Help identify Chester Mill Drill
Jimillsortit21/10/2013 22:36:42
7 forum posts
Hi
Been browsing the forums for a few months now and finding my way around, some very interesting models and machine information which is where I need some help.
I purchased the mill drill less a motor which someone has tried to alter , I would be grateful if someone could advise from the picture what model the mill is, if anyone has a parts list or could advise on the motor kW and frame size required that would be great. I realise you might require some measurements which I can post up.
Ignore the pully sitting on top it was just a handy place to sit it.
Thanks in advance
Kevin Bennett22/10/2013 07:50:26
193 forum posts
56 photos
Hi I have one just the same i have had mine since 1997, i wil go in the workshop and look for you when the sun is up
thanks Kevin
John Coates22/10/2013 07:54:12
558 forum posts
28 photos
It's a Chester Champion circa 1990's.
I've got one with slightly different handles and column raising system
Original motor is 0.5hp/0.37Kw face (flange) mounted. I've converted mine to 3 phase by making a spindle to accept a taper bush and thence a new single drive pulley
Spindle is Morse No.3 which means tooling can be bought (collect chuck, slitting saw arbor, drill chuck)
I've just got to sort a column locking mechanism to keep the column in register when I loosen it to raise or lower. Yours might already have this
Edited By John Coates on 22/10/2013 07:58:06
Jimillsortit22/10/2013 08:36:57
7 forum posts
Thanks for prompt reply guys.
John when I measured the Morse Taper I thought it was MT 2 so I will have to recheck that.
John Coates22/10/2013 10:15:04
558 forum posts
28 photos
Hi Jim
Mine is MT3 so yours could be smaller
wink
Kevin Bennett22/10/2013 12:53:06
193 forum posts
56 photos
the plate on the motor is a bit scratched on mine
ty kevin
Flywheel22/10/2013 12:57:08
34 forum posts
Hi Jim
I have got the same mill, I have still got the original "chinglish" "manual" and parts list if you want a copy I can scan it and email it to you
regards
Peter
Jimillsortit22/10/2013 14:28:37
7 forum posts
Thanks Kevin the pictures are helpful they let me see the proper setup.
Peter that's kind of you I will PM my email address thanks.
John Coates22/10/2013 15:13:09
558 forum posts
28 photos
Mine is like Kevin's
Kevin Bennett22/10/2013 16:25:49
193 forum posts
56 photos
Hi Jim I am going to strip mine down in the next week or 2 as I am fitting new spindle bearing I can take the motor off and send photos of the fixing if it will help .
ty Kevin
Jimillsortit22/10/2013 19:30:49
7 forum posts
Thanks for the offer Kevin but I now understand how the motor is fitted so don't give yourself extra work.
Jim
Nicholas Farr22/10/2013 22:17:59
3988 forum posts
1799 photos
Hi Jim, as has been said it is a Chester Champion Mill/Drill, although the one in the picture below has a different colour scheme the specifications are the same.
The photo below shows the motor plate on my one and the only imformation in the parts list is that shown as in the type.
They discontinued them around 2007/8 ish.
Warco produced an almost identical one known as the ZX-15 and discontinued them a year or so after Chester.
Regards Nick.
Edited By Nicholas Farr on 22/10/2013 22:26:58
Jimillsortit23/10/2013 04:56:35
7 forum posts
Thanks Nick
This just confirms what others have advised above especially the picture of the motor plate.
Jim
