Member postings for Alan Waddington 2
Here is a list of all the postings Alan Waddington 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: What Did You Do Today (2017)
29/10/2017 19:14:46
Posted by Robin on 29/10/2017 19:08:52:
I like the red white and blue colour scheme, very patriotic smiley
Ha ha.......never noticed that smiley.....Although i guess the origins of the welder are kind of at odds with the concept !
Edited By Alan Waddington 2 on 29/10/2017 19:16:59
Thread: Pallas HO vertical milling head
29/10/2017 19:12:02
Is it not the rectangular recess that provides drive ? Similar to an INT arrangement. Could be wrong but would guess that your toolholder should have flats that fit in the recess.
29/10/2017 19:03:28
Posted by Neil Wyatt on 29/10/2017 18:44:55:
I'd argue it's because your iPad rotates them but doesn't pass the information on to the forum...
Won't argue with your logic on that one Neil wink.........thanks for sorting though yes
29/10/2017 18:02:39
In the never ending quest for more workshop space, i decided to take the wheels off my mig welder and hang it on the wall above my welding bench...........sounds easy but it was a 4 man lift surprise.........Once it was up there i managed to finish the garden gate that had been kicking around for weeks........another job ticked off the list yes Apologies for the sideways images, but this forum insists on rotating them when i upload from my ipad ?img_0092.jpg
img_0094.jpgY
Edited By Neil Wyatt on 29/10/2017 18:43:49
Thread: Cheap 3 phase inverters.
17/10/2017 22:27:25
Iv'e got an expensive one on my lathe ( bought secondhand so not so expensive) and a cheap chinese ebay special running my mill, they both perform perfectly well......how long they continue to perform, only time will tell ? After i bought the chinese one, someone posted a link to here....https://inverterdrive.com/....had i not already bought the one from ebay i would have probably used them instead, as the prices are very reasonable. ( mill inverter is 5hp)
Thread: In praise of angle grinders
04/10/2017 08:38:26
You would have made the job easier still if you had simply notched the ends, and your legs would have lined up 😉
Thread: Dog poo problem
27/09/2017 19:46:03
We recently switched our Two Weimaraners to "Taste of the Wild" dried food, it doesn't contain wheat or any other bulking agents, they do lots of different formulas, so you can choose the one to best suit your breed.
Stools are much smaller and more solid as they metabolise more of the food, you also feed them smaller quantities.
Can't recommend it enough, nothing worse than dealing with sloppy dog poop.......Ok maybe turning cast iron comes close cheeky
Thread: A most unusual metal
17/09/2017 17:33:49
I would guess that part has been metal injection moulded
Thread: Pannier Weld, Braze or silver solder
10/08/2017 21:03:35
Whichever way you decide to tackle it, i would definitely braze rather than weld, what you've got there is a classic stress fracture, if you weld it, chances are it will eventually fail again.
Thread: Stained cast iron
24/07/2017 22:32:22
It won't hold the work any better or run truer without the stains 😂
Thread: Credit where its due DRO
07/07/2017 19:54:06
i once bought some scales from colin.....thoroughly decent fellow and very competitive on price, highly recommended.
Thread: Boxford 280
27/06/2017 22:51:08
Sounds more like a dry bearing in the motor than inverter whine.......
Thread: Lathe
27/06/2017 22:42:30
Posted by Henry Bunn on 27/06/2017 22:29:01:
Its going to be imperial that is another problem i would think.
I would see that as a bonus........
22/06/2017 22:16:52
Careful, those whipped cream do dads can bite.........
Thread: Anyone know what this hydraulic pump is or how it works?
15/06/2017 14:51:32
Looks very similar to a 12v one i had running a small Hiab on my trailer. There was an allen key adjuster to up the pressure. When i first piped it up it wouldn't lift anything over 400kg, but once the screw was adjusted it easily did 800kg. I'm guessing it was some form of internal bypass.
Thread: eBay lathe
30/04/2017 09:12:04
Came across this on eBay, nice lathe for someone......however the unusual provenance in the description made me chuckle.....😁
Thread: Rusty lathe for sale
15/04/2017 09:50:40
6 bids, so someone clearly does
Thread: Bandsaw woes
12/04/2017 12:59:17
Well Brian, you were bang on the money, did the wire test and the guides were so far out, it's truly a wonder it ever cut straight or the blade stayed on for more than 5 minutes.
Quickly ran out of adjustment, so had to mill a bit of material off the castings to get things lined up. Just waiting for new blades to arrive now.
Was originally looking to buy a Femi bandsaw, but couldn't find a UK supplier of the model I fancied, might have another look.
Thread: Jenkin Steel
12/04/2017 12:51:48
Another vote for Jenkins, been using them for a while. last time I called in on my way home from holiday in Northumberland, very helpful and friendly, they have a massive stock of alloy steels. Said if I wanted anything specific, they would be happy to cut small quantities.
11/04/2017 21:07:49
Some good tips there Brian, wouldn't have thought of using wire to check alignment. With regards to tension, is it best to just have enough tension for the blade to stay on the wheels without slipping or are you supposed to have a set amount of deflection in the centre between the guides ( bit like checking a motorbike chain ). Iv'e only had dealings with large industrial bandsaws in the past, which had tension guides.
I might Contact Ian and see if he can re weld the last blade, although by the time I've covered postage each way, it probably won't make economic sense.
