Help using faceplate on warco wm250
its a long way from the toolpost
Dismaldunc23/03/2014 13:14:56
91 forum posts
8 photos
Hi Chaps, I could do with a wee bit of advice (again!) I'm attempting to machine the rim of my "Wyvern" engine flywheel and using the face plate seemed the best way. bits of Perspex type stuff as stand offs but have a bit of a problem
as you can see the nearest I can get the carriage to the face plate will leave about 50mm of tool overhanging (this is with the topslide fully extended).
I think its the concertina type leadscrew cover causing the problem. The only thing I can think of is to make a long back to front boring tool (I suppose I mean a long RH tool) will this work or will it vibrate horribly?
Thanks in advance for your advise/comments
Dunc
JasonB23/03/2014 16:08:32
If you don't want to make a tool just use a big boring bar mounted upside down and run the spindle backwards, I have done it a few times on my 280
Dismaldunc23/03/2014 16:13:14
91 forum posts
8 photos
Excellent ! Thanks Jason I've got a nice beefy boring tool that should do the trick I never though of that.
