Simple Mill Engine
Eric Cox15/11/2013 09:10:35
557 forum posts
38 photos
Bill of material (again)
Should the support pillar MP18 be 4 x 1" long instead of 4 x 4" long.
Stewart Hart15/11/2013 09:57:00
674 forum posts
357 photos
Yes it should Eric looks like I made the same mistake as for the slide bars:---- sorry crying
Just one ? out of interest, are you making the engine, only it would be nice to know if any one as taken on the challenge.
Stew
Howi15/11/2013 14:08:54
442 forum posts
19 photos
Posted by Stewart Hart on 15/11/2013 09:57:00:
Stew
just to let you know, I have completed the simple mill engine (not yet painted though)
I had a copy of the plans (with mistakes) prior to the article appearing in ME.
As a relative beginner to model engineering I found the overall construction relatively easy, thanks to your build log. I have learned a lot in the process and picked up on most of the mistakes which are pretty obvious really.
i elected to use a cast flywheel rather than fabricate one and ruined two carbide tipped lathe tools getting through the glass hard surface skin ( they were only cheap ones so no great loss ) but once through the skin flywheel machines easily. I had to reduce the height of the 16mm square piece between cylinder and base to get piston valve and sliders to match on centre height. I did make the parts in the reverse order to you though.
I started with the slide bars, crankshaft bearings , crankshaft etc the cylinder and piston being the last items machined. ( proves I am a relative beginner I suppose!!!).
I have had it running on air ( I need a compressor of some sorts though).
It has been a real pleasure to make and look forward to your other engines in the series.
many thanks
Stewart Hart15/11/2013 16:36:37
674 forum posts
357 photos
Hi Howard
Thanks for your post, it all adds to the enjoyment of the hobby to know you've helped someone, but no mater what level of experience you have you are always learning with this game.
Chilled Cast iron can be a real problem, I nearly did some permanent damage to my mill trying to cut a slice off a block of cast iron of unknown origin.
I won't be starting the next engine until March April time I have it sketched out but I'm waiting for the cold weather to drive me out of my shed, and so that I can draw it up in the warmth of the house.cool
Thanks again
Stew
