Here is a list of all the postings Rod Renshaw has made in our forums. Click on a thread name to jump to the thread.
Thread: Is it possible to machine a lathe more accurate than the one you machine it on? If so, how? |
28/10/2021 20:43:54 |
I don't really know, but logic suggests that the earliest makers of lathes must have used some sort of dead centre lathe with hand held tools ( as Michael suggests), to make at least the turned parts of what we might recognise as the first type of lathe having any kind of similarity to what we would call a machine lathe today. If the parts produced were not as good as wanted they may have been corrected by hand tool methods and then built into a new machine better than the one they were turned on. I understand the very finest watchmakers' work is still done on primitive looking dead centre "turns" I remember reading someone who had an Ornamental Turning lathe saying that all the screws holding his lathe together had centres in the ends showing that they must have been turned between centres, perhaps using a single point hand held "threading tool" to cut the threads, no wonder the screws were not interchangeable. I should think that making an accurate lathe bed would have been very challenging until planers (or similar) were developed which begs the question "how did they make the planer bed?" Rod
Thread: How can I make an accurate 90° grind using a diamond whetstone? |
28/10/2021 11:57:24 |
+2 for John H - who clearly has a lot more patience than I have. And +! for Baz, I find these threads have an aweful fascination but I think I have had enough now. Rod |
Thread: Smart & Brown Questions |
27/10/2021 10:26:30 |
Jason,- thanks for that I was trying to spot the changes your edit had made and didn't think to look at the heading. Oldiron - Yes, your explanation is clearer than my brief note. John - I agree with NDIY about VFDs being the most useful drive for machine tools. Worth investigating. Usual advice with VFDs is "no switches between VFD and motor" because any switches might cause spikes which may cause the VFD to fail. This usually means one VFD per machine. As NDIY says the VFD will be able to control the motor, which makes the old switchgear redundant. Some workers wire up the VFD low voltage control cables to the original switches to give the appearance of using the old switchgear, in which case you don't need the internals of the switchgear, only the actual switches. There are experts on here who will advise on any specific aspect of your wiring but I think they will ask for more detail of the switchgear, VFD and motor. Rod
26/10/2021 21:02:22 |
Thanks Jason, what did I leave out or get wrong? Rod |
26/10/2021 20:50:37 |
Welcome John What are your interests and what do you plan to use your lathe for? Don't worry too much about rules on here. Just be polite and not abusive, (goes without saying really) and make half a dozen postings before you try to buy or sell anything and you won't go far wrong. Oh, and don't try to post links to things for sale from eBay or the Far East. Rod Edited By Rod Renshaw on 26/10/2021 20:52:02 Edited By JasonB on 26/10/2021 20:59:03 |
Thread: GH Thomas S7 topslide improvements |
25/10/2021 13:20:12 |
Nice job. Must do that myself. You may find an article on Woody's Workshop website on incorporating roller thrust bearings into the top and cross slide feedscrews interesting. Rod |
Thread: Vice |
22/10/2021 10:05:07 |
Never mind the width of the Atlantic, I find a difference in the length of my workshop! At the metalwork end it's a clamp and at the woodwork end it's a cramp, and sometimes it's the exact same tool that I have borrowed from the other end. Does this happen in places other than England ? ( I am not sure if the Scots and Welsh have this situation) Rod
Thread: Help with a broken Sieg Super X3 |
21/10/2021 20:24:44 |
I have always found Arc to give very good customer service. Not replying to an email does not sound like their usual standard. I wonder if the omission is anything to do with staffing problems due to Covid, or perhaps just a random thing. It might be worth trying them again. Rod |
Thread: Lathe query. |
21/10/2021 17:37:48 |
Welcome Paul All good advice above, but if you should be unfamiliar with working with it, please be aware that 415v will kill the unwary. 240v sometimes gives you a second chance but 415v is not forgiving Apologies if you know all this. Rod |
Thread: From where I might be able to source some 1300 micron (1.3mm) mild steel sheet? |
19/10/2021 20:23:18 |
John Now that we know a little more about the application:- Of the common materials, soft "steel" will be attracted most strongly ( High permeability), and the less carbon the better. Stainless steels are not so good, as you have said. A harder steel (more carbon) will not be attracted quite so strongly but the difference may not be important. But a harder steel will probably have more remanence, ie it will tend to become a magnet itself under the influence of the permanent magnet, especially if there is movement between the 2. But you said this does not matter. The essence of a latch is that it opens and closes so perhaps the build up of residual magnetism will affect the operation in time. So, very soft steel, or soft iron, alternative names for nearly pure iron. perhaps a lamination from an old transformer might be close enough in thickness. Your drawing does not make it clear why the thickness is so critical. Obtaining such small amounts of such material of a particular size may not be easy and some adaptation to the design may make life easier. Rod Edited By Rod Renshaw on 19/10/2021 20:55:54 |
19/10/2021 18:04:50 |
John I am not clear what you mean by "strongly magnetic." Ferromagnetism (as I understand it) divides into:- "Hard" - meaning it retains it's "magnetism" " permanently" - like a horseshoe magnet, sometimes called a permanent magnet. and "Soft" - meaning it is attracted to a magnet but is not magnetic itself unless it is close to a permanent magnet - like soft iron which you could pick up with a horseshoe magnet but otherwise it just sits inertly on the bench. Which you need is going to determine the suitable type of steel, and perhaps where you could get some from. Rod
Thread: Hi Far from new/poorly bench top lathe |
19/10/2021 11:58:11 |
Roy I don't know, just what I was told. Perhaps the man who told me the original story got self- act feed and cross feed mixed up. Rod |
19/10/2021 11:37:26 |
Someone told me once the "M" stood for "Military" and was because of the type M lathes having power cross feed and a self- act trip - which made them especially suitable for use on destroyers etc. while they were bouncing around on the ocean blue. any truth in this story do you think? Rod |
18/10/2021 16:14:08 |
Chris I had expected others to contribute to your question and to comment on the type of lathe you have. Drummond made lathes from about 1905 and many of their smaller types were used by model engineers. Solid reliable machines well worth restoring for their historical value as well as for use. Many were sold to the military for use on ships, submarines and army mobile field workshops. Some on this forum have and use the later Type M and I suspect there will be some who have or have used a type B and will be able to answer any specific questions you may have about this type. Rod Edited By Rod Renshaw on 18/10/2021 16:14:37 |
Thread: big jaws for my milling vise |
18/10/2021 15:49:11 |
Hi Celso Good solution to an awkward workpiece holding situation. I am afraid I could not follow the Spanish? soundtrack but the pictures are worth a thousand words. Keep up the good work. Regards Rod |
18/10/2021 12:53:52 |
Welcome to the forum. Seems to be a Drummond "B" type lathe. See "Lathes.com " website. Rod |
Thread: Super 7 questions |
18/10/2021 12:05:39 |
Re the oil cups for the countershaft bearings. My 1970s vintage Super 7 handbook has a rather "For Industrial use" feel about it. It says, on the fold out page, "Replenish oil-cups daily" but on the following page, in the text, it says "The hardened steel countershaft runs in oil impregnated bronze bearings which are located in the swing head. Oil cups are provided for occasional lubrication." I have tended to follow the later instruction, adding a few drops of nuto each time I came to use the lathe after a period of not using it, so rather like Martin's regime. I am still using the original shaft and bearings after 40 years so I don't worry too much about it. Rod |
Thread: Reproduction ivory look hand grips |
14/10/2021 14:36:12 |
I can confirm the potato in vinegar story,. but like John I have not tried it. I was told about it by a small girl who had read it in her Girl Guide Annual and told me "because you mess about with things in your shed" Rod |
14/10/2021 11:06:44 |
Reading through the posts it seems Myford may have changed the screws that secure the gearbox from !/4 " BSF to M6 at some point. OP might be best to check his machine. Rod |
13/10/2021 16:09:39 |
My Super 7 is about the same age as Tug's and all the holes indicated on your photo are 1/4" BSF on my lathe. Rod |
