slip ecentric drive pin
michael burton 108/12/2013 00:11:43
126 forum posts
32 photos
hi how do you work out the drive pin locataion on a slip eccentric iv got the eccentric with a 7mm off set to give me a 14mm throw...
is it critical as to were the drive pin is located
cheers all
michael burton 108/12/2013 00:25:27
126 forum posts
32 photos
im using a stop collar design and not the type were you use a plate with a curved slot
fizzy11/12/2013 20:40:53
1860 forum posts
121 photos
Im pretty sure the pin location has no bearing on things, its the dimension of the slotted part that is all important in determining the correct throw when moved to reverse
