Information Needed for Restoration
Dsel | 03/03/2014 01:46:15 | ||
45 forum posts 34 photos |
Dsel | 03/03/2014 01:47:28 | ||
45 forum posts 34 photos | Photos of drill are in my RSB album. | ||
Nicholas Farr | 03/03/2014 18:43:36 | ||
![]() 3988 forum posts 1799 photos | Hi Dale, below is a scan of an illustration of a drill that looks similar to the one in your photo's. It is from a catalogue from a supplier by the name of Croager Bros. who had a place in Homerton, London. There is no date in the catalogue, but I'm guessing it was around 1939 as there is a footnote pasted in about certain piricees may be subject to change owing to the outbreak of war. It dosn't state what make except that it is British. Hope this may be of some help. Regards Nick. Edited By Nicholas Farr on 03/03/2014 18:56:20 | ||
Dsel | 03/03/2014 22:30:24 | ||
45 forum posts 34 photos | Thanks Nick, that is the first one I have seen with the F shape. Interesting it has the two stepped cone pulleys on the back, and a single one on the spindle. | ||
Bob Stevenson | 03/03/2014 22:46:20 | ||
579 forum posts 7 photos | I have a 'RSB' lathe which I have always assumed was made in the 1920's. For many years I have never been able to find any reference to RSB or ever heard of another machine than my own, or ever met anyone who has heard of RSB Sometime last year the 'Lathes UK' site suddenly published photos of a virtual facsimile to my machine and states that it is the only one known (although my own is in much better condition) Here is the link (for what it's worth) to the site page;
http://www.lathes.co.uk/rsb/ | ||
Nicholas Farr | 03/03/2014 23:06:19 | ||
![]() 3988 forum posts 1799 photos | Hi Dale, I think the idea is that there is a belt round the spindle and over the two idlers on the back of the bend and then round the pulley that is closest to the piller which is at the middle of the piller, you then have another belt which goes round the three cone pullies in the middle and the bottom, which will give three different speeds. A thrid belt will then go round the outermost idler pulley at the bottom and the motor and this belt would be flipped from the idler to the drive pulley at the bottom with the foot pedel when you want to drill your hole and then flipped back whenever you need to stop, thus you don't have to stop and start the motor each time which may be driving line belting and other machines that other people are using. Hope that makes sense. Regards Nick. | ||
Dsel | 03/03/2014 23:24:58 | ||
45 forum posts 34 photos | Bob, I have seen that link thanks, and did email Tony with photos of my drill and asked if he hd any new info, Never responded unfortunately. So i guess your in the same boat as me. Could I bother you for some detail on your lathe. What is the dimensions of the pulley cone, diameters, widths,crown,and wall thickness & how is it fitted to the shaft, key or grub screw etc. What are the head stock bearings, bronze or babbit? Same with the tailstock, also the keyway on the tailstock, where is the key and is it just a bolt?
Nick, That makes sense, I like the foot shift for the slow fast pulleys. I just wonder why not have the three speed pulley on the spindle like others did. | ||
Dsel | 03/03/2014 23:31:49 | ||
45 forum posts 34 photos | Bob, Just wondering what your using to drive your lathe and if there is a second set of pulleys etc?? | ||
Nicholas Farr | 03/03/2014 23:37:47 | ||
![]() 3988 forum posts 1799 photos | Hi Dale, I guess that having a single pulley is much simpler, being that the flat belt has to twist through 90 degrees as it travels over the two idlers on the back of the bend. Regards Nick. Edited By Nicholas Farr on 04/03/2014 00:05:59 | ||
Bob Stevenson | 04/03/2014 18:21:05 | ||
579 forum posts 7 photos | Dale,
The cone pulley is for flat 1 inch belting. The three pulleys are 5.5, 4.0, & 2.5 inches OSD The cone is fixed to spindle with a single screw. The cone castign is approx 0.25 inch thick.
My lathe has been stored for some years and it's about 25 years since I last 'saw' the bearings...can't remember what material or type Tailstock is by keyway internally...there is no bolt as in the 'lathes uk' specimen. My lathe has a different arrangment for bearing adjustment to that in the 'Lathes uk' site and does NOT have the cap pieces (as mentioned on the site).......the casting is simply split at the back and tightened by screws.
Recently I have considered overhaul, remotoring and adaptation for horological work as the lathe turns nicely and (as I remember) is capable of accurate work.
The original lathe was (presumably) treadle powered. I have the original cast iron stand with massive fly wheel but the actual treadle is long gone and I don't remember it. The fly wheel is approx. 2 ft OSD and has two flat belt locations...one near outside edge and another at about 5 inch diameter. In addition there is a fine belt 'groove' also near outside edge. For many years the lathe was driven by means of a 'Met-Vickers' electric motor driving the fly wheel and mounted on a home made tray bolted to stand. Edited By Bob Stevenson on 04/03/2014 18:25:53 | ||
Dsel | 04/03/2014 22:24:33 | ||
45 forum posts 34 photos | Bob, Thanks for you time & info. RSB machines seem so rare on the ground, its a shame to have it packed away. If someone new about them they might be worth something. You have 1 of 2 lathes in known existence.
Ian S C | 05/03/2014 09:48:02 | ||
![]() 7468 forum posts 230 photos | Just going by similar drill presses, I would not be surprised if you got the wrong war, I think it could be 1914, I could well be wrong. The one I know best has a chain over a pulley and down inside the column to a weight, to retract the quill. Ian S C
Dsel | 05/03/2014 22:25:32 | ||
45 forum posts 34 photos | Michael, Thanks for the info. A hand search of Birmingham Museums isn't really in the cards for me, bit far for a convict to return to the motherland just to research his drill. | ||
Dsel | 05/03/2014 23:17:07 | ||
45 forum posts 34 photos | Michael, where did you find that these companies made "RSB" I have just been researching them via google and can find reference to making cotton milling machines but no link to RSB.. | ||
Nicholas Farr | 06/03/2014 00:47:08 | ||
![]() 3988 forum posts 1799 photos | Hi Ian, I still think the catalogue was issued around the start of WW2, it also illustrats the Alba No.1a shaper and a Union 5" S.C. lathe, both of which only seem to be availble from 1930 according to Tony's website **LINK** Regards Nick. P.S. Yes I've used one of those with the chain and the wieght inside the column where I used to work a few years ago. Edited By Nicholas Farr on 06/03/2014 00:53:46 | ||
Bob Stevenson | 06/03/2014 08:48:34 | ||
579 forum posts 7 photos | It would be easier to find out info if the general dates could be tied down more. The 'lathes uk' site mentions circa 1910 for the RSB lathe and I would have said it dates from the late 20's to early to mid 30's...and it looks like late 30's for the drilling machine.........
What we want is someone with an interest (and knowledge) in the modeling magazines for 1910 to 1940 era who might remember an advertisement for RSB machines as they more or less HAD to place adverts to sell anything.
Alternatively,......What about museum services for Birmingham City Council as they probably have a register of old businesses and it's highly likely that RSB were there or nearby.
Lastly,...were there model engineering exhibitions in the early 20th century.............someone with archived programmes or guides might be able to turn up an address for RSB as they would probably have tried to exhibit their machines. | ||
Dsel | 06/03/2014 09:36:19 | ||
45 forum posts 34 photos | Some great ideas there Bob. If anyone has those leads. I sent off some emails to Reiter to see if they recognise the logo as part of their history. Or had any info that might hekp.
Dsel | 10/03/2014 23:00:53 | ||
45 forum posts 34 photos | I have been in touch with a long term employee of Rieter, who now in retirement manages their museum. He has checked machines from 1795-1945 and all machines including guns bear the name J.J.Rieter & Cie. in the casting. He has no knowledge of RSB. That is another dead end by the looks of it.
I am in the position of your inquiry regarding old machine tools made by RSB. I have an old book with the history of Rieter with all the machines manufactured from 1795 to 1945. Rieter has produced all kinds of machines and even guns in the last 219 years. All machines, without an exception, bear the name J.J.Rieter & Cie. in the casting. (Johann Jacob Rieter). The initials RSB are unknown to me. I am very sorry not being able to help you with your problem. I wish you good luck in finding the manufacturer RSB. Best regards from Switzerland | ||
Tony Griffiths 3 | 03/09/2017 22:55:31 | ||
2 forum posts | The RSB lathe: Hi Bob, I'd be very interested to see some pictures of your RSB lathe - the second to come to light in recent years. I'm afraid that their background still remains a Mystery; the link to Leeds and Breeds Lathes Ltd that I mention has, so far, drawn a blank in trade directories of that town for 1900 to 1930 - so perhaps that's a non-starter. My apolgies to Dsel for a non-reply about your drill - my email load can sometimes be just too large to cope with. Do try again, please.... My thanks, Tony. | ||
Stephen Williams 7 | 21/03/2019 12:50:57 | ||
1 forum posts | I too have just come across an RSB drill press with flat belt drive.it stands 3' tall and has a table 7 1/2" square.it is complete but I can't decide whether to use it or not |
