Here is a list of all the postings Mick Henshall has made in our forums. Click on a thread name to jump to the thread.
Thread: What did you do today (2015) |
10/10/2015 20:33:54 |
6 years- thats good isn't it, and what is the problem with the warco my W 14 is going fine and well pleased with it although it would be nice to have a bigger machine, I just milled a 1/2slot 5" long thru a 5/8 piece of BMS took a while but whose in a hurry Mick |
Thread: And the job list piles up! |
24/09/2015 20:47:53 |
Hi folks Stumbled across an interesting set of vids on you tube called "Sunday Nightcap" Twastard Engineering" 119 vids which are extremely good, made by a chap called John, best ones I've seen very informative and I'm learning loads --thanksJohn--now we all have a list of projects to do and trouble is watching all this stuff just adds to the list so it keeps getting longer, does anyone else have this problem? Mick |
Thread: We're Moving |
18/09/2015 10:02:10 |
I'confused who is "they"? Mick |
Thread: Knurling Wheel 'Pins' |
31/08/2015 11:12:28 |
31/08/2015 11:01:00 |
For what is worth I made my knurling tool some years ago and have used it on numerous occasions with no problems using m6 bolts, there could be a problem running up to a shoulder but so far so good Mick |
Thread: Clapper box |
29/08/2015 21:00:01 |
Thread: 25 years of Model Engineers' Workshop Special |
25/08/2015 19:40:06 |
I pay for MEW by direct debit which as we all know can be altered to cover price changes etc, is it not possible to somehow register to receive these extra publications automatically and avoid disappointment, the producers of our magazine must have an idea of what is coming up in the forseable future and the price to cover the mag + one offs included in our Direct debit payments, Mick |
Thread: Personal messaging |
21/08/2015 13:03:20 |
Thanks Neil, test received and understood Mick |
Thread: Pre war Colchester Master |
21/08/2015 12:53:17 |
I seem to have posted reply twice, second time I done this well I am an OAP!!!
Edited By Mick Henshall on 21/08/2015 12:57:59 Edited By Mick Henshall on 21/08/2015 13:00:08 |
Now that looks a nice piece of kit,congratulations-24 speeds crikey I have just 6 Mick
21/08/2015 12:47:33 |
If someone sends me a pm how will know? Mick |
18/08/2015 08:57:58 |
Forgot to mention there are some photos in album, there has been some progress since they were taken so will update soon Mick |
18/08/2015 08:57:57 |
18/08/2015 08:52:46 |
Thanks Nigel, I would be very interested. My shaper is made from a variety of unassociated parts from here and there, motor from a floor polisher giving 360rpm,the slides are from a very old lathe,the tool slide is the cross slide from an unknown lathe,the yoke is driven from a rejigged gearbox from a industrial dough making m/c,the chassis,ram and slides, scotch yoke auto feed made ffrom scratch, I like to make useful things from discarded pieces of other machines,the fun is fitting them together and also saves a lot of work, one of my other efforts was a dedicated tool grinder made from an ex forensic specimen slicing machine which does everything I need at a low cost,enjoy your trip abroad and I look forward to hearing from you Regards Mick |
17/08/2015 19:06:14 |
Thanks John, perhaps I'll try a good fitting pin first as it seems the easiest option, woulld be interesting to try your taper suggestion -maybe later Revgards Mick |
16/08/2015 19:17:09 |
Hi Folks, I am attemting to build a home made shaper,got to stage of making the clapper box and need to make the taper pin or find someone who can supply me with a #8 taper pin 3:6" long and a reamer to suit, has anyone any suggestions please? Dimensions are similar to the atlas 7" shaper, or maybe there is a gash box lurking in a workshop somewhere that is unwanted and for which I would pay coin of the realm for Mick h |
Thread: swarf! |
21/06/2015 09:01:11 |
My girl is very understanding,she even let me strip and rebuild my Series 2a landrover engine in the living room, there were bits of landrover all over the dwelling,not a word of complaint,down side is I seem to be responsiible for the housework,seems fair don't it
Mick |
Thread: Machine vice - Vertex/Arc Euro Trade/Gloster? |
30/04/2015 17:12:00 |
I have a WM-14 and use a vertex 4" vice on it and have had no problems with size of vice, fair to say I removed the swivel base first and the odd time I have used base there has no problem either, I did buy a 6"rotary table which is sometimes awkward to mount and wish I had got a 4" Mick h |
Thread: single phase motor-calculating rpm |
05/04/2015 10:59:32 |
The nm converts to 3.9 odd ft lbs don't know if thats enough torque you would need but it pushes my hacksaw through a lump of 2" steel no problem
05/04/2015 10:49:01 |
I use Parvalux 12 volt dc motor ,max amps 6,watts output 46,rpm 3000,rated continuous which has a gearbox fitted which gears it down to 50rpm,nm 5.35. This runs my home made machine hacksaw photos of which are in my photo album. It is compact with plenty of oomph, I don't know a great deal of elec theory but this works for me maybe it would work for you Mick H |
