Member postings for HomeUse
Here is a list of all the postings HomeUse has made in our forums. Click on a thread name to jump to the thread.
Thread: Bakers fluid
26/03/2014 09:28:42
Had similar problems - cured by washing in “Dish Washer” with normal detergent tabs - gave a good wash after with warm clean water - no further problems . Have done same on copper boiler to remove flux scale.
Make sure Her To Be Obayed is out.
Thread: Old lathes, maker unknown
21/03/2014 15:01:54
The one in the background is a Britannia Wood Turning or Straight Turning Lathe either model No (I think 7 or 8) which should rest on a foot driven flywheel stand - The metal cutting tools were “T” shaped on the cutting end with an extended handle on the bottom of the T - the top arms of the T were sharpened and in use one arm was rested in grooves in the top of the rest and then guided along to form cuts on the revolving material. Date of manufacture about 1900 - One was in my family(and used) up until about 1960. Wish I still had it !!
Thread: Painting a copper boiler
14/03/2014 10:15:23
The etching primer I use on copper boilers and all brass work is u-pol Acid (hash) 8 1K Etch Primer - available at good paint shop (car) suppliers - I find it needs a coat of following paint applied within 24 hrs (after drying period of 1 Hr) (Note:- No Hash Key on my keyboard)
Edited By HomeUse on 14/03/2014 10:16:25
10/03/2014 09:51:45
Normally the temperature of the outer shell (Not Cleading) is not much more than 100 deg C - the superheating of the steam comes after the steam goes thro. superheating tubes in the flue ways - LBSC did not used cleading (insulation) on he’s boilers and did not seem to have trouble with good quality enamel paints - My boiler is LBSC design and is covered with spray applied enamel from Phoenix Paints (No interest in the company other than a satisfied customer) The copper was fully cleaned /dried and scarified all over with a nylon scourer then given a coat of etching primer. Wear gloves as even a fingerprint (oil) will cause later problems.
Edited By HomeUse on 10/03/2014 09:52:49
Thread: Ball valves
21/02/2014 15:17:32
Ball valves - no problem with steam - this supplier has valves for all accassions
http://www.valves-online.co.uk/acatalog/Brass_Ball_Valves.html
Thread: M.E. thread screws wanted
14/01/2014 09:20:46
I understand that ME threads are based on the BSW thread form so 1/8 x 40 and 5/32 x 32 are the same in both types (for the critical their could be a slight difference in the "Crest and Root" -
Thread: 3D printing update
18/12/2013 11:41:19
Hi Michael - have been doing research into injecting Wax through hothead so as to make lost wax castings - very difficult to get temperature/flow worked out - will keep trying
Thread: Boring head - metric or imperial?
18/12/2013 11:37:40
OK - mine is M2/M3 tapers and the metric has metric thread and imperial thread (maybe UNF but I think more likely BSW - others may be different - The bars are also metric and imperial.
18/12/2013 09:07:35
Think you will find that the draw bars are also metric for metric head and imperial for imperial head - If your SX3 is metric then you will need to make up inp. draw bars
Thread: MT2 for rotary table
13/12/2013 14:01:41
Had same problem so bought a blank arbor and cut it down with angle grinder - cleaned up end on grindstone and then found that the arbor was only case hardened so could set centre hole in the end with normal drill - set arbor in lathe headstock to drill.
Thread: Myford Industrial Stand Wiring
08/12/2013 10:29:43
The colour wires seem to indicate that it is for 3 Phase - ? Have not seen that colour combination for single phase even with reverse ? may be others have.
Thread: supercharged V12 2 stroke
06/12/2013 18:11:35
? Is this by increasing the pressure into the crankcase or by increasing the flow between "primary compression" and the main (explosion) compression - keep us posted
Thread: Machining a soft-ended MT2
13/11/2013 09:34:09
"Stub's" avator looks like a rocket assisted elephant - could this be his latest project
Thread: 3.5" Railway Gauge Association
04/11/2013 08:51:55
Could be good Idea - Needs a lot more work before asking for subscriptions - Lets have more info. as suggested by Joegib (above)
Thread: Dremel 3000 vs Challenge Extreme
02/11/2013 09:04:31
If you want a tool that is going to last a lifetime then try "Rotozip"http://www.rotozip.com/en-us/CuttingTools/Pages/cuttingtools.aspx?catid=5122 - the collets take the "Dremel" type cutters/burrs etc. - Had mine for over 30 years, using as hand held or with mountings on lathe and mill.
More expensive than most but well worth the extra cost.
Thread: Prescription Safety Glasses
16/10/2013 09:27:16
Just had pair from "Should have gone to" (British TV Add) - Cost £68 - Free Eye test - Ready in 14 days - Spec :- Clear glass upper area for long,normal distance and perception in lower area - needed getting used to not looking thro' top and bottom at the same time - No Problems
Thread: making a 3.5 inch boiler
19/09/2013 09:24:52
Have been told that TiG welded boilers will only be tested if they were welded by a qualified (certified) welder ?? or is this only for Stainless steel and does not include Copper boilers ???!!
Thread: BSMEE Thornbury Exhibition
16/08/2013 20:54:54
Been today (Friday) had quick talk with Springbok on the Bristol stand - Lots of people milling arround - Very good Show Well worth the visit - Bought some goodies ?"dont know if I realy need them"
Hope all who visit have as good a day as I did.
14/08/2013 08:29:36
Hi - Will be at the 2pm "meet" on Friday - Mine's a very strong black coffee - "Get the Kettle on"
MikeB
Thread: marking / layout blue
02/08/2013 09:06:50
Hi Slotdriller - Thought it was superglue on toilet seats (Not E Blue)
