Harrison Horizontal / Universal milling machine spare parts
Andy Pugh30/03/2014 21:40:07
67 forum posts
Surplus to requirements due to the CNC conversion I have
Table vertical screw, nut and nut housing. Condition seems to be very good.
Y-axis screw, nut, handwheel, bracket and micrometer dial. (everything except the thrust bearings). Condition seems to be excellent, very low backlash.
X-screw and nut, handle and micrometer dial. The nut is in the rotating housing for spiral milling. More wear than Z or Y, but still very usable.
The Feed motor/gearbox and a set of pick-off gears. Also the control box. I can probably find the limit switch housing too.
Click on the picture for a bigger version.
From Harrison Mill
Collection preferred, from Essex.
Rico Suave24/04/2014 21:59:03
5 forum posts
Hi there:
I am interested in two things! First and foremost, I think the CNC retrofit you did on your machine is awsome and it has inspired me to do the same, albeit I don't have the experience and skill you do. Gotta try though! So I have 2 broken harrison mills, where they both tipped and broke the x axis handle and deformed the corresponding nut, and the second machine the x leadscrew was sheared off with all corresponding components (parts lost by former owner). Thus far I have a replacement x lead screw and nut, but am lacking some components that it looks like you have due to CNC conversion. I am wondering if I can buy a subset of your parts (shipping weight is a big concern as I am in Canada), and I am also very interested in the plans you made to convert the machine to CNC. My plan is to CNC one machine and run the other in manual until the conversion is complete. I am a Hobbyist so time is on my side, and I plan for this to be a big long term learning project. Thanks and great work! Your YouTube demos are great! Cheers
Rico Suave24/04/2014 22:02:39
5 forum posts
Oops! I meant y-axis cross travel direction for the posting above, not x-axis!!!!
Andy Pugh25/04/2014 00:49:36
67 forum posts
Having noticed that I had private messages, it looks like I may have takers for the feed motor and the X screw, so the Y screw is the only spare part anyway.
I am happy to ship the parts to you at cost, though that might be quite a high cost.
Andy Pugh25/04/2014 01:18:40
67 forum posts
I forgot to say:
I don't have much in the way of drawings of the CNC conversion, I mainly work direct from 3D models. You are more than welcome to the 3D models, just say what format you can use.
If I was doing it again I might consider putting the X nut and bearings below the surface of the base, rather than exactly where the original nut was with a drive tube. Though then it might be hard to get enough travel (on the plus side it leaves more room for the telescopic screw cover).
If you haven't seen the pictures, here they are but I suspect you probably backed-up from the spare parts pictures already?
Rico Suave25/04/2014 03:33:16
5 forum posts
Thanks so much, sent you a private message, and your pictures have been very educational (and humbling) for me in planning my project!
tony conlon11/03/2015 20:16:50
2 forum posts
im looking for change gears for the power feed for a harrison mill, are these still there or gone thanks for your time.
Neil Wyatt11/03/2015 20:39:06
19226 forum posts
749 photos
86 articles
Andy,
You seem to have takers, but for the future we prefer folks to use the free classifieds for private adverts - it keeps the forums tidier
Andy Pugh11/03/2015 22:09:23
67 forum posts
Tony: Check your messages
Neil: Sorry to clutter the forum but it seems that PMs don't produce notifications?
