ALUMINIUM PISTON
RICHARD GREEN 202/07/2014 11:47:36
329 forum posts
193 photos
Hello
I am making an aluminium piston for a steam engine from 6082 alloy, 4 1/4" bore diameter, ( cast iron cylinder )
Does anyone know how much clearance I should allow between the piston and cylinder , taking into account the expansion of the alumunium piston with steam at 150 psi ( 185 degrees C )
Richard.
Edited By RICHARD GREEN 2 on 02/07/2014 11:49:35
JasonB02/07/2014 12:03:57
Most of the traction engine guys allow about 0.002" - 0.003" per inch dia.
J
Andrew Johnston03/07/2014 11:01:32
7061 forum posts
719 photos
Assuming that we're talking traction engines running at a few hundred rpm the forces involved in reversing the direction of the piston at the end of each stroke are not that high, even with a solid cast iron piston. I would agree with JasonB on the clearances, but personally I would not be happy with the resultant rattling fit.
So just to be different I have designed hollow cast iron pistons for my 4" scale SCC engines. As a flavour here's a screen shot of an FEA analysis of one half of the LP piston:
The hollow LP CI piston is actually slightly lighter than an equivalent solid aluminium piston.
