Oompa Lumpa | 25/11/2013 21:06:36 |
888 forum posts 36 photos | Well, as you all know, took delivery of my nice shiny Chester DB7 VS lathe the weekend. I am, for the money, really pleased with it. So I have been playing with the settings and seeing what it can (and can't) do. The great thing about this machine is that I have a full set of Change Wheels and nothing has been bent, broken or cut out (yet!). Thing is, I decided to investigate screwcutting and of course there is a lovely schematic bolted to the casing, you know the kind of thing - Wheels A-B-C-D use "whatever tooth wheel in the chart". So I look along and find .7 and right after that .8 pitch - no .75 - which is a metric pitch I would want to cut. i am either misunderstanding the chart completely or this machine will not cut a .75 pitch screw in the Metric configuration. The machine is the Imperial version just for clarification. I was wondering if there is a workaround? graham. |
John Stevenson | 25/11/2013 21:10:55 |
![]() 5068 forum posts 3 photos | If the driving gear for 0.7 pitch is 20 and the gear for 0.8 is 21 then you need a 20 1/2 gear to get 0.75.
Simples. |
Oompa Lumpa | 25/11/2013 21:15:03 |
888 forum posts 36 photos | Posted by John Stevenson on 25/11/2013 21:10:55:
Simples. Thank you John, I can understand the logic in that but of course I just don't have such a thing. Under the circumstances I am going to call Chester in the morning. I really don't need to be learning gear cutting, yet! graham.
(ps, sorry about the double post) |
John Stevenson | 25/11/2013 21:39:36 |
![]() 5068 forum posts 3 photos | Graham, can you post a picture of the screwcutting chart please ? It's probably something simple, can it do 1.5 ? if so then 0.75 is just the same ratio with an extra 2:1 reduction somewhere. |
Hairy Pete | 25/11/2013 22:16:01 |
17 forum posts 3 photos | There's an example of 0.75mm pitch shown on page 18 of the manual. |
Oompa Lumpa | 26/11/2013 11:48:08 |
888 forum posts 36 photos | Posted by Hairy Pete on 25/11/2013 22:16:01:
There's an example of 0.75mm pitch shown on page 18 of the manual. Ah, snag is I do not have a manual. I will call Paul at Chester and enquire. Meanwhile here are the pictures: This second chart gives the wheel combinations for the common threads. Naturally I use 6-7-and 8mm Metric Fine, which are.75 pitch. of course I would....
Les Jones 1 | 26/11/2013 12:33:51 |
2292 forum posts 159 photos | I think this would work. A B 80 60
PS Is the leadscrew 12 TPI ? Les. Edited By Les Jones 1 on 26/11/2013 12:50:12 |
JasonB | 26/11/2013 13:19:25 |
![]() 25215 forum posts 3105 photos 1 articles | You can also go 60-H 80-51 H-72 Subject to the length of the banjo and it being 12tpi |
John Stevenson | 26/11/2013 14:34:44 |
![]() 5068 forum posts 3 photos | Just change A from 60 to 30 |
