End mill does two jobs at the same time
Ian P | 27/07/2013 21:07:45 |
![]() 2747 forum posts 123 photos |
Video is shaky as I am lowering the cutter and giving the job a spin whilst holding the camera. This was the second hole I cut, the first one started almost by itself. Cutting through the 1" takes about 10 minutes. The rotary table is made out of a car front wheel bearing/hub assembly. It has very little preload and yet no detectable play. The video is at, http://youtu.be/Jv8_JCiAbRk Ian P Edited By Ian Phillips on 27/07/2013 21:11:53 Edited By Ian Phillips on 27/07/2013 21:12:36 |
Carl Wilson 4 | 27/07/2013 21:54:32 |
![]() 670 forum posts 53 photos | Hello, I suspect that you, Sir, are a bit of a genius on the quiet. Carl. |
Nicholas Farr | 27/07/2013 22:16:15 |
![]() 3988 forum posts 1799 photos | Hi Ian, thats a neat idea. Regards Nick. |
Thor 🇳🇴 | 28/07/2013 06:05:37 |
![]() 1766 forum posts 46 photos | Hi Ian, I have done something similar but always used the handwheel on my rotary table. As you say, yours almost do everything by itself! I suppose the bearings in your rotary table has much less friction than mine. Nice video. Thor |
Ian P | 29/07/2013 08:44:04 |
Posted by Thor on 28/07/2013 06:05:37:
Hi Ian, I have done something similar but always used the handwheel on my rotary table. As you say, yours almost do everything by itself! I suppose the bearings in your rotary table has much less friction than mine. Nice video. Thor I would have done the same but I dont have a real rotary table. The 'table' on my rotating axis has a few sets of indexing holes in its top face (12 & 10) and I use it as a rotary indexer (with a lash up clamping device) I have used it to 'carefully' cut large radii on rectangular reatures by arranging temporary travel stops. Rotating the job whilst cutting needs concentration and a firm grip on the table! but it works. Ian P
Having said that if you have a table on which you can disengage the worm gear then |
