John Durrant | 14/08/2014 16:22:06 |
44 forum posts 4 photos | I have an Amadeal XJ12-300 mini mill, bought used. I took off that spring thing and fitted a gas strut, then fitted three DRO's. It was the bees knees, I thought. But I was truing of a hole using an 8mm end mill as a reamer, I went too deep, the end mill jammed and teeth flew everywhere. I bit the bullet and ordered a belt drive upgrade kit from Amamdeal, Great service, ordered it on Sunday through EBay and had it fitted on the milling machine on Tuesday morning. Wonderful, for two days It started kicking and farting with a grating noise from the top end, I thought that I had pulled the belt too tight and knackered the bearing on the motor, so took off the end cap, and the bearing on the pulley end looks and feels perfect. I ran it under power and it still kicks with no load on it and every time it kicks there are blue sparks from the brushes. If I turn it by hand there is a slight squeaking noise from inside it. Now I know next to nothing about electricery, is the motor caput or is it the circuit board, and where is the best place to get replacements. Edited By John Durrant on 14/08/2014 16:22:36 |
Nick_G | 14/08/2014 16:28:18 |
![]() 1808 forum posts 744 photos | . I would say that the brushes have gone south. (quite common on some imported DC motors) Don't keep trying to run the rascal until they are replaced.
Nick |
Les Jones 1 | 14/08/2014 16:51:47 |
2292 forum posts 159 photos | Hi John, Les. |
John Durrant | 14/08/2014 17:00:22 |
44 forum posts 4 photos | Had a look at the brushes and they look OK to me, about 20mm long, smooth face and with a good spring on them. I can't see anything wrong with the winding or other parts. |
Mark P. | 14/08/2014 19:31:07 |
![]() 634 forum posts 9 photos | The DC motor brushes on my Warco WM16 wear very quickly and give this problem. Mark P. |
Paul Barrett | 14/08/2014 19:34:50 |
59 forum posts 16 photos | When I bought my XJ9525 from Amadeal around 7 years ago I had similar noises from the motor. When I stripped it down the magnet had come unglued from the casing. Hugh replaced it F.O.C. straight away. Edited By Paul Barrett on 14/08/2014 19:35:19 |
John Durrant | 14/08/2014 20:10:29 |
44 forum posts 4 photos | Although I am not keen on doing it, electricery is a dark art to me, it looks as if I must do a full strip down of the motor. I am afraid the Hugh will not help me though, I asked him for an XJ12-300 and he could not supply it for a month or so, so I bought a used one instead. You pay your money and take your choice. |
