Here is a list of all the postings john hunter 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Tom Senior belts |
29/01/2016 17:53:41 |
I would be grateful if any Tom Senior m1 owners would let know the specs for the motor drive belt. My own is very rough and i cannot see any information on it. I would say it is about 58 inches long on the inside and i am not sure if it is Z or A section. I hope someone can help me out . regards John
Thread: er collet chuck for tom senior |
19/04/2015 11:42:48 |
Have managed to remove collet holder now so its got to be worth replacing top and bottom bearings while the spindle is out. Many thanks for the kind replies.cheers John |
19/04/2015 11:14:00 |
thanks for the replies,i have got to a position where i have the spindle with the clarkson collet chuck still in it removed from the head, which still has to be removed but at least is not damaging the head.It my be easier to work on now and will soak it in plus gas. Is it worth putting my propane burner over it . many thanks john |
15/04/2015 18:28:21 |
Hello,I would be grateful for advice on my recent purchase of a Tom Senior M1 milling machine. I would like to use my er 25 collets in a suitable mt 2 chuck. Are they okay for milling ?. At the moment it is fitted with a Clarkson autolock which is seized due to not being used for 2 years and am thinking about removing it .Many thanks in advance for any replies. cheers. |
Thread: Harrison L5A Lathe |
31/03/2015 15:14:25 |
Can anybody tell me the size and thread of Harrison L5A oil nipples. Many Thanks |
Thread: reconditioning mini mill |
24/09/2014 09:23:02 |
I was wondering if any model engineer could give me advice on reconditioning a Conquest mill. I want to change the spindle and bearings and i would like to know if the sieg x2 spindle and bearings are the same size.This is due mainly to cost of spares for the Conquest... thanks John |
Thread: Snap rivets |
31/07/2014 20:50:27 |
Many thanks for the replies.I hope to have a fighting chance. cheers |
31/07/2014 09:25:35 |
Hello,can anyone give me some advice in the use of rivet snaps.I have two and up to now have not had any luck using them.Have looked on you tube but have found little.Any pictures would be useful.Cheers |
Thread: harrison L5/L5A |
07/07/2014 17:13:04 |
the cross slide screw is okay,just the wheel which is cast.probably been hit with a fork lift. as snapped on thee spokes .If any body has one for sale i would be pleased to purchase it.
07/07/2014 15:20:06 |
hello, i have just purchased a Harrison L5A and thanks to the pallet carrier they have smashed the cross slide handwheel .They also damaged the isolator on/off box. Has anyone any idea where i may be able to pick up the 4 inch cross slide handwheel. Many ThankS John |
Thread: early super 7 problem |
23/06/2014 10:24:16 |
Have since found out the cap screws are 2 ba and have now purchased some so thanks to the people who informed me.I would still like to do a mk2 clutch conversion in the future on my early super 7 and i wad wondering if anyone has done the conversion and parts needed. Cheers John |
23/06/2014 06:37:48 |
Hi Dennis,Tried to reply to your personal message but my gmail will not let me do it. I would be grateful if you have a cap screw spare.my countershaft vee cone pulley has had better days as well and i am looking for a replacement.any information on that is most welcome. regards john |
22/06/2014 21:25:39 |
Hello,can anybody tell me the thread size of the countershaft split collar allen screws. Thankyou |
21/06/2014 08:20:28 |
Thanks for the reply Dennis.I have now replaced all bearings and will the refit the the clutch over the next few days, I will replace the locking grubscrew on the adjuster.I do not have the any early manual pages. cheers John |
20/06/2014 20:11:37 |
Thanks to Tom i now have new bearings.They where purchased from Simply Bearings,leigh, lancs tel 01942 269837 and they are a very friendly crowd. The numbers are. major brand klnj3/4 imperial deep groove ball bearing Torrington B1212oh full compliment needle roller bearing with lubricating oil hole. Regards John |
18/06/2014 08:50:51 |
Thanks Tom,will give them a ring. |
18/06/2014 00:45:11 |
Thanks Dennis,I am aware of the locking grub screw but it still slips and thanks for the quick reply.If you have any idea for bearings please let me know. Cheers John. |
17/06/2014 22:11:02 |
Hello, I would be grateful for any advice you can give me on a slipping clutch on an early super 7 sk1453.I find that i am constantly adjusting it only to find it slips within a few minutes.I decided to strip it down and to be honest everything looked okay.The countershaft looked in good condition and the expanding iron shoe work but the adjuster had very slight wear.So i9 am at a loss to see the problem.the bearing are noisy and i would be grateful if someone could point me in the right direction to purchase them.would it be more sensible to fit the later type clutch if it can be done.Any advice is most welcome. Many Thanks. John
Thread: early myford super 7 |
26/02/2014 20:08:02 |
Many thanks for the replies.i will not have as much of a mess now i am better informed,cheers |
26/02/2014 16:46:38 |
any thoughts on sealng the leak from the sight glass.i was thinking of gasket cement. |
