021 16:53:08 |
Posted by IanT on 09/01/2021 15:30:04:
I've watched quite a few but got a little frustrated, that when they came to an "interesting" bit (like some lathe or bench work) the producers seem to quickly jump away to the next project, only returning later when all the good stuff is finished. Unfortunately, the truth is that most viewers are watching for the human-story side of the series and not the workshop bit.
I watch it occasionally, but have no interest in watching someone machine/file/weld/paint an entire part. I know what that looks like, and watching somebody else do it is almost as much work as doing it myself. I'm unlikely to restore a teddy bear, but that's what makes a quick glimpse of what's involved interesting.
Some of the history of the items are worthwhile, but just because granny bought the wotsit 97 years ago with her first pay isn't |
Thread: help identifying gear module or dp |
08/01/2021 17:48:50 |
Posted by Richard Cox on 08/01/2021 16:52:45:
I admire what some of you lads can do with cad I can only dream, I keep toying with the idea of getting into it but not really got the need bit of a catch 22 really to get good at something you need to always do it (keep practising) and not really having the need nothing to practice with lol, I’ve played with fusion360 did a few tutorials, and downloaded free cad, I found modelling my projects in Fusion 360 as I made them was a good way of learning what I need to know. |
Thread: MIG Gas |
08/01/2021 10:32:17 |
Posted by Speedy Builder5 on 07/01/2021 18:39:36:
When I first purchased a MIg in 1998, MIG gas for steel was CO2. Now it is Argon 80% CO2 20%. Is this to limit CO2 emissions, or to improve weld joint? I bought my first MIG in 1990, and CO2/Argon mix was recommended then. I used CO2 because I worked in a bar and got it and a regulator for nothing. Then I used friend's machine with Argoshield, and rented a cylinder on the way home. I was repairing rusty cars. And it's 5% argon unless you're welding really thick steel.
CO2 is one of the waste products of brewing, and brewers struggle to get rid of it Edited By Nicholas Wheeler 1 on 08/01/2021 10:34:59 |
Thread: Holding drills in ER collets |
06/01/2021 19:31:08 |
Posted by Rob McSweeney on 06/01/2021 15:05:27:
Possibly worth investing in a few spare nuts, so that if you are drilling several sizes in sequence the drills can stay in their collets and save time and fiddling about? Why didn't I think of that? I often use the collet chuck for drilling, and already have four nuts for the various ER tools I have. Using them will save quite a lot of time and hassle. |
06/01/2021 16:53:07 |
Dave's description is exactly how I do it: ER32 chuck for milling, and any occasional drilling needed as part of a job. If the job is mostly drilling, I fit the drill chuck.
I decide which to do on the basis of time against hassle. |
Thread: DTI Stand - Single Lock Type? |
06/01/2021 13:28:19 |
I have the one pictured(or it's twin), and a couple of much smaller ones that were about £10 from ebay. The big one works perfectly out of the box; less than a turn of the knob locks it up tightly. The cheap ones now do the same after I took them apart and finished all the mating surfaces of the wedges properly. So I would say it's more of a wedging action than hydraulic |
Thread: TIG is harder than it looks |
31/12/2020 09:42:18 |
Posted by Pete White on 31/12/2020 08:47:21:
Some interesting points there. Having done quite a bit of gas welding I have been told and thought I could move on quickly, often wrong, ask the wife lol. There is a place quite close, Hinkley Leics who do 4 hours one to one tig tuition for 80 pounds, was going to go but got talked out of it then and now again Covid!!
You'll spend more than £80 in consumables with poorer results than the tuition. |
30/12/2020 21:01:20 |
Posted by noel shelley on 30/12/2020 19:40:44:
Hi, Using an EW9 shade might help you ! But why use tig on such thick material, it's the wrong process for this work.. Far to much tig I see looks beautiful but has poor penetration and therefore little mechanical strength. Great for thin tube or sheet in stainless or alli. Your job looks sound, just needs tidy'ing. If you can gas weld then it's likely setting of the machine and the right gas. Good Luck. Noel. I'm not a TIG expert by any means, but surely welding two materials that are of very different thickness is one of the reasons for using TIG rather than any other process? Having done some gas welding I found the action of feeding TIG filler rod to be the same, but holding a lighter, shorter torch with on the fly adjustments was much easier. On steel at least. Aluminium is another matter, as it's very difficult to tell the whether it's hot enough to weld, or about to melt on the floor. You have to speed up as you work along a seam and I don't get enough practice to do this well. I do most of my workshop welding with the TIG because it's at the end of the bench, whereas getting the MIG out to do it is more of a faff than is justified. But if I'm honest, the TIG is an extravagance that was bought using an unexpected windfall. |
Thread: Milling on a mini lathe |
27/12/2020 23:30:25 |
Posted by Pete. on 27/12/2020 22:46:32:
The cheap ones have a 50mm x 90mm table, completely useless, don't waste your money, the £100 ones are from India and China, having just looked, and not knowing anything about these, the ones claiming to be real myford ones are £170 including post, they make a point of not being the Indian or Chinese variant, probably a reason for that. 50 years ago, people were using them on myfords, not Chinese mini lathes, there's a size difference. The mini-lathe takes up less space than a Myford, but its swing is the same. The vertical slides are similarly sized too. |
27/12/2020 22:36:57 |
Like Dave, I bought the vertical slide for the mini-lathe as I didn't have space for a mill. Most of my work was on car parts, but it was so limited in space, clamping and size of cuts that I quickly bought a matching mini-mill and lived with having to move it around on the workbench to do all of my work. I've since bought a bigger lathe to improve my productivity(I can't accept that hobbyists don't have time constraints) and would have done the same for the mill, but I really don't have space for one. I did keep the slide, and have made an adapter to fit it to the WM250 lathe, so I could attach a milling spindle. That's because I would like to build a simple clock, and it seems to be the simplest setup for various wheel cutting operations. I do have most of the parts to convert the mill to CNC, and that's intended as a productivity increase rather than making difficult parts. Standing at a machine cranking handles for ages just to cut a simple feature on a part, let alone initial roughing out, is just tedious drudgery. Automating those all those sequential cuts while I do something else(which doesn't even have to be engineering) would be far more sensible. I will need to come up with a quick way of bolting/unbolting it to the bench though! Edited By Nicholas Wheeler 1 on 27/12/2020 22:37:29 |
