Here is a list of all the postings Jon Gibbs has made in our forums. Click on a thread name to jump to the thread.
Thread: What Did You Do Today (2017) |
14/08/2017 13:49:35 |
Duncan and Neil's suggestion (also recommended by Martin Cleave) of half the infeed on the 90 degree set topslide (arc tan 0.5 = 26.6 degrees) also results in the reduced cutting forces and a cut on the RHS of the tool for 55 & 60 degree threads as well as giving direct depth reading. I'm not sure my poor old ML7 would cope with a directly cut thread at 8TPI or 3.5mm pitch! The method also has the big advantage IMHO that broadening the cut while at full depth is a cinch on either side of the thread crest just by adjusting the topslide. HTH Jon
Thread: Toolmex chuck problem? |
14/08/2017 13:33:29 |
Just a thought, but are the jaws inserted in the right order? It might be that the previous owner did their best to correct for the asymmetry that would create? Jon |
14/08/2017 10:56:23 |
Posted by Swarf, Mostly! on 14/08/2017 10:26:12:
He writes that for a right-hand male thread, 'the left-hand flank of the thread cannot touch its mating thread'. So it's the finish on the other flank that's important. I can't say that I'd noticed much difference in finish between the two sides of a thread. After all I thought the idea was that the intent to use a lower angle than 30/27.5 was to ensure that the right hand flank was "cut" on every pass too? It might be my inexperience though. Martin Cleave (Screwcutting in the lathe - WPS No 3) addresses the topic on page 157 (poor finish) and says that it may be due to "too pedantic following of top slide advancements" or the tool not set to cut on the trailing edge. Jon |
11/08/2017 11:26:19 |
Thanks Russell - it's a fun build and hopefully I'll end up with a useful set-up. I'm planning to make the full set of accessories and particularly the end-mill sharpening fixture. |
11/08/2017 09:33:16 |
Did a bit more to my HH advanced rest last night. Finished the two rotating dovetail slides on the RHS of the second photo. Still a fair bit to do but getting there. Also changed over to imgur to see if it solves the 3rd party hosting picture problem of Photobucket... Jon |
Thread: Thread cutting, which gear goes where? |
10/08/2017 15:43:03 |
Hi Nige, The ML7 handbook in pdf can be downloaded from here **LINK** Pages 25, 26 and 27 show the same nomenclature to help with your setups. HTH Jon |
Thread: Engineers stud or just studding |
09/08/2017 15:36:38 |
Hi Nige, This ebay seller lists them... **LINK** Never tried them but HTH Jon |
Thread: Myford Mandrel thread. |
07/08/2017 17:28:34 |
Posted by Nige on 07/08/2017 15:15:41:
Having got the head stock aligned as best I can for the time being I mounted a piece of EN1A and took a test cut over about 1 1/2" measuring diameter at both ends of the cut after each pass and noting the difference. After 6 or 7 cuts the difference was averaging out at about .001" the narrower dimension was always nearest the chuck. Not sure what conclusions to draw from this...Good, bad or indifferent ? It could be that the stock is bending away from the tool but if the cuts are light and the tool sharp enough then it could be fixed by at least one of a couple of things. 1) The headstock needs to be turned clockwise in relation to the bed - the mandrel end needs to come forwards, or 2) The bed is twisted and the front tailstock end needs to be lifted upwards to bring on the cut more towards the tailstock end. HTH Jon |
Thread: lathe tool cutting oils |
28/07/2017 15:26:48 |
Posted by Nige on 26/07/2017 21:24:05:
Does anybody have any experience, good or bad with these cutting fluids please. MAXCUT No.5 Chlorine Free Neat Tapping & Cutting Fluidfrom Arc Eurotrade and Multispec Cutting & Tapping Fluid (Ref: MT5)from Chronos. Nige, I've used the Arc product and Dormer Supercut (**LINK**) but got fed up with the high price and bought some of this oil off ebay **LINK**. Twice the price for 5 times the quantity and seems to do the job for me. HTH Jon |
Thread: Drilling holes in the 1860's |
28/07/2017 11:56:36 |
Whitworth's self-acting drilling machine and self-acting radial drilling machine were displayed at the 1851 Exhibition and would have been more than capable of boring plate I'd have thought... See figures 7 & 8. Jon |
Thread: workshop rust |
28/07/2017 09:49:03 |
Posted by Robbo on 27/07/2017 19:29:22:
Or if your cellar has one of those little windows at ground level, some extraction, which would draw air through from the house, might help. Sorry for being skeptical but doesn't this risk drawing moisture laden air from the house (cooking steam etc) onto the cold surfaces of the cellar potentially making the damp issue worse there? I'd be inclined to try to get air movement and a through-draught in the cellar so that the moisture you breathe out can be got rid of ASAP. Good luck and HTH Jon |
Thread: blueing mild steel |
28/07/2017 08:18:52 |
I bought some Birchwood Casey Super Blue and it's very easy and quick on mild steel. Can't say I "like toxic chemicals" as per Ian's comments above but sometimes they make sense. HTH Jon |
Thread: Myford multi stop |
27/07/2017 11:27:14 |
They are still available from Myford and can be found here... £264 inc VAT. Quite eye-watering to be honest Jon Edited By Jon Gibbs on 27/07/2017 11:34:47 |
Thread: HSS and Carbide Milling mills |
27/07/2017 09:11:12 |
Hi Alfie, What speed were you running the carbide end-mill compared to the HSS? Carbide should be run faster (~3x) and worked harder than HSS. HTH Jon |
Thread: 2040 deadline for Diesel and Petrol cars. |
26/07/2017 12:36:35 |
Posted by Ian Parkin on 26/07/2017 12:01:47:
Has anyone on here got real evidence of how much an electric car costs to charge? not hearsay or manufactures figures but real it cost me 40 units to do 40 miles sort of evidence anyway has anyone got real evidence in real world conditions Edited By Ian Parkin on 26/07/2017 12:03:05 Not real world evidence but both petrol and diesel have roughly the same energy in 1 litre as 10 kWhr. So your approximation of 1 unit per mile isn't far off assuming similar efficiencies between power sources. |
26/07/2017 11:52:05 |
We need some leadership from the government to give a boost to R&D IMHO and this is as good as anything they've come up with so far. We might have left Europe by 2040. We'll be eating goodness knows what (GM fruit and veg, hormone and chlorinated meat etc), with sea levels lapping at our ankles (from Greenland - I'm glad I don't live on Portsea Island anymore) but at least air pollution levels may be set to improve Jon |
Thread: Hand saw with depth stop? |
25/07/2017 11:53:49 |
Another thought would be freezer spray on the seat post while gently warming the seat tube. I don't think the freezer spray will damage the paintwork, especially if sprayed on the inside and may be enough to break the seizure. |
Thread: Isopropyl Alcohol as a Fuel |
20/07/2017 13:26:48 |
I use the 2-stroke Aspen in my chainsaw, strimmer and leaf blower. The big advantage for me is that the fuel can stay in there with no chance of it going off and they'll start first time no matter how long between uses. So, admittedly it's expensive but there's no waste and far less hassle. Jon |
Thread: Rebuilt ML7 |
20/07/2017 11:25:23 |
+1 Very nice restoration. ...and nice looking dials too - I was tempted to upgrade mine but at £41 each |
Thread: Corrosive liquids. ................................... |
19/07/2017 17:25:28 |
The thread probably belongs in the tearoom but it seemed a pretty civilized exchange of opposing views to me. |
