Dan Jones | 27/02/2014 20:02:06 |
![]() 83 forum posts 316 photos | Hi everyone, I've purchased a set of drawings for Live Steam Model's 4" Foster single cylinder agricultural engine. I have finished off model that are 3" and smaller but this is to be my first 4" build and my first full engine build. I'm wondering if there is anyone who knows what components I should start first and what order the engine should be built in, for example a ground-up build or wheels then boiler type of build.
If anyone can help I would be really grateful. Thanks, Dan. |
JasonB | 27/02/2014 20:09:05 |
![]() 25215 forum posts 3105 photos 1 articles | Most people tend to start with the front end - front wheels then hornplates, shafts and the rear wheels and then move onto cylinder and motion followed by tender and plumbing Get your boiler on order soon as most of the suppliers have about a 12month lead in, you won't be needing it for the front end. Also very importand, read the long list of drawing errors here before you buy or cut any materails You may also want to join Traction Talk forum, there are several Foster owners & builders there.
J Edited By JasonB on 27/02/2014 20:10:16 |
Dan Jones | 27/02/2014 20:16:45 |
![]() 83 forum posts 316 photos | I've heard that the front end is generally the place builders start. Do you know if LSM supplies any laser cut parts like hornplates, tender plates, spokes etc? Thanks, Dan. |
GarryC | 27/02/2014 20:16:59 |
![]() 740 forum posts 1043 photos | Hi Dan Are you going to be uploading progress of your build anywhere on line? I would like to follow it if you are. On here would be great of course.... Thanks. Regards Allan. |
Dan Jones | 27/02/2014 20:21:29 |
![]() 83 forum posts 316 photos | Allan I can post build progress on here if people would like to see it. But beware, I have a habit of making slow progress!
Thanks, Dan. |
JasonB | 27/02/2014 20:39:06 |
![]() 25215 forum posts 3105 photos 1 articles | Yes they do a lot of lazer cut parts, not sure how they work out cost wise compared with doing your own drawings and getting your local cutters to do it. Does not matter how slow you are we still like to see pictures |
GarryC | 27/02/2014 20:40:44 |
![]() 740 forum posts 1043 photos | Hi Dan I would love to see it on here I'm sure others would as well. Timescale no problem of course. As many pics and descriptions of the processes and machining setups as possible would be brilliant, better still if you can relate them to the drawings - even seemingly the most basic things and right from the start.. Sorry I'm asking way too much! I'll keep my fingers crossed and be pleased to see whatever! Cheers. Allan. |
Martin Cottrell | 27/02/2014 21:53:20 |
297 forum posts 18 photos | Hi Dan, I am also about to start the daunting task of a full Traction Engine build. Mine is a 4" Little Samson. I am in the process of re organising my garage into a workshop and once that is done I shall start on the engine. I will probably be posting some pics on here as progress is made and will definitely be posting questions when my skill level falls short of the required level! I anticipate that the build will probably take me 3-4 years so maybe we can have a race to the first steam-up! Regards, Martin. |
Martin Cottrell | 27/02/2014 21:54:33 |
297 forum posts 18 photos | Removed duplicate posting! Edited By Martin Cottrell on 27/02/2014 21:55:34 |
Paul Janes | 28/02/2014 08:46:17 |
23 forum posts 3 photos | Hi Dan, I am building a 6" Ruston Proctor SD. Probably about the same size as your 4" Foster. Not being a machinist, I was advised by one to start at the front wheels and axle. Not too hard to accomplish, you learn a lot of skills and soon have something to to be proud of. Don't just just go to LSM for laser cut parts. Shop around and you may get a better price. I live in Australia and quotes for plates for my boiler and horn plates ranged from $600 to over $1000. Not everything has to be laser cut. (normally costs more than oxy cutting). Laser cut tolerance can be within 0.3mm but oxy profile cutting within 1-2mm.( Some of my photos are on Traction Talk in the model section). P.S. Double check all of the dimensions on the drawings. A lot of mine are wrong. Good luck, Paul |
Chris Gunn | 28/02/2014 14:50:36 |
459 forum posts 28 photos | I would start with all the wheels if you have the castings, all can be machined together, all similar parts, then build the wheels, again common methods to front and rear, then make the front end, then rear axle parts. when you get the boiler make yourself a trolley with castors to support the engine, arrange it so the wheels will be a few inches off the ground, then you can move it around to work on, it will be at a better working height, and when you get to the motion etc, you can turn the engine over, rotate the wheels, check gearing and so on. when the time comes you can run the complete drive train to test. As Paul says shop around for laser cut parts, seems to be overcapacity where I live, and good prices seem possible. Chris Gunn |
Dan Jones | 01/03/2014 13:24:49 |
![]() 83 forum posts 316 photos | Hi guys I'll try and keep you all posted with pictures and notes of the build. I think that the order of the build will be front end first and get a boiler on order. I've been reading through the list of drawing errors and joint breaking studs for the covers on the cylinder block seem to be a trending topic. I have noticed the provision for these holes on other models and I have a couple of questions about them. How do these studs work? Are the holes for the studs in the covers threaded or drilled clear?
Many thanks, Dan. |
JasonB | 01/03/2014 13:32:14 |
![]() 25215 forum posts 3105 photos 1 articles | All the main stud holes are drilled clearance size through the cover, the ones to remove the covers are drilled and tapped but the hole does not extend into the cylinder block. In use you undo all the nuts and remove them and then screw a couple of bolts into the tapped holes, as they contact the block they will jack it away from the surface. J Edited By JasonB on 01/03/2014 13:33:34 |
michael cole | 01/03/2014 14:50:48 |
166 forum posts | Hi Dan and Martin Good to hear of more traction engine builds. I am also buidling a 4 inch Little Samson. Taken me about 4 years so far with a least 1 more to go. There are some very good build series of the Little Samson on TractionTalk forum.
Mike |
