Eric Cox | 07/08/2013 12:09:56 |
![]() 557 forum posts 38 photos | With regards to the simple mill engine ME 4460 p113 the two tables show threading tools required (Table 1) and equivalents (table 2). Table 1 M2 M2.5 M3 M4 M5 Table 2 M2 M2.5 M3 M4 M6 M5 disappears and M6 appears. In ME4462 p227 fig 4 Front Cover is drilled and tapped M8 Which tapsa and dies are required, M5, M6 or M8 |
JasonB | 07/08/2013 12:45:25 |
![]() 25215 forum posts 3105 photos 1 articles |
Maybe Stew single point cut the M8 thread in which case taps and dies are not needed, guess we will just have to wait for the next installment to find out
Though actually I think its a typo and the part should be threaded M6, it was on his original build but he may have updated the drawing but not the tool list. I'm sure Stew will be along in a while to confirm Edited By JasonB on 07/08/2013 12:51:40 |
Eric Cox | 09/08/2013 09:54:41 |
![]() 557 forum posts 38 photos | I thought the magazine had employed a technical assistant to eliminate typos. On a less serious note Front and rear cover p227 "These are made from a bit of 1 3/8 inch aluminium bar that I picked up at the Manchester show"
I hope he got enough for everybody. |
Stewart Hart | 09/08/2013 12:01:58 |
![]() 674 forum posts 357 photos |
Posted by JasonB on 07/08/2013 12:45:25:
On my version I tapped the front cover M6 but decided things were a bit tight so changed the drawing to M8 so you will need M8 taps and dies but if you wish you can get away with M6 as i did:- some how things got missed up in the text, you will need a M6 die for the crank shaft, Sorry for the mix up chaps, any way you can't have enough taps and dies, if any one has been and bought an M8 I promis i'll have an M8 thread in my next engine so that it won't go to waste |
