Best method for internal hone over short length
Mark C | 25/03/2014 22:15:59 |
707 forum posts 1 photos | I have a small cylindrical bearing that needs altering to C3 clearance, I was going to have it done out but at £20 for the race I thought I might give it a go in the workshop. I know a lot of people do bores with hones but the race is 26.5 mm diameter and 10 mm wide making it short compared to an engine cyl. I was wondering if anyone has any experience of honing such a short diameter and how they went about it? For information, I need to add 0.007 mm (roughly 2 or 3 tenths) to the diameter. Mark |
Michael Gilligan | 25/03/2014 22:33:08 |
![]() 23121 forum posts 1360 photos | Mark, Not much experience, I'm afraid ... I sold my Delapena because it wasn't being used. Biggest problem will be avoiding "bell-mouthing", so it's probably not a freehand job [which is all the Delapena was intented for] ... Here is an article that may help. MichaelG. |
jason udall | 25/03/2014 22:43:54 |
2032 forum posts 41 photos | How did you intend to immobilise/drive the inner race to hone it? Once done why not machine a stack..with first/last as sacrificial..to the gods of bellmouth |
jonathan heppel | 26/03/2014 07:35:57 |
99 forum posts | Why the C3 clearance? If you're just following factory recommendations I wouldn't bother. Such a tiny amount would make very little difference to the service life of the bearing, if that's your concern. Doesn't C3 refer to the clearance between inner and outer race? That would be a tricky job indeed, and well worth £20. |
Mark C | 26/03/2014 09:26:42 |
707 forum posts 1 photos | Sorry, the cost of the bearing assembly is £20, having it altered was more like £50.... I reckon for that I would have a go and still take a chance on a second standard bearing if it goes to pot! The idea is to alter the outer race to give extra running clearance and the bearing is "n" type with detachable outer race. the reason for trying is not just replacing like for like, it is a very tight fit in the housing and as it is on the business end of an armature, it gets quite a large temperature difference across the bearing, hence the increased running clearance. Michael, thanks, I did not think about holding the race before (I planned on sticking it in the 3 jaw!). I will probably make a housing that it can sit in, just clear so the diameter is free and nip it in with a retaining flange (should that be convex or concave Mark |
mgnbuk | 26/03/2014 10:15:38 |
1394 forum posts 103 photos | Why not adjust the mating part & keep the standard bearing standard ? Modify the bearing & next time you replace it you will have to modify the replacement - modify the mating part now & next time a standard bearing will fit straight in. Nigel B. |
