Here is a list of all the postings Old School has made in our forums. Click on a thread name to jump to the thread.
Thread: Water jet cutting |
24/09/2020 18:15:07 |
It’s for a 2.5cc tether car it should do 150mph needs to be rigid. |
24/09/2020 17:36:12 |
Can anyone recommend a company that would cut out two model car chassis from 12mm thick mild steel 400mm long 60mm wide. thanks Oliver |
Thread: Scaling back forum activity |
11/09/2020 21:00:49 |
Barrie i believe their is a need for a more broad church model engineering site, the existing ones are predominantly set in the past. My interests are fast more modern model engineering for cars boats and planes. We now have a tether car track in the UK first one for around 50 years, we have only had two events Covid secure with a lot of interest in building cars which was once the domain of model engineers. |
Thread: Steel stock for newbie ??? |
11/09/2020 06:04:15 |
I buy my metal from a company called M machine, they have a big range of material and it’s all sold by grade, I like to know what I am buying. Plus they are very helpful. |
Thread: A 5cc Twin Shaft diesel engine |
07/09/2020 20:29:16 |
John Wells 3 sent you a pm |
Thread: Myford 254 faceplate options |
24/08/2020 16:48:54 |
My 264s faceplate is 10 inches diameter. |
Thread: D bit help |
19/08/2020 13:39:19 |
This perhaps a d bit is best described as a simple reamer and use as you would a reamer. i built A A Rayman,s high speed steam engine along with a flash steam boiler. Alan supplied me with drawings and a lot of help to build the boat that goes with it. My boat gets up and planes no problem at all. |
Thread: recommendations for used lathes? |
15/08/2020 20:54:14 |
https://www.ebay.co.uk/itm/lathe/254683209730?hash=item3b4c4d6002:g:zFoAAOSwJ59fMUE2 Theres the link to it. They are a good solid lathe capable of good work, had one as my first lathe also used one at school. |
Thread: epoxy resin preventing from sticking. |
15/08/2020 06:23:54 |
PVA mould release just paint on a couple of coats. |
Thread: Regular maintenance myford speed 10 |
13/08/2020 07:57:08 |
Not all of us are engineers I was a merchant navy deck officer but I can use a sextant amongst other things. |
Thread: Spectacles and solder. |
03/08/2020 06:13:47 |
You need to get them welded, some people who do jewellery welding may be able to help. |
Thread: Cutting brass with saw questions |
03/07/2020 06:49:07 |
These were the clocks my father made towards the end of his working life.
This was the last orrery he made. After that he made a few clocks for pleasure. His workshop was half a double garage only room for one person everything for the clocks was produced in the workshop. My mother made him keep four clocks one for each of their children mine is a long case clock. Will someone please turn the picture the right way round please. Edited By JasonB on 03/07/2020 07:52:55 |
02/07/2020 20:59:00 |
I spent most of my early life around clocks my father made his living making clocks, he was FBHI. The lathe was a Myford super7 wheel crossing out and plates for skeleton clocks were done on a big pantograph engraving machine. Because of the reduction on the engraver patterns could be cut out on a bandsaw from 1/16” ply. Wheels cut on a modified horizontal mill the fly cutters made by hand and hardened and tempered. Dials engraved using ply patterns on a rotary table with a face plate on it. Clocks were usually made in batches of 5 nearly all skeleton clocks from the very basic to orrery clocks. The saw in video looks very much like a fretsaw and not a piercing saw. I inherited all his hand tools all the machinery was sold. All the ply wood patterns were dumped. Edited By Old School on 02/07/2020 20:59:29 |
Thread: clarke cl500 improvements |
01/07/2020 17:41:13 |
The Raglan Little John is a superb lathe only parted with mine when I treated myself to a Myford 254 just before retirement |
Thread: Ultrasonics and citric acid |
29/06/2020 19:49:07 |
Yes you can citric acid and a little washing up liquid and do it hot you will get good results, change the solution regularly |
Thread: Floating Reamer Holder |
20/06/2020 06:54:37 |
Excellent video and tool, first time I have watched a video of this type to the end well done. |
Thread: Best places to buy metal for machining |
17/06/2020 06:23:35 |
I use M-Machine for most of the metal I use, what I like is that they tell you the grades of the material and a lot of what I make I need to know for the application. i was making some bevels gears that would be nitride hardened, they hadn’t got the size I wanted were prepared to get a bar in and sell me six inches. |
Thread: Grafton tools (who?) - rotary table |
16/06/2020 21:51:33 |
I bought an 8” Grafton rotary table 5 years it has been used a lot with no problems at all. I think it spent most of its life in a cupboard and got a coat of paint occasionally. |
Thread: A very nice 2.5cc control line speed engine |
13/06/2020 09:09:58 |
The speed should be in excess of 300kph in an controline aircraft, the current tether car record is 285kph held by a Norwegian his car and engine are home built his engine revs to 42 to 43,000. Both types of engine run on straight fuel 80% methanol and 20% castor oil. Barrie that’s an interesting engine project like the spark erosion for doing the transfer ports certainly better than the cast crankcases on my 2.5cc tether car engines. What piston liner set up have the gone for ABC or AAC ?Look forward to seeing some results.
Thread: How to glue plastics |
07/06/2020 18:26:32 |
I worked in the plastic pipe industry, making PE and PP pipes, all the purple pipe you see down motorways etc is mainly PE and is flame treated so that the print will stick to the pipe. Flame treat was phased out and we went to a plasma treatment and finally the ink producers made an ink that would stick and meet the requirements for print adhesion. Not much will stick to PE or PP. |
