Useability
Clive Haynes 1 | 03/08/2014 21:43:50 |
8 forum posts | Hi, is there anyone out there that has or has used the small Warco cutter grinder? I am considering buying one with the attachments for drill and lathe tool sharpening which I have always done freehand but fancy touching up the odd milling cutter. What are your experiences and are these machines any good? It's funny really as I finished my apprenticeship as a tool & cutter grinder many years ago making cutters for the macine shop auto's and capstan lathes, thats showing my age. So if anyone has any information about these machines I would appreciate it. Clive
David Colwill | 04/08/2014 01:35:56 |
782 forum posts 40 photos | Hi this has been covered here LINK Regards. David.
Clive Haynes 1 | 04/08/2014 21:59:38 |
8 forum posts | Thanks David for your reply and link which was informative but does'nt cover any detail of anyone putting one to full use. i e grinding a slot or end mill using a finger if it is possible. Clive |
Niloch | 05/08/2014 09:32:44 |
371 forum posts | You might be interested in the YouTube video, Using a Deckel Grinder |
Old School | 06/08/2014 09:30:04 |
426 forum posts 40 photos | Clive
I have one of these machines and have sharpened both end mills and slot drills sharpening the flutes is not easy as it is difficult to get a smooth action as you grind them I keep trying various modifications getting better but not there yet. I also bought the drill sharpening attachment its not very well made and does not appear to be capable of the precision required to sharpen a drill. Having said that that I cannot make sense of the instructions, so at the moment I have admitted defeat with drill sharpening. I tend to use a lot of small drills up to 6mm when they are blunt I replace them. It has been used for the final grinding of D bits and other cutters. Would I buy one with hindsight yes but it does not see much use about once every couple of months and I have a session sharpening milling cutters.
Olly |
Clive Haynes 1 | 07/08/2014 18:34:22 |
8 forum posts | Thanks for your reply Olly, These comments are giving me a better insight into the usefulness of these machines. I will probably get one if only to use for a diamond wheel setup. Clive |
