Here is a list of all the postings Clive Haynes 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Workshop lighting |
06/09/2014 22:15:26 |
Hi, regarding Mike Haughton's article on workshop lighting I would like to add details of the lighting that I use in my workshop & garage. Firstly I hate florescent lighting and seem to be constantly replacing tubes or starters. I have replaced all 10 units with LED units which I made from 50mm pvc trunking with the led self adhesive strips on the front face and the led driver on the inside of the trunking, with end caps in place the look quite neat. With this system you can tailor the fittings to your own requirements. The smd strips come in 5 meter lengths and in 2700 kelvin to over 6000. Just a little correction to Mike's reference to the stagecoach wheels in old movies, this was due to the shutter speed of the movie camera. |
Thread: Warco cutter grinder |
07/08/2014 18:34:22 |
Thanks for your reply Olly, These comments are giving me a better insight into the usefulness of these machines. I will probably get one if only to use for a diamond wheel setup. Clive |
04/08/2014 21:59:38 |
Thanks David for your reply and link which was informative but does'nt cover any detail of anyone putting one to full use. i e grinding a slot or end mill using a finger if it is possible. Clive |
Thread: Drill Press Options |
03/08/2014 22:37:36 |
I have a floor standing clarke pillar drill which I have owned for many years and have had no problems with accuracy but I have replaced the chuck as the one supplied is rubbish. So save yourself some cash and just replace the chuck or try your tailstock chuck. Clive |
Thread: Laptop/iPad stand |
03/08/2014 22:15:15 |
Looks good but can you still read music when you want to play your saxaphone? Clive |
03/08/2014 21:43:50 |
Hi, is there anyone out there that has or has used the small Warco cutter grinder? I am considering buying one with the attachments for drill and lathe tool sharpening which I have always done freehand but fancy touching up the odd milling cutter. What are your experiences and are these machines any good? It's funny really as I finished my apprenticeship as a tool & cutter grinder many years ago making cutters for the macine shop auto's and capstan lathes, thats showing my age. So if anyone has any information about these machines I would appreciate it. Clive
Thread: Suitable compressor |
03/08/2014 21:12:42 |
I have a heavy duty 12v tyre pump which will inflate a 16" tyre in 4 min, it is nicely made aluminium construction and cost me about £30. I had a quick look on ebay and there is a similar model but twin cylinder and claim 50 ltrs per min but it is £60. Clive |
25/06/2014 22:43:13 |
Have you looked at the BAMBI range of super quiet compressors? I've got a twin cylinder one which makes no more noise than fridge, the downside is that they only produce about 1.75 cfm per cylinder and they aint cheap. |
